Old 11-20-2012, 12:06 PM   #1
DCDetector
DCDetector's Avatar
View DCDetector's Gallery25
Default E-Flite Sbach 342 UMX battery
I just bought a Spektrum DX7s a E-Flite UMX Sbach 342 3D BNF Basic(EFLU4950) and E-Flite EFLB1802S20 2S 7.4V 180mAh 20C Lithium Polymer Battery. My question is will this battery come with the proper connector to connect it to the Sbach, or do I also need to purchase a connector? I understand I will need an adapter for the charger?
Probably needs to be moved to the battery / charger area. Sorry.
DCDetector is offline
Old 11-20-2012, 05:22 PM   #2
hoghead5150
yeah you will need an adapter. the plug on the battery isn't a "normal" balance plug. instead of having 2 locating tabs (one on each end of the top) it has one tab on the top in the middle.
if you need more batteries, might check out the G-Force batteries from valuehobby.com you can order them with the correct connector and they are like $3 each!!
hoghead5150 is offline
Old 11-27-2012, 06:14 PM   #3
dumo01
dumo01
dumo01's Avatar
Club: Westerville Model Aeronautics Assc
Friends: (7)
This is the adapter for the charger, there is also a similar one that uses the Thunder Power balance board.
http://www.horizonhobby.com/products...-efl-EFLA700UM
Great little airplane, I am using the 200 maH battery that is marketed for the mini Stryker and MIG 15. Gives you a few more maH, but is also a 25C rated battery instead of the 20 c for the 180maH
dumo01 is offline
Old 11-28-2012, 01:39 AM   #4
rags
Great choices - you will have a lot if fun with these. Just as a thought - what I did was change out the stock connector in the plane with a JST plug. This allows the use of batteries with the JST and the balance tap. I've also noticed that a lot of the batteries with the OEM connector are a little more expensive. Plus you can not monitor the cell balance with the OEM connector. I did this on my Sbach - Beast 3D - and my 130X.
rags is offline
Which of these 2 radios for a E-Flite Sbach 342 umx as3x? DCDetector General Electric Discussions 6 12-04-2012 11:38 AM
3 cell Lipo Batteries- Bang for the Buck dahawk General Electric Discussions 30 03-11-2012 01:40 AM
UMX Sbach 342 Aaeolien Indoor & Micro Electric Planes 2 08-28-2011 05:58 PM
UMX Sbach 342 BNF kenchiroalpha Indoor & Micro Electric Planes 1 04-30-2011 08:35 PM
Page generated in 0.19856 seconds with 25 queries
