Old 10-16-2012, 09:07 PM   #1
Yakfishingfool
Default More newb info
What is the relationship of receivers to servos? If I go with a DSM transmitter I can use spektrum receivers and will any servo work with it or is there proprietary connectors? Just wondering. Scott
PS, just picked up a dx6i, was thinking of trying an orange 6ch receiver but not sure what servo to apply as I need three for my gentle lady conversion. Thanks. Scott
Yakfishingfool is offline
Old 10-16-2012, 09:15 PM   #2
pmullen503
Just about any three wire servo can be used with your receiver. The only caveat is if the servo has a Futaba style plug, it will have a tab that would insure the correct orientation when plugged into a Futaba receiver. In a pinch, the tab can be trimmed off with a knife to use the servo in other receivers.
It's best to just buy servos with the correct plug. In your case, JR or universal style.
pmullen503 is offline
Old 10-17-2012, 07:04 AM   #3
Friends: (16)
Yup, just about any servo will work from the small servos to the giant scale servos. They all have the same connector. One good brand of servos is the Hitec line. They are reasonable in cost, and they work well with the proper application.
They run in cost from $8 or so up to over $200 each, depending on if you are flying a slow sailplane, or a $$$$ 200 MPH wet turbine model. For your Gentle Lady conversion, methinks a standard servo about $12 or $15 will work just fine. I flew an electrified Gentle Lady years ago, had a lot of very good flights with it. After a few flights on that Gentle Lady, I put spoilers on the wing. It was very difficult to stop it when trying to land.
Take a look:
http://www.amainhobbies.com/index.ph...tandard-Analog
Newb Huge Thermal MyBspec888 General Electric Discussions 4 07-01-2012 03:40 PM
Info for anyone flying an SDM\ Harbor cub , exceed or Guanli 3ch cub. hangingon General Electric Discussions 0 01-30-2012 09:58 PM
NeeI am rebuilding a christen eagle by cox does not look in too bad a sd help or info Gofer303 Crash and Safety Forum 12 11-21-2011 02:15 AM
bananna sky flight radio info wlester RC Radios, Transmitters, Receivers, Servos, gyros 3 05-10-2011 11:53 AM
Ohio Combat Info Needed skynut Delta & Flying Wings 2 04-01-2011 05:04 PM
Page generated in 0.19243 seconds with 23 queries
