| RC Radios, Transmitters, Receivers, Servos, gyros Discussion all about rc radios, transmitters, receivers, servos, etc. |
#1 | ||
Club: Augusta County RC Club
Since I'm not using Spektrum servos I intend to use my Dremel and grind off the plastic tab molded into the rx case so as to allow me to plug in my servos. Is this the proper way to approach this or am I missing something? (other than buying all my servos from Spektrum) In the attached pic the tabs are somewhat visible in the bottom side of the plug opening. |
#2 | ||
Club: CVMRCC, SEFSD
I don't ever recall seeing any of those in my Spektrum rx's. But I don't have that exact model rx either.
#3 | ||
It's easier to trim the corner off the servo connectors if they don't fit. The corners are there to prevent you from plugging in the servo backwards.
#4 | ||
2013 President of PSSF
If you are referring to the little triangular bump on the lower edge, That is the polarizing device. JR & Spektrum servo leads have two corners beveled at a 45 degree, it is slight but it is there. Full size JR receivers, many times have that little bump along both sides of the plug area. Works pretty good, but you can force them in wrong.
If you have Futaba servos, they will have a ridge along one edge of the plug, I just trim that off, scrape a bevel on the edges and plug them in. I have never found a need to cut the receiver case. In your picture, the signal wire will be the top row, then positive, with negative on the bottom row. The signal wire is almost always the pin that would have the closest relationship to the circuitry on the board. Pos & neg are common from pin to pin, or left to right |
Dave R, Proud PGR rider.
When you have flying skills like mine, ![]() You become a master at repair.
#5 | ||
Originally Posted by Wildflyer
Thanks Wildflyer
You answered a question I had forgotten to ask--that of proper direction of servo lead. I would have ultimately figured it out but you saved me some head scratching. After seeing the previous answer I did the forehead slap thing and wondered why I didn't see that before as the obvious answer. My servos are the inexpensive 9gr variety and slightly filing off the plug corner is the ticket. Many thanks to everyone's help! |
#6 | ||
Friends: (9)
It would sure be nice if Futaba would adapt the universal connector standard like the rest of the world.
Mike |
#7 | ||
I guess yesterday was just not my day. First I cooked my charger, then thought I'd have to modify my servo leads to fit my receiver. This evening took another look at the rx and found that indeed the servo leads do fit properly without any modifications. I guess I was just tired and not thinking clearly.
My B6 charger is still zapped but at least I got my rx installed in the plane. Ordered another B6 btw. Thanks for all the responses! |
#8 | ||
Pilotpete2
Originally Posted by rcers
It would even be nicer if JR/Spektrum and Airtronics would have the Futaba orientation slots in their receiver cases as Hitec does
![]() The slot for the Futaba orientation (not polarity) tab acts as a positive reference for orientating the JR universal style plugs without having to look for the markings on the case. Signal lead goes towards the slot, simple ![]() FWIW, Futaba servo plugs have had the bevels on them for many years, so trimming the tab off is all that's needed to use them on JR and Airtronics receivers. I still have JR/universal style connectors on some of my planes, for aileron connections you have to be careful to watch your wire colors, as it's easy to get them reversed. A PITA if you find out after bolting on the wing that one of your ailerons is not working. Been there, done that ![]() Pete |
"If the women don't find you handsome, they should at least find you handy"
Red Green |
#9 | ||
Friends: (9)
Pete - you are right that too would be great. Hitec gets it...
#10 | ||
Pilotpete2
rcers,
I've been down a long road with connector confoosion! My first radio, a Futaba Conquest AM used the ancient G connectors (the servo leads were actually male), my second an Attack AM with G connectors, then onto old style Airtronics with their insane plug with the negative in the center, which was a recipe for disaster. For a long time I used only JR universal stuff, but when I got back to Futaba, I started to appreciate the tabbed J connector, especially for stuff like aileron servos extensions. Cheers, Pete P.S. I'm usually right only 2 times a day, just like the brass ships bell clock in our living room, it's right only twice a day
Red Green |
| RX Switch Question | paxskipper | Beginners | 27 | 02-25-2012 10:21 AM |
| For Sale Spektrum AR6200 RX | MrMulligan | Radio Equipment For Sale & WTB | 5 | 10-21-2011 03:50 AM |
| For Sale Spektrum AR6110 DSM2 rx - $30 shipped | fliprob17 | Radio Equipment For Sale & WTB | 0 | 05-18-2011 03:26 PM |
| New HK 9ch Spektrum compatible RX | Wildflyer | RC Radios, Transmitters, Receivers, Servos, gyros | 9 | 05-17-2011 05:34 PM |
| For Sale Gws Pico Tigermoth BNF with Spektrum rx + 3 lipo packs+ extra 2.4 ghz system! $70! | 1987tc | Airplanes - Electric For Sale & WTB | 10 | 02-23-2011 03:05 AM |
