Old 09-15-2012, 11:50 AM   #1
Relsom
Default Power Supply For EFlite 1 Cell Charger
This E Flite EFLC100, the one with 4 AA batteries for charging the little 1 cell Blade lipos may optionally be supplied with a 6vdc supply. Has anyone had any luck using a generic OTS 6vdc supply? There are cautions in the manual about not using anything other than the E Flite EFLC1005 plug in supply with this. I can't imagine why there would be a problem using any supply as long as the plug is polarized correctly and it's capable of at least 600 to 800 ma.
....Chris
Relsom is offline
Old 09-15-2012, 12:39 PM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Yep volts are volts. I have used other supplies without an issue.
Old 09-15-2012, 12:57 PM   #3
Relsom
So do the batteries have to stay in the charger for the adapter to work. I can't get the light to come on while using the adapter with the AA's pulled out.
...Chris
Relsom is offline
Old 09-15-2012, 09:51 PM   #4
Relsom
Odd, the 6vdc 650ma power supply I was trying to use caused the charge light to turn off when I plugged it in. It was already in charge mode with a lipo inserted and the AA's installed.
I went up to my LHS to ask if they knew how it was s'pose to work. He didn't know for sure and swore all Eflite chargers were 12v. as he pulled out his "junk" box with a bunch of misc chargers and adapters. I found an EFLC 1005 in the box and showed him that it was 6v. He said the charger must need that 1.5a capacity and said I could have the adapter. He said it was last years model and he didn't need it. I didn't argue and bought some props and tools that I was needing anyway. Wala - problem solved.
....Chris
Relsom is offline
Old 09-15-2012, 11:45 PM   #5
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
I think I remember reading that you need to take the bqtteries
out if you are using an AC adapter
Helicopters don't really fly.......
They're just so ugly, that the earth repels them.
Heli Jim is offline
Old 09-16-2012, 12:21 PM   #6
Relsom
You may be right, Jim. And I may have posted victory too soon. With the AA's installed and the EFlite adapter plugged in the charging indicator did not shut off within a reasonable time. Charging indicator did not come on at all without the AA's installed.
I unplugged the charger and let the battery charge from the AA's. The light went out per the normal charge cycle. I have not seen instructions as what to do with the AA's when using the adapter. Point that out if you can find it.
I'm figuring that I either have a defective charger, I damaged the charger using a 650ma adapter(unlikely), or I'm not doing something right.
...Chris
Relsom is offline
Old 09-16-2012, 05:34 PM   #7
soar-ne
Omaha Ne.
I may be wrong, but it seems like when this charger came out others tried this and had the same problem. I think I read over on RCG several rears ago that when you take the unit apart their is a seperate tap for the light circuit that you have to modify. Might try a search over there in the Micro areas. I personally use rechargable batteries and have zero problems with my units.
Good Luck
Bob M.
soar-ne is offline
Introducing the ALL NEW Cellpro PowerLab 6 (EC5 version) Charger Howard Matos FMA Direct 7 10-25-2011 07:03 AM
For Sale SOLD-----eFuel 30 AMP 13.8 Volt DC Power Supply Merritt Batteries and Chargers Forsale/WTB 0 08-17-2011 03:05 AM
For Sale schulze isl 6-330d charger 8.06 version and a N Powered Novak DC power supply d12bn Batteries and Chargers Forsale/WTB 2 08-06-2011 01:00 PM
Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 0 07-28-2011 02:04 PM
Page generated in 0.07328 seconds with 31 queries
