Old 11-26-2012, 08:02 AM   #1
View CHELLIE's Gallery13
Friends: (281)
Default Beginner Scratch Building Tips
Hi Everyone This Thread is for the Beginner Builder to Learning Different Types of Ways to Build your scratch Built Planes, Please add any info that you Know to help others with their build, Thank You, Chellie
Info From Youtube
Old 11-26-2012, 08:03 AM   #2
Friends: (281)
Old 11-26-2012, 08:05 AM   #3
Friends: (281)
http://www.wattflyer.com/forums/showthread.php?t=16392
http://www.rcplanetalk.com/trim.html
http://www.wattflyer.com/forums/showthread.php?t=39483
Old 11-26-2012, 07:27 PM   #4
Friends: (281)
http://www.wattflyer.com/forums/showthread.php?t=39733
http://www.wattflyer.com/forums/show...ht=coke+bottle
http://www.wattflyer.com/forums/showthread.php?t=39138
Old 12-13-2012, 06:30 PM   #5
road king 97
old hat
road king 97's Avatar
Club: joliet rc club rt 66
Friends: (13)
All right CHELLIE i will show how iam building a full airfoil wing,its like the video above but i use real ribs so i can make different airfoils and a balsa spar to make it stronger. You can see my ribs and the two pieces of foam that makes my slot for the main spar .This is one half of my wing and the main spar runs all the way through with no breaks in it. The wing is 38 inches long so i only had 36 inch spar but i fill in the end piece with foam glue to the end of my spar. You cut a groove on the inside at the front of the ribs and then tape it on the outside so it wont break when you bend the top sheating down.I roll both side over a 2 inch or any other small pipe to get it close to shape .I sanded the front and back edge about 7/8 strip so when they are folded over and pushed together it ends up at around 6 mm thick for a 6 mm ail. at the trailing edge. BTW i space the ribs about 3 or 4 inches apart. I then use elmers rubber cement around the outside edges and ribs plus the top piece where the top of the ribs will hit when i fold it. I glue in my main balsa spar and use rubber cement on top of it too plus the foam strips on each side of it. After the cement is almost dry i fold the top half over to make a nice airfoil and very light but strong wing. This wing is for a canard stick i shrunk plans down from a balsa one and i want to make a 50 inch one soon and draw plans to give out free on wattflyers soon. I hope this makes sence because i build better than explain things lol I want to thank CHELLIE for talking me into trying to build with foam a year ago ,iam still learning but its just as fun as building with balsa and much faster. joe
Name:	airfoil wing 3.jpg
Name:	taped together for a picture.jpg
Name:	canard stick.jpg
road king 97 is offline
Old 12-13-2012, 08:21 PM   #6
dheaton
Those are some good videos Chellie. Thanks for sharing them.
Info From Youtube
dheaton is offline
Old 12-13-2012, 11:12 PM   #7
Friends: (281)
Good Looking Wing Joe yea, I love building with foam, its fast and fun, if you want to build a super clean plane then use Balsa, but for all around fun flying, I use Foam, Take care and have fun, Chellie
Old 12-13-2012, 11:14 PM   #8
Friends: (281)
Hi I have Learned a Lot from the Youtube videos, they can be very informative, and when i see one that is super good, I like to share it with others, Take care and have fun, Chellie
Old 12-13-2012, 11:23 PM   #9
road king 97
old hat
Friends: (13)
You cant get any funnyer than this CHELLIE lmao joe
Name:	slowly 5 mine.jpg
Old 12-13-2012, 11:27 PM   #10
Friends: (281)
Thats A Cute fun flier
Old 12-14-2012, 03:03 AM   #11
Friends: (281)
Thumbs up Trimming Your Bird
http://www.scootworks.com/rdrc/trim.html
Model Airplane Building Clinic >> Begins 29 Sep. All Skill Levels Welcomed Murocflyer General Electric Discussions 282 11-04-2012 10:35 AM
#27 Model Airplane Building Clinic >> Mimi DLG 1 meter polyhedral<< aeroknot Hi-Performance and Sailplanes 94 10-23-2012 12:59 AM
Model Airplane Building Clinic - - Instructors Needed Murocflyer ParkFlyers 9 09-21-2012 01:55 AM
Charlatan - a balsa scratch build pylon racer Sunstorm Scratch and Kit Built Aircraft 3 11-02-2011 12:13 PM
Its On, Start Building, 100 Mph Under $100.00 Foamie Contest CHELLIE Scratch and Kit Built Aircraft 151 09-12-2011 06:14 AM
Page generated in 0.73534 seconds with 51 queries
