Old 11-14-2012, 01:58 AM   #1
earthsciteach
Default FPV Flying Wing
I've been slowly working on a flying wing for a couple of friends. The wing is nearly complete, save for installation of electronics, a bit of fairing work, and a paint job. It is made of foam insulation board and very lightweight fiberglass wetted with Minwax Polycrylic.
Here is a link to the build:
http://forum.flitetest.com/showthrea...wing-build-log
earthsciteach is offline
Old 11-14-2012, 02:07 AM   #2
View mclarkson's Gallery26
Friends: (8)
Best of luck with the project. Keep us up to date.
Old 11-14-2012, 10:01 PM   #3
riverrat
circa: 1946
riverrat's Avatar
Club: NRA Life Member
Friends: (30)
Default MWWBPC?
Teach
I take it the PC you used was water based?
How did it work for you?
How does it compare in strengh vs. epoxy?
Thanks in advance!
Regards
Jimmy
riverrat is offline
Old 11-14-2012, 10:50 PM   #4
earthsciteach
I used Minwax Polycrylic. It seems to work just fine. The glass is extremely thin, so it probably doesn't contribute all that much in terms of strength. If I were to use a heavier cloth, I'd probably use epoxy. But, I'm really happy with the Polycrylic in terms of surface finish and protection from dings and dents.
Old 11-14-2012, 10:58 PM   #5
riverrat
circa: 1946
riverrat's Avatar
Friends: (30)
Default MWWBPC
I think I will try it.
I have MinWax water based Polycrylic
in a qt. can & a rattle can.
Jimmy
riverrat is offline
The Extreme Flight Edge 540T-EXP ARF-48 x-nitro 3D Flying 16 02-25-2016 02:58 PM
Dart Fishbonez Foamies 189 07-22-2012 07:04 AM
Choosing a Sailplane Radio - What to Consider AEAJR Hi-Performance and Sailplanes 3 04-09-2012 12:57 PM
lightest wing loading ARF biplane 4 ch wattman WWI Era 1 11-09-2011 09:49 PM
Crazy idea? WayneG Hi-Performance and Sailplanes 21 05-29-2011 08:37 PM
Page generated in 0.07845 seconds with 27 queries
