Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Warbird Electrics
Old 11-19-2012, 03:22 AM   #1
mikie
Default motor or esc problem???
New to electric ihave a pz f4u got about 10 flites on it but last one it was running great then it just quit ? i advance the throttle and motor just jetters??
newbe
mikie is offline
Old 11-19-2012, 03:38 AM   #2
stuart
stuart's Avatar
Outstanding Contributor Award
Friends: (12)
start search with the 3 wires from esc to motor...sounds like a loose connection. one more thing........welcome to wattflyer mike. this is a a hobby of many things that can go wrong and probably will. my tranmitter of 4 years just went on the fritz today pretty much squashing any flying till my new module arrives from hk[china]. it's the first time i'v ever paid for "ems" shipping....thats how much i want to get back to flying...lol.
stuart is offline
Old 11-19-2012, 05:15 AM   #3
Love my Super Cub
Fishbonez's Avatar
Send a message via AIM to Fishbonez Send a message via Yahoo to Fishbonez
Friends: (15)
Agreed with the above post.
Check to make sure solder connections are good. Even the slightest fraye is enough to cause that problem
Happy flying may your crashes be limited and if they are not limited let them be cool.
Fishbonez is offline
Old 11-19-2012, 10:21 AM   #4
View CHELLIE's Gallery13
Friends: (281)
disconnect the 3 wires from the motor and esc, use a volt ohm meter and check for equal continuity on the motors 3 wires, testing 2 wires at a time, there should not be any continuity from the motor wires to the motor metal case, pull on all the connectors on the esc and motor, sometimes a wire will break inside the plastic wire covering at the connectors, hope that helps, Chellie
you can get a cheapy volt ohm meter at Harbor freight tools for about $5.00 if your in the USA
Old 11-19-2012, 02:18 PM   #5
mikie
Thanks for the info loose connection works great now. I can see I got alot to learn great site
mikie is offline
Old 11-20-2012, 04:21 AM   #6
Love my Super Cub
Fishbonez's Avatar
Friends: (15)
Glad you were able to find the problem. I beleive we all have alot to learn that is what makes the forumns so great. Just a mass welth of knowledge in one itty bitty box :-)
Problem with either LiPo's, ESC's, or BL motors... RC Fan Chris General Electric Discussions 14 06-13-2012 02:41 PM
HELP!!! RX problem!! wittpilot General Electric Discussions 13 10-11-2011 06:19 AM
Glitch / lock out problem!!!! Gee Power Systems 20 04-14-2011 03:29 AM
Unpossible servo problem mclarkson RC Radios, Transmitters, Receivers, Servos, gyros 13 02-13-2011 12:45 PM
Page generated in 0.17200 seconds with 29 queries
