Old 05-30-2006, 01:08 PM   #26
jalves
jalves's Avatar
Well done Heiner,
The "bump" in the dorso seems to me that it isn't much scale look (have to see some pics from the real wing to compare) but the front is much scale looking, one of the best I saw.
Alves
jalves is offline
Old 05-30-2006, 02:24 PM   #27
Heiner
Here are some photos of the original one .....
Heiner
Heiner is offline
Old 05-30-2006, 04:30 PM   #28
Tempest
Very nice job Heiner! The intakes and turbine covers look great.
How scale would you say the plans are? Do you know which version it is scaled after V2 or 3?
Paul
Tempest is offline
Old 05-31-2006, 07:00 AM   #29
Heiner
@Paul,
I scale it to Ho-229 V3. Yesterday I finally got a plastic set of the DRAGON Ho-229 V3. Now I could see, that I have to flatten the turbine housing a little ......
Heiner
Heiner is offline
Old 05-31-2006, 06:50 PM   #30
bobthenuke
Inveterate Teenager
bobthenuke's Avatar
Beautiful job, Heiner.
You have a PM...
bob
The drawings are only a few of the beautiful work by A.L. Bentley. He has sets of drawings for multiple versions of the Ho9. IMO, a must have for serious Horton aircraft scale modelers. http://www.albentley-drawings.com/horten_ho229.htm
Name:	Ho229 Side.jpeg
bobthenuke is offline
Old 05-31-2006, 08:31 PM   #31
jalves
jalves's Avatar
Do you have more drawings of Ho-IX??
jalves is offline
Old 07-07-2006, 01:27 PM   #32
ghethco
Hi Heiner,
A few of us on RCSCALEBUILDER.COM are working on a Ho 229 design together. We are starting with a slope glider (PSS) but want to build an EDF version for hand or bungee launch. Some are dreaming of an ROG version with scale retracts, etc. Not sure if this is practical with current EDF technology.
I'm curious, how did you arrive at the wingspan to fan size figures below? Is this because of thrust requirements, or does it have to do with scale size of the openings?
Gary
Originally Posted by Heiner View Post
Tim,
if you choose the Het 3W at 3s1p you just draw 20A each in the minifan.
30A each at 4s1p ...........
Wing span, scale to fan diameter:
EDF 60 mm span 1 466 mm = 58 inch
EDF 69 mm span 1 680 mm = 66 inch
EDF 90 mm span 2 200 mm = 86 inch
Heiner
ghethco is offline
Old 07-07-2006, 08:41 PM   #33
ghethco
Default Re: Ho 229 EDF
Should have mentioned -- the reason I ask is that we are building a 66 inch span Ho IX V1 glider I'm hoping to do the first EDF model in the same span. The scale jet inlet and exhaust openings are about 2 inches at this scale. I'd like to stay as close to the scale inlet size as possible. The Wemotec micro fan is about the right size, but some have expressed doubts two of them can produce enough thrust. Has anyone tried tapered tubes? In other words, 'cone' shaped inlet and exhaust tubes with the 'choke' points at the ends. Or would this rob any extra thrust provided by the larger diameter fan?
I really don't like the look of scale jets with ridiculously oversized intakes. Ruins the scale looks and almost makes the model pointless, for me at least.
Speaking of tubes, what are people using? Are there ready-made lightweight tubes available for EDF? I haven't seen anything on the net.
Gary
ghethco is offline
Old 07-07-2006, 10:59 PM   #34
bobthenuke
Inveterate Teenager
bobthenuke's Avatar
Gary
Gary,
Although i deal with a lot of EDF models I'll never claim to be an authority. I can say, however, that the thrust of the Wemotec Micro fans is limited, at best. I have a 39 oz F-14 with two Microfans using pretty good 6000KV motors, and I'm lucky if I can get 1.5 pounds thrust. Keep in mind that it takes a bit of serious battery to attain this. Having said that, this particular model was never designed for fans to begin with so the ducting is far less than optimal. However, there are scale jets with designed for EDF with scale intakes that can really put out, these using Minifans or Midifans. I have a larger F-14 that will probably weigh in about 7-8 pounds and I have no issue with it being able to easily fly with two minifans.
