Old 12-02-2012, 11:18 PM   #1
DCDetector
DCDetector's Avatar
View DCDetector's Gallery25
Default Does this EXPO setting look right?
I'm having trouble adapting to how sensitive my E-Flite UMX Sbach 342 is to stick commands especially on ailerons. Being so small I find myself overreacting on banking. I want to mellow out the stick control so that it is less touchy at the start of the stick movement but still has full throw. Does this EXPO setting look right for what I'm try to accomplish? Would I be better of just reducing the throw?
DCDetector is offline
Old 12-02-2012, 11:23 PM   #2
Friends: (16)
There is positive and negative expo. One makes the control VERY sensitive around neutral, something you don't want. The other makes the control less sensitive around neutral. Visually double check your aileron throw my moving the transmitter stick to make certain of which type you have. It should be obvious.
I've been using about 35% expo on all of my models, a value that has worked out well for me. Each person is different, so try different values.
As for dual rates, they do work and work well, but as for me, I've just selected expo functions, and don't use dual rates (or triple rates in my Spektrum DX8 transmitter.)
Today, I put my 4 year old electric Showtime 50 in the air, and found it very sensitive in aileron and elevator functions. It was the first flight with the Spektrum DX8 transmitter. Quickly landed it, and noted that expo had not been set up. Put in that 35% on both aileron and elevators, and made it much nicer to fly.
kyleservicetech is online now
Old 12-02-2012, 11:39 PM   #3
slipstick
On JR/Spektrum POSITIVE expo values make the control less sensitive round the control's centre.
On Futaba you need NEGATIVE expo values for the same thing.
If that's a Spektrum DX7S I'd guess you've made it much MORE sensitive not LESS. Probably not what you intended .
slipstick is online now
Old 12-02-2012, 11:39 PM   #4
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
NO!!!! That is not right. You want positive values on Spektrum systems. So you are just backwards - yours will be MORE sensitive around neutral, not less.
Old 12-02-2012, 11:45 PM   #5
Friends: (16)
Yup
That's why I indicated move your transmitter stick and watch the ailerons/rudder/elevator.
For some reason, the various RC radio suppliers define positive and negative expo differently.
As for my DX8, it does take a positive number for the proper expo commands. Tried it with negative expo, boy does that respond weirdly.
Old 12-02-2012, 11:52 PM   #6
WAA-08 Pilot
Friends: (9)
Yup
Sometimes watching the surface or servo isn't as easy as looking at the graph. I really like the graph at it clearly shows more control around center.
Old 12-03-2012, 02:48 AM   #7
Friends: (16)
Graph is good, but what do you do when some transmitter brands show the expo curves reversed from other brands? One way to really make certain you've got the expo correct is to program 95% expo. That really shows how it works. (And NO, don't try to fly a model with that much expo.)
Old 12-03-2012, 10:05 AM   #8
DCDetector
DCDetector's Avatar
Thanks! That is why I asked.
Does this look better?
Old 12-03-2012, 04:00 PM   #9
WAA-08 Pilot
Friends: (9)
That's what you want!
The curve helps to imagine what is going on. You see how not much happens at first then it jumps up later.
50% is a LOT of expo - I do go that high on very responsive fast airplanes but normal ranges are around 20-35%.
Old 12-03-2012, 05:08 PM   #10
stevecooper
stevecooper's Avatar
View stevecooper's Gallery86
Club: Mullet Mauroders
Friends: (86)
I fly all my planes with-out expo or mixing, They say you need it on my Extra and 4-SITE 3/D planes right on the Box, but never using all the new bells and whistles , I've flown Friends planes with Expo but it doesn't "feel right",,fly'in my thumbs for 40+ years and can't get used to "moves a little-then a lot", expo throws me off, I fly 3/D smack-downs at fly-ins and always hold my own with the "Big-Shots" out there,, I think Expos great for most, but not for all,, just two cents worth, Bubsteve
Monkey Minion'air
stevecooper is offline
Old 12-03-2012, 05:14 PM   #11
WAA-08 Pilot
Friends: (9)
Hats off if you fly 3D with no Expo WOW!
But I have several planes with none - I get it. I have one I don't think I could manage with out Expo.
Old 12-03-2012, 05:40 PM   #12
DCDetector
DCDetector's Avatar
My problem is I'm used to flying my big planes where reaction between stick movement and plane are not so... instant. Plus my bigger planes are more along the scale/trainer line so the very design makes them more docile. I've noticed even on my UM cub and UM Ares trainer 100 they are much harder to fly than my biggies because of being very responsive/reactive. The UMX Sbach is more a goes-where-you-point type plane. I like flying low and close which takes a lot faster response with less room for error. If I get too far away my orientation get bad.
Old 12-03-2012, 08:49 PM   #13
stevecooper
Friends: (86)
I've flown the The UMX Sbach with-out Expo, ( I'd forgot) she's a hand-full with roll-rates like a drill-bit , I flew her on full rates to start with then switched to low, fun plane, bubsteve
ID:	164611 Here's a little-one I flew at SEFF last-year HaHaa!
Monkey Minion'air
Old 12-03-2012, 10:16 PM   #14
Friends: (16)
Yeah, I had one of those, gave it to my son. You are right, the roll rates are so fast it's difficult to stop the model right side up. Setting up expo on that Sbach made a real difference.
That was a fun fun model though, my son busted it up after a few dozen flights.
Getting Back Into It wolfewinde General Electric Discussions 209 12-02-2011 11:26 PM
Looking for suggestions on values for dual rate and expo RightFly RC Radios, Transmitters, Receivers, Servos, gyros 2 08-30-2011 05:43 PM
Turnigy Plush 10A ESC - throttle setting problem mclarkson Power Systems 5 08-22-2011 10:30 AM
expo??? chadwy Beginners 22 05-26-2011 12:38 AM
Charging Lipo with Lilo setting? Epowerreg Batteries & Chargers 14 04-09-2011 04:37 PM
Page generated in 0.58319 seconds with 51 queries
