Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Company Support Forums > Heads UP RC discussion
Heads UP RC discussion Heads up RC discussion and support. Monitored by Heads UP RC.
Old 09-05-2012, 02:39 AM   #1
hardingham
Default Can't set throttle on HURC 50 Amp ESC
I have a new HURC 50 A ESC that I'm trying to hook up to a Spektrum AR500. I've connected it to a 5 A external UBEC, which I've plugged in to a spare channel on the receiver, while the ESC plug is connected to the THRO channel, with red wire disabled. The receiver is bound OK to the transmitter and will power servos but not the throttle channel. I have carefully followed the recommended steps for programming the ESC to learn the throttle range, but all I'm getting is a series of steady continuous beeps after the musical tone. My throttle setting in my transmitter (a DX7) is normal not reversed. I've tried setting the subtrim to Low -100. I did successfully get my setup to work with an AR6200 and a little Orange receiver, so I don't think I've made a trivial mistake like inserting a plug the wrong way. Anything I do, I just get the continuous beeps from the ESC.
Should I try rebinding the receiver, then go through the throttle range adjustment on the ESC?
Any advice much appreciated. Thanks!
hardingham is offline
Old 09-05-2012, 02:58 AM   #2
all_up_in_the_air
HeadsUp RC.com
Friends: (4)
The continous beeping indicates one of two things:
1. Throttle range is not set.
2. ESC is not receiving instructions from the receiver.
Considering that you said the ESC works with other receivers, there is likely an issue with your AR500 receiver. (You may want to test the AR500 with a different ESC to see if it functions properly).
I suggest re-binding, then trying to set the throttle range again. If that doesn't solve the problem, you'll need to use a different receiver.
Hope this is helpful to you
all_up_in_the_air is offline
Old 09-05-2012, 12:30 PM   #3
hardingham
Default thanks
Very helpful. Will try as you suggest.
E
Old 09-05-2012, 02:57 PM   #4
NJSwede
3D wannabe
NJSwede's Avatar
View NJSwede's Gallery1
1kW
If that doesn't work, by all means contact HeadsUp! They usually get back with a relevant answer within an hour or so.
AMA #959089
NJSwede is offline
Old 09-05-2012, 04:14 PM   #5
Friends: (16)
This thread might held determine if your receiver has issues. Use the digital multimeter to check the output signal of your AR500 receiver, and compare that to your orange receiver.
http://www.wattflyer.com/forums/showthread.php?t=54123
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 146 05-07-2013 03:24 PM
Emax Budget 50 Amp Brushless Motor ESC celticflyer Power Systems 4 05-01-2012 12:14 PM
My new 7.54 ounce motor and 50 amp esc gone2fly2 Power Systems 0 04-20-2011 09:18 PM
Sold 50 amp mystery esc ($10 shipped) gone2fly2 Motors and Speed Controllers for sale & WTB 0 04-06-2011 01:38 PM
Page generated in 0.20739 seconds with 27 queries
