Old 10-02-2012, 01:15 AM   #1
gene375
Default ESC from Flyzone Cessna vs Flyzone Super Cub
I just swapped out the stock motor with an E-flite Park 450, and the motor mount I found here from Terry.
My question is, Will the ESC from the Flyzone Cessna which has 16g wires work better into theSuper Cub which has 18ga wire, I do not know any more about either ESC, and which one would be better suited for the upgraded motor and battery a 2200 20C... thanks Gene
gene375 is offline
Old 10-02-2012, 11:20 PM   #2
nidly
according to my info they are both 18 amp esc , but IDK if that's enough for your motor/prop combo.
nidly is offline
Old 10-03-2012, 12:47 AM   #3
gene375
So if I upgrade the ESC to match the 450 and a 9X6 prop, how do I figure it out.
gene375 is offline
Old 10-03-2012, 12:58 AM   #4
nidly
I'm pretty new at doing power combos , but perhaps these sites will help.
http://flbeagle.rchomepage.com/softw...c_imperial.htm
http://www.flybrushless.com/prop/view/78
http://rcadvisor.com/efficient-rc-el...-power-systems
Someone should check me out on this , but it seems like this 890 kv motor on 3s with 9x6 prop will pull only 10-12 amps max. Another try gave me 27 amps so I just don't know what rpm to use.
nidly is offline
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 165 06-28-2017 04:22 PM
flyzone super cub gene375 Beginners 9 09-26-2012 12:37 AM
For Sale Aluminum Motor Mounts for Multiplex, Parkzone, and Flyzone Super Cub Planes terrynshed Motors and Speed Controllers for sale & WTB 4 09-24-2012 05:33 PM
For Sale Aluminum motor mount for Flyzone Select Scale Super Cub and 450 size motor terrynshed Motors and Speed Controllers for sale & WTB 43 09-04-2011 04:32 PM
Page generated in 0.07131 seconds with 25 queries
