Old 11-01-2012, 06:25 PM   #1
CNY_Dave
Default Need Info on Turnigy SK5055-580 Aerodrive XP
I have a Turnigy SK5055-580 Aerodrive XP (580KV), and am looking for what size the bearings are, and if anyone knows what bolt-on prop adapter I can pick up as a spare.
(so far mine does not seem to be having magnets come loose or having the bell slide out of position)
This motor has been superseded twice, first by the 50-55B-600kv (which aside from color looked the same), and now by the L5055B-600, which looks a bit different in construction but still quite similar.
BOCA shows a similar motor (50-55a 400kv) as taking two of the 8 x 12 x 3.5mm bearing.
CNY_Dave is offline
Old 11-02-2012, 08:11 PM   #2
Dr Kiwi
Outstanding Contributor Award
Get the original bearings out... and measure them?
Dr Kiwi is offline
Old 11-02-2012, 08:25 PM   #3
CNY_Dave
As a last resort, sure, but I want to avoid the down-time.
Also, I'd like to avoid purchasing multiple replacement bolt-on prop adapters just to find which one fits.
I think it is absolutely absurd hobbyking can not tell me what size bearings are in it.
This motor has an 8mm shaft, HK customer service sent me a link to a 6mm collet and a set of 6mm bearings...
CNY_Dave is offline
Old 11-27-2012, 05:08 PM   #4
renwick56
These will fit. I have them in mine:
http://www.bocabearings.com/bearing-...0-65-sk-380-kv
renwick56 is offline
Old 11-27-2012, 05:17 PM   #5
CNY_Dave
Awesome, thanks.
Kit shows
(2x) ID 8mm x OD 12mm x Width 3.5mm
(1x) ID 8mm x OD 16mm x Width 5mm
I have received but not tried on a bolt-on prop adapter that looks exactly the same as the original, I'll post up if I ever get around to trying it.
http://www.headsuprc.com/servlet/the...Adapter/Detail
CNY_Dave is offline
Help needed: Housing stuck on Turnigy SK 5055-580 steinar Brushless Motor Construction 17 09-23-2011 06:21 PM
Page generated in 0.20015 seconds with 27 queries
