Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Delta & Flying Wings
Old 12-04-2012, 06:13 PM   #1
TargetAH
Default LED Lights for MS Composit Swift II
Want to add LED lights. What is best set up?
TargetAH is offline
Old 12-04-2012, 09:54 PM   #2
Bub Steve
Bub Steve's Avatar
View Bub Steve's Gallery86
Club: Mullet Mauroders
Friends: (89)
1'st get a UBEC to handle the power for them and servos as the ESC won't have enough amps, Get the 3m color strips and white strips, my color ones are 12V and the white 4-5V, hookup the white ones to the RX and the color ones to to a "Y" adpt from the 3-cell lipo give them 12V, (RX puts out 4-5V plug into any extra ch)
This is what I fly on mine (4-years old now), there maybe Newer set-ups but mines simple an sweet The black thing on tops a 5 LED flashing Cap0lite,, Fun stuff, bubsteve
ID:	164632   Click image for larger version
Monkey Minion'air
Bub Steve is offline
Old 12-05-2012, 01:55 PM   #3
r_kopka
Electric Only
r_kopka's Avatar
2kW  1kW  Globetrotter Pilot
I haven't found any strips NOT for 12V !? As said an adaptor between the battery and the ESC is fine. That way you can also fly without light and test the light without motor.
Color strips are fine but for the beginning even a few leds at the wing tips, the middle and at least one pointing back are enough.
RK
r_kopka is offline
Old 12-05-2012, 06:59 PM   #4
soarrich
Soarrich
soarrich's Avatar
Club: JCSF & MMAC
I have a Popwing and put leds from Hobbyking on it. Vid from my sister-in-law's iPhone:
I just plugged the power leads into the balancing plug on the battery.
soarrich is offline
Old 12-05-2012, 10:40 PM   #5
Bub Steve
Bub Steve's Avatar
Friends: (89)
My white led's from HK are 5V, I also have blinkers and strobs that need 15 Ohm resisters in line , the blinkers are 3V and have Adpts,, I just gave him the simple set-up, Look on HK website at the white 5V ones,, they are there
bubsteve
Monkey Minion'air
Old 01-26-2013, 09:54 PM   #6
crash_out
Misanthropic Member
crash_out's Avatar
View crash_out's Gallery2
Club: No club, I'm a renegade!!!
Send a message via MSN to crash_out Send a message via Yahoo to crash_out
2kW  WAA-08 Pilot  1kW
Friends: (7)
I have a set of 3.3volt ones from HK-they are bright, but only have 1 light every 3 inches on the strip. They also reuire you to use the voltage regulator to give them the 3.3volts they need.
I just bought nearly 100 feet of various colors froma vendor on Amazon. They are 12 volt, already have the current limiters attached, and have 3 LED's every couple of inches. They are almost as bright as the HK ones, and have 3m tape on the back side for attachment.
They will run off a typical 3s flight battery, but as the voltage goes down they will dim slightly. They are advertised to comsume around 1.75 amps for every 5 meters. If you have room and ability to carry the extra weight, I'd power them by their own small battery.
http://www.amazon.com/Flexible-Strip...ed+light+strip
In theory you can get any LED lights or strips and use them. The key things to look for is their operating voltage, and that they come with current limiters.
-nick
TANSTAAFL!
crash_out is offline
Swift II Nightflyer Davethebluessinger Night Flying 3 06-22-2017 09:53 PM
Led lights for Mcfoamy Dean in Milwaukee 3D Flying 5 02-29-2012 10:20 AM
MS Swift II Cof G way off! Davethebluessinger Delta & Flying Wings 19 06-24-2011 01:23 PM
Prop for MS Composit Swift II and MS Mini Swift Davethebluessinger Delta & Flying Wings 12 05-23-2011 01:05 PM
HZ Super Cub and LED lights - help needed. bcmedic16 Power Systems 9 02-04-2011 09:54 PM
Page generated in 0.32569 seconds with 35 queries