For duct tubes, people use almost anything from Krispy Kreme box material to heavy paper. Personally, I use drafting mylar. The main concern is that the duct forward of the fan will not collapse and that the exhaust tube will not blow apart...both issues easily dealt with.
Personally, if I were to build a Horton it would be sized, at the very least, to take advantage of the Minifan. With the new motors, batteries, and fans today the limitations of scale intakes are becoming less and less. There are many people on 'the other' forum that are extremely well versed with such matters and I would suggest you try them out to get the information you require. I know that *I* would.
bob
Old 07-08-2006, 12:58 AM   #35
Sky Sharkster
Sky Sharkster's Avatar
View Sky Sharkster's Gallery11
Globetrotter Pilot
Friends: (20)
Default Horten "Wing" Plans
Hi Guys, just thought I'd mention these Horten plans, posted under "Builders Techniques" a couple of months ago. http://www.bellimelgroup.com/products.htm
Don't know if they're of any use to you but worth a look!
Ron
Sky Sharkster is offline
Old 07-25-2006, 04:02 AM   #36
Tempest
So Heiner? Are you holding out on us? I saw a bit of a tease on your He-162 thread
Updates please...
Paul
Tempest is offline
Old 07-25-2006, 04:51 AM   #37
ghethco
We are now looking at using the Wemo mini-fans and upsizing the model (Ho 229) to 1/8 scale (82" span). These fans with the right motors/batteries and a light airframe (no LG, etc.) should be a speedy combination. We have obtained the original Horton airfoil data (all 19 stations!) along with all of the other relevant aerodynamic data, and plan to build a prototype that is precision scale. We *do* expect there to be issues. We plan to fly this second design also as a slope glider first.
Gary
ghethco is offline
Old 07-25-2006, 06:51 AM   #38
Heiner
@ Tempest,
we made a video of the HO-229 V2 last weekend.
www.nurfluegel-modelltechnik.de/download.html
From the Ho-229 V3 soon more. (have to finish the SU-27, when motors will come, finished HE-162 yesterday, some little work left at the SAAB Tunnan....)
Heiner
Heiner is offline
Old 08-02-2006, 01:23 PM   #39
Heiner
Hello,
I received today a lot of drawings from Arthur Bentley from England. They will help to build the next HO-229 V3 scale 1/6 or 1/5.
Heiner
Heiner is offline
Old 08-03-2006, 03:04 AM   #40
bobthenuke
Inveterate Teenager
bobthenuke's Avatar
Ron
Ron,
I emailed the fellow who drew up and sells these plans with a few questions as I intended to purchase a set. He never replied, so I dropped the idea. He has/had a couple of threads on RC Groups forums, but it seemed like he never wanted to answer some direct questions about his planes. They look good, but he doesn't appear to really want to sell the plans, IMHO.
bob
Old 08-03-2006, 06:05 AM   #41
CraigO
CraigO's Avatar
View CraigO's Gallery7
that is odd isnt it. I asked him about purchasing an electronic set over the internet and got a reply from him the next day. I have since bought a copy of his plans forthe 82inch version.
Craig
Go Wallabies Go
CraigO is offline
Old 08-03-2006, 06:53 AM   #42
Heiner
Ok,
to make scale openings for the inlet, here are the original dimensions.
Wing span at HO-229 V3 16,80m = 661.42 inch
Inlet diameter 560 mm = 22.05 inch
I made a mistake, because I scaled up from my DRAGO plastic kit 1/48.
The original inlet diameter of the Jumo003 or BMW004 was 360 or 400 mm, but at the HO-229 they made the inlet wider than the inlet at the jet engine.
