Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > Micro Sized Electric Helicopters > E-Flite Helicopters
Old 10-31-2012, 01:43 AM   #1
d12bn
Default Good flight then my 300 X went down
The flight after this video my motor blew up in flight. That would have made a good video. Lost power and dropped like a brick making a lot of noise. I was doing some tic tocs and I thought the main shaft broke. Took it apart and the bottom motor bearing is gone.
d12bn is offline
Old 10-31-2012, 05:18 PM   #2
rags
Buddy of mine just had similar incident. Motor started screaming (noise) and he started to land. About 2 feet up the motor locked up and it landed a little hard. Stripped main is all the damage. "Opportunity for upgrade".
rags is offline
Old 10-31-2012, 05:51 PM   #3
d12bn
Default Hello
I have a new motor coming from HH but also looking at Scorpions
d12bn is offline
Old 10-31-2012, 07:15 PM   #4
rags
Yea. I think he's going with a Scorpion.
rags is offline
Old 12-18-2012, 05:59 AM   #5
buzzbomber
Matt Smith
buzzbomber's Avatar
View buzzbomber's Gallery11
I know it's been a while but...About how many flights did you have on your 300X before the motor let go? I haven't been keeping track of flights, but mine seems to be holding up so far. I actually did have a mainshaft fail on mine - it was a bit scary because I just spent the battery showing it off with some mild 3D for a few friends and as I was getting ready to set it down, the shaft let go about 4' up and about 10' from me just on the other side of the safety fence. Not a good feeling to lose directional control of a flying cuisinart that close to you......amazingly, nothing else, not even the main blades, was damaged since I got it down pretty level in the tall weeds.
Matt
Down with Gravity!
buzzbomber is offline
Old 12-18-2012, 01:23 PM   #6
d12bn
Default Hello
I had around 50 flights when the motor went
d12bn is offline
Everything You Wanted To Know About Electric Powered Flight AEAJR General Electric Discussions 256 06-14-2013 04:38 PM
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 147 05-29-2013 09:32 AM
Extreme Flight Extra 300 EXP__Clean Sheet Doc Austin 3D Flying 5 01-05-2013 03:19 AM
Extreme Flight 48" MXS__Something Completely Different Doc Austin 3D Flying 2 11-27-2011 07:03 AM
Checking CG in flight? DanWard 3D Flying 14 04-15-2011 12:41 PM
Page generated in 0.28073 seconds with 30 queries
