Old 09-21-2012, 02:57 AM   #1
The_village_idiot
'every village needs 1
Default Bernard HV40 - Schneider Trophy racing seaplane scratch build
Hello all,
Time for another scratch build. I can't seem to get away from the Golden Era of aviation and most of the Schneider Trophy planes seem really cool to me. As I was surfing this site: http://doz.jp/sr/h_ozawa_works_2009.html
I came across the beautiful aviation artwork of Mr. Ozawa in Japan. The Bernard HV40 caught my eye with its oddball faired radial, and I knew I had to try and build one. It was really hard to find much information about the plane, so I contacted Mr. Ozawa and he graciously provided a 3-view and some other reference information he had found about the plane.
I have been slowly working on it for a few months now but our computer decided to go on sabbatical for a while. So now that the computer is back up and running, I have a backlog of photos to share.
I wanted to keep it parkflyer-ish, so the wing-span is about 40”. The airfoil is a Clark Y, mostly because they are easy to build, and float well enough for my limited pilot skills to keep up. Other than that, most specs are still up in the air (pun), based on the weight. I am targeting somewhere in the low 20oz. range (I hope). I decided that I am going to full sheet/plank this one, so I am a little worried about how the weight is going to work out.
Here is the picture progress so far.
Name:	Bernard HV40 side view.JPG
ID:	162729 The inspiration - thanks Ozawa-san!
ID:	162730 A few nights with the pencil, ruler and french curves to draw the formers
ID:	162731 Pretty standard construction - one side at a time
ID:	162732 Fuse halves
ID:	162733 The wing pierces the center of the fuse. The plan was to cut out the belly section under the wing later so the wing can be installed from underneath. That was dumb. I should have left the wing saddle pieces off, installed the wing, then put the saddle
The_village_idiot is offline
Old 09-21-2012, 04:40 AM   #2
View mclarkson's Gallery4
Outstanding Contributor Award
Best of luck. That's a beautiful plane. I love sports planes from that era.
mclarkson is online now
Old 09-21-2012, 02:41 PM   #3
Bill G
Super Contrubutor
Bill G's Avatar
View Bill G's Gallery82
Club: rcg staff
Friends: (17)
Beautiful subject with beautiful lines.
Roy Tassell had finished a beautiful model of a similar Bernard HV220 seaplane, started by a friend who had passed away. Sadly Roy has passed away this past year, and was an excellent seaplane modeler. I was fortunate to meet him on SeawingsUK a few years ago.
http://theflyingboatforum.forumlaunc...php?f=87&t=828
Bill G is offline
Old 11-20-2012, 02:36 AM   #4
The_village_idiot
Default Progress update
So its been a while. Here is the latest progress.
Basically, most of the parts have been framed out. I still need to work on the nose of the fuse and the motor mounting. Everything was looking to be pretty light until I started sheeting. The floats doubled (!) in weight from about 30g per side to 60g per side (1/32" sheeting). This is without glassing yet. I had really hoped to sheet/glass the rest of the plane but this weight increase has got me worried. I am planning on using 1/2 oz glass cloth but I still see the weight going way up. I am going to try glassing the floats first (basically because I have to in order to seal them up for bouyancy anyway) and see where they end up. This thing may just sink to the bottom of the lake!
ID:	164297 The battery 1000maH 3S is a tight fit right behind the firewall
ID:	164298 laying up the wing - typical construction
ID:	164299 framed out the wing. The LE will be shaped once the sheeting is applied.
ID:	164300 The framed wing is just under 60g.
ID:	164301 Fired up the pencil, ruler and french curves for sketching the floats
ID:	164302 The floats were built in halves, flat on the board and then assembled. The ply for the mounts was later hollowed out.
ID:	164303 I couldn't resist mocking everything into place just to see what it will look like. Sat in my chair and when "Vrooom" for a minute.
Old 11-20-2012, 02:58 AM   #5
I do that constantly with every build. Looking good there.
Old 11-20-2012, 03:24 AM   #6
View CHELLIE's Gallery13
Friends: (281)
Very Nice Build, Subscribed
Old 11-20-2012, 11:23 AM   #7
pd1
Still Learning
pd1's Avatar
View pd1's Gallery69
Club: Cape Ann RC Model Club
Friends: (53)
Nice airplane subject, nice job building.
Looking forward to more pictures.
Paul
pd1 is offline
Old 12-16-2012, 09:21 AM   #8
Allroaddm
When i finished my Macchi M39 Project this will be my next Seaplane Racer ! Great Job !