HO-229 V3
scale wing span inlet dia
1/10 = 1680 mm 66" 56 mm 2,2" (MINIFAN)
1/6 = 2800 mm 110" 93 mm 3,66" (MIDIFAN)
1/5 = 3360 mm 132" 112 mm 4,4" (120 mm EDF)
Heiner
Heiner is offline
Old 08-03-2006, 07:15 AM   #43
Heiner
photo from my Ho-229 V2
Heiner is offline
Old 08-03-2006, 11:31 AM   #44
Sky Sharkster
Globetrotter Pilot
Friends: (20)
Default No Reply?
Hi Bob, sorry to hear Bellimelgroup didn't respond, I got an answer to questions within a couple of days. Maybe try again?
Ron
Old 08-03-2006, 01:10 PM   #45
bobthenuke
Inveterate Teenager
bobthenuke's Avatar
Craig
Ron<<
That really *is* odd...maybe there's something to that "String" theory and alternate universes.
But, how did you find the plans? My questions to him were directed more towards scale details. I'm still pretty much interested in a minifan sized 229 with retracts.
bob
Old 08-03-2006, 01:36 PM   #46
Heiner
Hello,
I ordered some additional drawings from :
Arthur Bentley has a lot of them, they may help to create a very scale HO-229 V3.
Heiner
Heiner is offline
Old 08-05-2006, 02:42 PM   #47
bobthenuke
Inveterate Teenager
bobthenuke's Avatar
Hello,
Heiner
I can't imagine a more accurate source of information other than having the real thing right in front of you. I tried to get information on the one in the US at the Smithsonian Institute, but apparently it's packed away in some big warehouse (makes me think of the ending scene in the first Indiana Jones movie) and not obtainable by mere mortals. On the other hand, the fellow I spoke to there gave me Bentley's name and recommended his work highly. What's even better about the Bentley drawings is that they can be ordered in different sizes making plans development a lot easier.
bob
Old 08-07-2006, 06:01 AM   #48
CraigO
CraigO's Avatar
thanks bob for the PM excellent info.
have you fellas seen this site http://home.planet.nl/~otten100/ very interesting indeed. this man is also making an 82 inch version. it looks like he has collected quite an array of relevent documentation and has tested a PSS version of the model.
Heiner i am certainly interested in a minfan version. i couldnt afford a midifan setup
cheers
Craig
Go Wallabies Go
CraigO is offline
Old 08-07-2006, 06:24 AM   #49
bobthenuke
Inveterate Teenager
bobthenuke's Avatar
Craig,
I went crazy several months back trying to get some information on that model, since it's about the nicest I've yet to see. I got absolutely nowhere. If anyone can locate the owner and get some information it would be great. As I recall the email adresses given were no longer valid, and attempts to find the original builder or the new owner were fruitless.
bob
Old 08-08-2006, 06:48 AM   #50
Heiner
Bob,
Arthur Bentley made new drawings from many information he could collect during 40 years. He visited the Smithsonian Institute and he has also original Horten production drawings from the German Museum in Munich, the drawings the Americans gave back to Germany after WWII. Arthur Bentley worked for an English airplane company, so you will be surprised what detailed drawings you can order from him!
Heiner
Heiner is offline
Tags
ho229 , horten
Flying Wing Plans-Horten, Northrop Sky Sharkster Scratch and Kit Built Aircraft 10 07-08-2009 02:43 AM
Sold - For Sale - Dragonus II ELITE NV - 229.00 Shipped lbcynya Helicopters- Electric For Sale & WTB 8 04-28-2008 02:38 AM
Wft09----$229,wft08----$169 ELEMODEL Radio Equipment For Sale & WTB 1 04-23-2008 04:48 AM
Hydrogen/fuel cell powered Horten flying wing ron_van_sommeren Power Systems 6 09-29-2006 05:25 PM
Page generated in 0.90062 seconds with 78 queries
