Old 11-26-2012, 03:30 PM   #1
newjak
AMA Park Pilot Partner
newjak's Avatar
Club: Central Delaware Parkflyers Association
1kW
Friends: (13)
Default Gorilla glue overspill-what to do?
I got a little over zealous with the gorrilla glue when repairing my Skytrainer. The glue worked its way into my steerable nosegear locking it into position. I am looking for some way to remove or loosen the glue without damaging my nose gear. Any help would be appreciated.
A.M.A Park Pilot Partner / Wattflyer Mentor
newjak is offline
Old 11-26-2012, 04:25 PM   #2
Rodneh
I'm afraid that any thing that would dissolve the Gorilla glue will also dissolve any other plastic or foam structure in the vicinity. About the only solution is to mechanically clean it out with tweezers, forceps, knives or whatever. If it is possible to completely remove the nose gear assembly, then you could immerse it in acetone (or maybe gasoline as that will dissolve some foams) to remove the bulk of the glue. However, you will still wind up with a sticky film on the remaining parts that will have to be laboriously scrubbed off.
Rodneh is offline
Old 11-26-2012, 05:02 PM   #3
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
As far as I know nothing but force removes dry Gorilla Glue.
fly
flydiver is online now
Old 11-26-2012, 07:30 PM   #4
View CHELLIE's Gallery13
Friends: (281)
Remove the landing gear and wheel, and use a propane torch to burn away the glue, FIRE GOOD Ok Just Kidding
try using a soldering iron to heat up the old glue with to get it soft and remove it when it gets hot and soft.
Old 11-26-2012, 08:20 PM   #5
Rockin Robbins
Rockin Robbins's Avatar
Friends: (7)
Is this where I pop in and recommend explosives?
Rockin Robbins is offline
Old 11-26-2012, 09:22 PM   #6
dgjessing
I like this idea...
Dave
AMA #56519
dgjessing is offline
Old 11-26-2012, 10:04 PM   #7
Beemerider
Beemerider's Avatar
Club: Augusta County RC Club
Make it a taildragger...............
Beemerider is offline
Old 11-26-2012, 10:54 PM   #8
newjak
newjak's Avatar
1kW
Friends: (13)
Problem solved! I used my heat gun to soften it up a bit. Then used a hobby knife to cut a scrape away enough glue to free the mechanism. Thanks for the suggestions. Except the one about explosives
newjak is offline
Old 11-26-2012, 11:18 PM   #9
rags
Thanks for letting us know what worked - learn something every day. --- lol
rags is offline
Old 11-27-2012, 12:38 AM   #10
Augermeister
View dahawk's Gallery6
Club: 114th RC Aero Squadron
Friends: (13)
The foam-up Gorilla is a PINA Spilled some on my tires and it's a bear to get off.
I prefer Beacons Foam Tac and/ or 5 min epoxy for most things. For foamie profiles I use hot glue and to repair detached ailerons I use welders.
Throw the Gorilla in the bin !
" Something Ain't Right ! "
Capricorn - the ultimate flying boat. Larry3215 Foamies 2720 05-15-2013 07:17 AM
Carving and finishing "Blue" foam payne9999 Scratch and Kit Built Aircraft 34 11-26-2011 02:52 PM
Hot Glue? Wrongway-Feldman Foamies 30 08-27-2011 01:28 AM
Glue question for a Quique Somenzini e-Yak 54 Mysterious 3D Flying 5 08-03-2011 12:50 PM
CA Glue - 3DHS ARF assembly DanWard Beginners 12 01-03-2011 10:43 PM
Page generated in 0.30003 seconds with 40 queries