Greetings from Bavaria
Dirk
Allroaddm is offline
Old 12-17-2012, 03:20 PM   #9
soarrich
Soarrich
soarrich's Avatar
Club: JCSF & MMAC
Wow! That's really looking good.
soarrich is offline
Old 12-22-2012, 07:46 PM   #10
The_village_idiot
Default Float update
Slowly working on completing the floats. They are almost like building 2 additional airplanes!
Here's the story on weight for 1 float:
Float in the "bones": 31grams (see pics)
Float sheeted: 61grams
Fiberglassed w/ 0.5oz fabric: 87 grams
Primed/filled: ??
Based on these numbers, I need to figure out what I am going to do for the rest of the plan regarding covering - Should I sheet/glass or use covering?
This is my first experience with fiberglassing and I have to say it is going better than I expected. There is still lots of sanding/filling/priming to do but the finish is much better than I imagined.
ID:	164987 "In the bones" weight is 31grams. (sorry hard to read)
ID:	164991 With sheeting (1/32"), the weight is 61grams
ID:	164992 First fiberglass experience. Much easier than I expected, but still stressful.
ID:	164993 Glassed and sanded weight: 87grams.
ID:	164994 After a few rounds of sanding and priming. The surface is really smoothing out.
Old 12-22-2012, 07:47 PM   #11
The_village_idiot
Oops - the fiberglassed weight is 67grams, not 61...
Old 12-22-2012, 07:49 PM   #12
The_village_idiot
Living up to my login name... that should say " the sheeted weight is 67 grams, not 61..." Man, I need to take a break. Sorry.
Old 12-22-2012, 08:01 PM   #13
baz49exe
baz49exe's Avatar
View baz49exe's Gallery15
Club: East Devon Radio Control Club
Friends: (14)
Great subject and lovely workmanship! Can't wait to see the finished model. You've got to like a float plane!!!
baz49exe is offline
Old 01-17-2013, 03:33 AM   #14
The_village_idiot
Default more updates
Sorry I have been building, not blogging. Here is the latest.
I decided to go ahead and sheet/glass everything despite the weight. Looks like it will now be a hefty pig somewhere in the upper 20's ounces.
I sheeted most of the fuse, knowing that the fuse was crooked by a few millimeters along the back half. I guess I had hoped I could "pull" it back with the sheeting but, that didn't work, so... "off with its tail"! I spent some more time jigging the whole rear half to the build bench and had much better results the second time around.
With the fuse sheeted, I finally had enough parts to take a rough look where the CG would fall. My original thought was to put everything as far forward as I could get but I should have thought more about the floats, and how much weight they would put forward of the CG. (I am beginning to hate these floats...). After the first CG check, I found that was way off and I needed to move weight backwards. So...more cut and paste. The servos for the rudder and elevator have moved to the back of the belly pan, which works out better for weight and wire routing. The battery moves from right behind the firewall to the belly pan, right about at the CG. I have a few more details to work out but I think it will all finally work.
It is starting to look more and more like a real plane.
ID:	165620 The original plan - battery right behind the motor in order to get the CG right. Guess what? That was wrong.
ID:	165621 "Off with its tail!" Hacked the back half of the fuse because it was straight.
ID:	165622 2nd try and getting the fuse straight. Much better!
ID:	165623 Sheeted fuse with most of the big components mocked up for a CG test. The battery (blue foam with wheel weights on top of fuse) will end up pretty close to the CG position but in the belly pan
ID:	165624 Underside view, showing the belly pan. The rudder/ele servos moved from the front of the belly pan to the back. The battery will fit in the middle of the belly pan (at least that's the current plan)
Old 01-17-2013, 06:29 AM   #15
Looking awesome.
Old 01-29-2013, 05:01 AM   #16
The_village_idiot
Making slow progress...
Worked on the float struts and fairings. I decided to invest in making a set of jigs out of blue foam in order to keep the fuse and floats aligned while bending up the wire for the struts. It only took a little bit of time and probably saved me time in the long run. It was really easy to bend, check, bend again, etc... and keep everything straight.
The struts are a wire frame (I forget the wire diameter) with foam to make the shape. Once out of the jig, I found the floats are a little heavy for the wire, and they tend to sag in-board under the weight. That changes my strategy for the float bracing wires. I orignally planned on having them for aesthetics only but I think they will need to be structural to keep things solid. Looks like I have some "open float" surgery in my future...
ID:	165958 Jigs from blue foam to keep things square while the struts were rigged
ID:	165959 Basic strut wire frame with balsa ends to help shape the foam
ID:	165960 Strut and fairing in place. As far as struts go, I think it looks pretty cool.
