Old 11-13-2012, 04:23 AM   #1
Default Hobby King motor to replace 61 glow ...
OK ... here's a question ...
I have a biplane of 56" wingspan, about 7lbs ... (1.4m x 3.2kgs)
Designed for straight 61 Glow and 12x7 ... 13x7 prop ... I use it on a RCGF 15CC gasoline ... yes it's overpowered.
But I am thinking to use the RCGF on another model and want to convert the biplane to electric.
I want plenty of power ... plenty of oomph so she climbs reasonably vertical but not necessary unlimited ...
I have to ask that suggested motors be based primarily on Hobby King or secondary on Hacker equivalents - as I am not able to buy from USA outlets ... Budget of course - as I'm a cheapskate !!
Here's the baby in her gasoline 'mode' ....
Over to you guys ....
Old 11-13-2012, 05:37 AM   #2
Nitro Blast
Nitro Blast's Avatar
View Nitro Blast's Gallery38
100mph Speed Demon  3kW  1kW  WAA-08 Pilot
Friends: (65)
Check these:
Turnigy Aerodrive SK3 - 4250-410kv Brushless Outrunner Motor
Hobbyking 70amp OPTO ESC with 5 Amp External UBEC
Run that on 5 cells and you'll be able to really spin a deep prop like a 13x10, and you arent stressing the setup.
You could start with 4000 mAh 5 Cells and try to get that to balance, and get a decent 7~10 minute flight.
Of course, every setup should be watt meter verified.
Nitro Blast is online now
Old 11-15-2012, 01:54 PM   #3
Cheers ... I looked at the SK3 series ... but various comments talk about magnets breaking loose etc.
I note you pick the lower KV motor instead of the higher ... and of course needs the 5S ...
Would you think a higher KV on a 4S ?
Old 11-15-2012, 08:04 PM   #4
Dr Kiwi
Any combo can be made to work, but lower voltage means higher current draw... which means lower flight time [and because of I^R, more waste heat to be dissipated].
Cheers, Phil
Dr Kiwi is offline
Old 11-15-2012, 09:00 PM   #5
Friends: (16)
If you want power, something on the order of a $$$$ Hacker A50-12S, 5S LiPo, and a 15X10 APC-E prop will do pretty good. I've got two of them on 8 pound airplanes, running on 6S2P A123 battery packs. That power system hauls the 8 pound models straight up out of sight. These Hacker motors are available in a number of different KV's (different windings) for the same motor frame, to match what you need for your model. The www.motocalc.com computer program is fairly accurate on predicting how the Hacker motors/props/battery packs will perform.
Or a little less power, the Hacker A40-10L motor.
Going to a lighter LiPo 4000 Mah or so battery would perform even better.
(Also have an A30, two A40's one more A50 and two A60's. All have performed well, easily matching their specifications over the past several years. Just had a steel shaft set screw issue last summer on the A60-16M motor after 160 flights. That's it. No I don't work for Hacker, wish I did!)
http://www.aero-model.com/Hacker-Bru...By-Series.aspx
Hobby King jchtr3a Company Discussions 13 08-10-2012 10:27 PM
BD-5B Comparison of Aeroworks Vs. Hobby King kits frenchstan Pusher Park Jets 0 01-30-2012 04:11 AM
hobby king hangingon Company Discussions 43 01-25-2012 02:44 AM
Sci-Fi channel ad... Hobby King! Nitro Blast Company Discussions 5 11-11-2011 05:47 PM
Hobby King USA Ware house Planes list! tallflyer Company Discussions 3 04-12-2011 01:10 AM
Page generated in 0.21812 seconds with 27 queries
