Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Hi-Performance and Sailplanes
Old 10-06-2012, 01:11 AM   #1
Dave D
Default Funjet ultra ESC or motor problem
I would like to know if anyone has had the same problem as me with the Multiplex Ultra combo. HC3514-2900 and Castle Creations LITE ICE 75. When I power up to about half throttle the motor goes into what sounds like it is vibration or prop cavitation. Not sure if this motor ESC combo is truly compatible. As soon as that happens the ESC gets a high amp spike and cooks the ESC. I have bought a second of the same combo with the same results. Sent both motors to Himax and they have reported no issues with either. Castle creations has fixed both ESCs twice. Running SKY LIPO 3 cell 4400 40c 80c burst. MAX has updated instructions for recommended settings which I have tried. standard timing PWM rate at 16Khz. Spent most of this flying season trying to resolve this issue. (HELP)
Dave D is offline
Old 10-06-2012, 01:55 AM   #2
Friends: (22)
hello dave and welcome to wattflyer. i don't know whats up with your setup,but could you share the prop size your spinning? have you done a watt/amp meter to the setup? i also fly the funjet ultra using a headsup rc powerup jet 450 brushless and 4cell 2800mah 30c zippy using the caslte creations ice 100amp esc. this is overkill but its what i had in the drawer and i may switch things up to go 6cell later. one problem i had was a bad zippy pack that must have been sagging in power during wot causing the motor to cut out and need rearming[lvc].most likely a bad cell.
that pack swelled up after a few cycles and has been trashed. i hope you fix the problem and please let us know what you find out. stu
Old 10-06-2012, 02:34 AM   #3
Dave D
I'm using the 6x5.5 that came with the motor ESC combo. Looking back at the logged data from the ESC I am between 60 and 70 amps max. I can't understand how I can purchase two of these combos and both have the same problem with both. I have tried multiple batteries with both and same issues. Spent 300.00 for these two motor ESC combos and have not been able to run through a complete battery. Very frustrated.
Dave D is offline
Old 10-08-2012, 02:21 AM   #4
Dave D
Here is a video of the problem that I am having. Toward the end you will hear the problem. If I let this happen a couple of times it will cook the ESC.
http://youtu.be/CsDKcVrZpF8
Dave D is offline
Old 10-08-2012, 06:45 AM   #5
welshboy
Default Re: Funjet ultra ESC or motor problem
I don't know the model, but have you tried balancing/changing the stock prop? The stock one I had on my Skysurfer was far too flexible.
Sent from my GT-I9300 using Tapatalk 2
welshboy is offline
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 165 06-28-2017 04:22 PM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra terrynshed General RC items For Sale and WTB 7 02-01-2012 05:11 AM
FunJet vs FunJet Ultra TylerJCooper Pusher Park Jets 24 06-11-2011 07:44 PM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra terrynshed Motors and Speed Controllers for sale & WTB 0 02-18-2011 04:11 AM
Page generated in 0.06590 seconds with 27 queries
