| Pusher Park Jets For all pusher jets and jet-like models. |
#26 | ||
Managed to get a session in last night home .... WOW !!
The change to a 4.75 x 4.75 gave it a whole new life ... and sound. Video will upload later ... Speeds from 80 - 110kph .... not bad I reckon for a flatplate scratch-build depron machine. Used the catapult - beautiful ! Went away straight as a die. Nigel |
#27 | ||
Video of first catapult launch of F15 ...............
http://youtu.be/eKNNDDdDMiY Very pleased with it ........... it's rekindled my desire to get my twin motor version of PKJ sorted !! Nigel |
#28 | ||
Friends: (12)
very...very...very cool!!!!Nigel,she flys great and the bunglaunch was perfect
. I've come to realize the best days to video are cloudy as the back drop lets our planes show up better as a black silhouette. nice build. really need to get the desirer to try and build something like this one day.
narrow is the place to land.
..wide is the space to crash ....choose the narrow way!
#29 | ||
Hi Stu ..... I was wary about the model before I flew her ... couldn't see that such a simple model would perform so well ... but BOY ! is she cooooooooooool !
The size is just right and will not be building the larger plan version. What i will do is modify to fit a couple of 40mm EDF's in next one. This one is already had modification to get a 920mAh 4S in ... so when I get back from Singapore - she'll be launched with a 3S as normal to make sure all still OK - then the 4S put in to really see what she'll do. The whole model took LESS than one standard sheet of 6mm Depron. I used a spare PKJ light high KV motor ... and spare prop / ESC etc. The LiPo's are from early days of my 50mm T45 ... so basically I was on the rummage bin to complete her for peanuts. The reward - well you see the video ! Stu - it was SO SIMPLE to make ... and my mods make it even more simple ... you have various stuff from the PKJ's ... why not get some 6mm depron and do it ? The colour scheme gave me trouble as all I found was the standard USAF grey .... having flown the first 2 flights with that and the couple of stripes on top - I added the white next day. Next one will be all-over white and then sun-burst stripes to get her visible. Maybe you noticed in the video, that as she flew overhead - the silhouette was EXACTLY an F15 ... Steve S certainly designed a brill plan model. OK - I took a few liberties and altered a few bits to make it easier to build ... but it's a sound design. Can't wait to get home again. Nigel |
#30 | ||
Home tmw ..... itching to get in air again !!
Have 4S to try in her next ... Nigel |
#31 | ||
Tried to catapult launch her ... but wouldn't play ! Then realised that ramp angle was too much and made it difficult for hook to work. Pal offered to hand launch .......... she rolled straight into the ground ... snapped of the nose. Got her home and asbout 10 mins with epoxy had her back together again. Video is being sorted now ... will link shortly. Nigel |
#32 | ||
The fateful Torque Roll vid !!
If anyone else can give any thoughts after watching .. I'm all ears !! What I don't understand is previous she launched fine 2x ... then this. http://www.youtube.com/watch?v=8Mezv...ature=youtu.be Nigel |
#33 | ||
Club: I do not belong to a club, I just fly at a park with other enthusiasts
Hi All,
After a 27 year break from modelling, I started again in 2011 and can't believe how it has all changed, I have so much to learn! Anyway, when I saw the F-15 plan, even better I can buy Depron locally, I had to build it. Only problem is, I lack creativity and skill when it comes to colours and schemes...... never mind, I still look forward to flying it when finished. Regards Ian |
#34 | ||
Have a good idea now what happened .... The bungee launcher was used to try launch her shortly before but due to uneven ground - angle was too steep and she kept slipping the hook. On last release - she slid of the rails onto the nose ... and may have cracked the front fuselage - where in the video she is broken after hitting the ground. We think that was cause. Nigel |
#35 | ||
Originally Posted by pistnbroke
This baby flies well ... I built the 70% smaller version from his tiled plans. I also linked the ailerons and elevators together ........... boy does she roll !!
Because it's hard to get CF rod etc. here - I cut the elevators into fixed stabs and elevators hinged ... removing the need to fabricate that central rod affair. I use a 9gr servo each side for aileron / elevator. Nigel |
#36 | ||
And ? Did you fly it or not ?
Nigel |
#37 | ||
I set-up the bungee catapult with extra tension for my 1.4kg F16 70mm .... and thought it would be fine for my lesser models .....
The lightweight F15 which normally goes of sweet on the catapult was yanked hard into the ground, breaking up the left wing. I've glued it back together but it doesn't look right - it seems to have a bend in that wing which I cannot remove. Looks like I may have to cut and replace whole wing or build another ... ![]() ![]() ![]() ![]() Nigel |
#38 | ||
Wind today too much for comfortable flying ...
Decided to replace the wing on this little gem ... Here's the wing cut away and you can see the deformed even after repair .. ![]() Getting sorted with 6mm Depron to cut out new ... ![]() New next to old ... ![]() In place for alignment .. ![]() Finished ... took about 2 hours total .... ![]() Nigel |
#39 | ||
I can't seem to win at moment with this model ... all was fine with her till she had a failed launch ... the wing / fuselage cracked. Repaired and then only trouble every launch after ... motors burning out, ESC's failing ... wing cracking ....
So new wing ... new motor .... new ESC .... http://www.youtube.com/watch?v=IagWw...ature=youtu.be ESC again fails !! Reckon I will downgrade the motor and give her a fighting chance !! Nigel |
#40 | ||
I've just swapped the motor out for the 2805 Emax 2840kv from HK .....
With 3S 1300 pack - she was drawing 14.8A on a 5x5 prop. http://www.hobbyking.com/hobbyking/s...idProduct=5353 A lot less amps than previous ... so I'm hoping that she'll still give good speed and stay in air longer ! If the motor proves itself - it could be a good candidate for twin installations .... Nigel |
#41 | ||
Hi Nigel, I have not tried my F-15 yet but I am getting close, I am a bit put off about launching pushers at the moment as I sliced another finger the weekend just gone launching someone else's pusher jet. Only 9 stitches this time! I will post a pick and a small video when I do the maiden. Regards Ian |
#42 | ||
You need this ....
http://www.youtube.com/watch?v=IagWwuqkw1E see attached files ... Nigel |
#43 | ||
Hi Nigel,
Thank you for the information on the bungee launcher, I was tossing between trying a dolly and the bungee. I think I will try the bungee. Regards Ian |
#44 | ||
Believe me .. the bungee is the best thing ever ... no more stitches and A&E dept's at hospitals ... best few $ ever ...
Nigel |
| bungie launcher for small hk parkjet? any suggestions? | stuart | Delta & Flying Wings | 13 | 05-01-2013 05:53 AM |
| Converting Pusher Parkjet to EDF | solentlife | Electric Ducted Fan Jets | 4 | 05-12-2012 10:36 AM |
| peregrin falcons dive 200+mph,can my parkjet go faster? | stuart | Pusher Park Jets | 7 | 05-09-2012 02:35 PM |
| HOBBYKING PARKJET..fantastic!!!!!!!a great flyer | stuart | Pusher Park Jets | 5 | 10-09-2011 03:05 AM |
| Grayson parkjet lipo setup | n3o | General Electric Discussions | 2 | 07-19-2011 11:24 PM |
