Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Company Support Forums > FMA Direct
Old 12-01-2012, 03:12 PM   #1
kittiwat1
Default Battery capcity and Cellpro Powerlab 8 V2
Can I charge different Lipo battery capacity with the same cell count on PL 8? Thanks for your advise.
kittiwat1 is offline
Old 12-01-2012, 03:59 PM   #2
Nitro Blast
Nitro Blast's Avatar
View Nitro Blast's Gallery38
100mph Speed Demon  3kW  1kW  WAA-08 Pilot
Friends: (65)
Yup..
(1s to 8s balanced, 1s to 2s unbalanced), Lithium Ion (1s to 8s balanced, 1s to 2s unbalanced), Lithium Manganese (1s to 8s balanced, 1s to 2s unbalanced), A123 (LiFePO4) (1s to 8s balanced, 1s to 10s unbalanced), NiCd (1s to 21s), NiMH (1s to 21s), 6v, 12v, 24v Lead Acid batteries (Flooded, Gel) Adjustable range 10mA to 40A, limited by 60A input current*
Nitro Blast is offline
Old 12-01-2012, 08:31 PM   #3
Tim Marks
President FMA, Inc.
Hi:
Yes, when charging LiPo in parallel, you may have different capacity batteries, but you MUST maintain the same cell count.
When setting charge rate, set it based on the pack with the lowest capacity; e.g., if you wish to charge 3300 and 2200 mAh at the same time, and you are shooting for 2C charge rate, tell the PL8 you are not charging in parallel, and set the rate manually at 4.4A.
Tim Marks
Tim Marks is offline
Page generated in 0.15688 seconds with 22 queries