ID:	165961 The foam was carved out on the back side to accept the wire frame. It will be filled in later with small strips of foam
Old 01-29-2013, 01:59 PM   #17
pmullen503
So cool!
pmullen503 is offline
Old 01-29-2013, 05:01 PM   #18
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Wow! How did I miss this build up till now? Beautiful subject and work, and once again, I'm envious of another's talent. (And patience!)
Old 02-16-2013, 02:21 AM   #19
The_village_idiot
Default Float surgery complete
As I mentioned in my last post, I needed to do some surgery on the floats in order to add some strength to make the float wires structural. After some hacking, I got all the wires (0.080 carbon rod) in and it made a huge difference in the stability/strength of the floats, even without glueing them in place.
ID:	166289 Once again, glad I made those jigs out of foam to keep everything aligned while the wires were sorted out.
ID:	166290 Yikes! Cutting the holes for the reinforcements was not my finest work. Added blocks to the plywood formers to receive the wires.
ID:	166291 Took a while to get all the angles right. I made the blocks in the floats a friction fit, that allowed me to rotate them to the right angle to match up to the wing. I had to fish the blocks out of the float a few times when they fell in.
ID:	166292 All the wires in place temporarily. Even without glueing them in, the strength is really improved.
Old 02-16-2013, 03:57 PM   #20
stuart
stuart's Avatar
Friends: (12)
she's a beauty for sure!!! your doing a great job to the whole project and i'm shocked i never posted before this to thankyou for sharing this build with us. i'v been following along but now i'm subscribed.
i really like the round fuse,all the kits i build are flat sided for the most part and i want to p/u a rounded bipe fuse build in the future.....seems building is taking a back seat to lazyness. thats the drawback of having a job i love and giving it my all during the week.
i like the 1/4 scale newport from balsa usa...
stuart is offline
Old 03-08-2013, 02:28 AM   #21
The_village_idiot
Here's the latest. Basically I have been doing a lot of fiberglassing, sanding, filling, sanding, priming, sanding, sanding, sanding.... I really don't know how guys can stand doing a 1/4 scale with fiberglass. I am glad I stuck with a ~40" span! Most of the major parts are now glassed and sanded but there is still so much to do.
ID:	166928 The fuse - half glassed. The sheeted weight of the fuse was 55grams. With glassing, it went up to 69 grams
ID:	166929 Can't help but put all the pieces together when I get the chance.
ID:	166930 Made 9 fairings for the engine out of blue foam. They will be glassed and hollowed out later. With all 9 of them on the fuse, it takes on this weird si-fi like shape.
ID:	166931 Again, can't help but mock stuff up. Still need to figure out all the blends with the wing root and float strut fairings. I also need to cut out the scale cylinder head holes.
Old 03-08-2013, 02:43 AM   #22
pmullen503
Looking good so far. The fairings are the defining feature of the plane, I don't envy you the work and skill it will take to get them just right. Are you going to pre-finish them before you glue them on?
Old 03-13-2013, 01:53 AM   #23
The_village_idiot
pmullen - you're right. The plan is to pre-finish the fairings and then glue them on. It would be really difficult to glue them on and then glass/sand/fill them. I am currently part way through glassing all the fairings. After that, I will hollow them out to save weight. I hope that I can glue them in place and only use a small fillet of microballons / epoxy where they meet the fuse. Everything will get a final sand/fill once it is all glued in place, in preparation for final paint.
I also need to integrate the fairings with the motor cooling somehow. The original plane had small holes in the fairings to provide some cooling to the radial engine. I am going to try and use these holes to help cool the motor.
Old 03-13-2013, 03:24 AM   #24
pmullen503
Perhaps this is a little late but it may help you do the cylinder heads. See this post on making cheap silicone casts using silicone caulk and cornstarch as a catalyst. Below is a dummy radial I made from a 1/12 scale Williams Brothers kit. I bought a single cylinder and crankcase kit and used them to make the molds, then cast the crankcase and 9 cylinders with epoxy. The detail was very good. If the foam fairings aren't up to snuff, you could also do the fairings this way too.
EPP F-22 Scratch build, first pusher jet. Timewarp Scratch and Kit Built Aircraft 5 02-11-2012 09:15 PM
$100 Scratch Build Contest "Best Looking" poll here hillbillynamedpossum Scratch and Kit Built Aircraft 100 01-07-2012 11:12 PM
First scratch build Aaeolien Scratch and Kit Built Aircraft 13 08-28-2011 03:30 AM
$100 Scratch Build Contest Best Build Thread hillbillynamedpossum Scratch and Kit Built Aircraft 2 05-17-2011 02:43 AM
$100.00 Scratch Build Contest: 60" Glider Propjobbill Scratch and Kit Built Aircraft 19 05-11-2011 04:08 AM
Page generated in 2.88290 seconds with 109 queries
