Old 12-12-2012, 11:49 PM   #1
videorov
Default How can I check to see if Brushed motor is dead
I changed out the controller and still nothing from motor. All other controls work just no motor.
Is there a way to check the Brushed motor to see if it went bad. Its a Sky Surfer by Blitz with the standard Brushed motor it
came with. Who makes a replacement Brushed motor for it. Looks like I will have to replace it.
I have brushed controller so want to stay with brushed motor.
videorov is offline
Old 12-13-2012, 12:34 AM   #2
Do you know what voltage, or how many cells that motor is rated for?
For a brushed motor (NOT a brushless motor!!!!) all it takes is to disconnect the ESC controller from the motor, and connect the motor to a battery with a couple of Radio Shack jumper wires. Something like 6 Volts DC should do it.
If that motor does not turn over with the direct connection of that battery, its not a good sign.
At any rate, some of those inexpensive import brushless motors and their inexpensive ESC's are worth considering. They will have twice the horsepower, and will run on the same, or even less energy requirements out of your battery.
Old 12-13-2012, 12:38 AM   #3
Friends: (22)
wow,joined in 2008 and up to 7 posts.....lol....make m want to welcome you back.[jk]
if you toasted the brushed motor it would give off a burnt smell,if it's shorted by some other means or if you esc isn't controlling the motor but is working the other controls you may need to replace them.
banana hobby sells the skysurfer and under part the motor is in stock for $8 thats a inexpensive step toward fixing her up,the brushed esc is also in stock for $10. thats mighty affordable for a plane that sells for $139.
before you do anything you should check your receiver and make sure the connections there thru to the esc and motor wires are in good shape. sound like a disconnect somewhere.
hope this encourages you to fix your skysurfer and have many great flights with it. by the way....looks like the skysurfer would make a great fpv plane.
Sky Surfer V4 RC Trainer Airplane RTF - Radio Controlled Sky ...
Sky Surfer V4 RC Trainer Airplane RTF from BananaHobby.com. Shop our selection of RC Airplanes to find your RC Flight ... Banana Hobby is not responsible for ...
www.bananahobby.com/sky-surfer-v4-rc-​trainer-airplane... - Cached
Old 12-13-2012, 04:34 AM   #4
videorov
Default Brushed motor checking
Thanks guys for all the help. I will do all that was said and also order
new if I need to for place listed.
videorov is offline
Old 12-13-2012, 02:56 PM   #5
Bub Steve
Bub Steve's Avatar
View Bub Steve's Gallery86
Club: Mullet Mauroders
Friends: (89)
I'm in N. Fl, I've been watching your thread here, I have Buckets full of brushed motors,, ( many new as I put Brush-less on and put the motors that came with the planes in the Bucket), 350's 400's and 450 size, There free for you as a Wattflyer Friend, PM me and let me know what you need,, Bubsteve
ID:	164840   Click image for larger version
Monkey Minion'air
Bub Steve is offline
Something else to check, your bec! Glacier Girl General Electric Discussions 6 03-11-2012 01:26 AM
Dead Duck. . . . . Don Sims Humor 7 12-10-2011 12:17 AM
Kyosho 480-540 brushed can motor question Bomb Dropper Power Systems 7 06-03-2011 07:21 PM
Quick question(s) - Brushed ESC mclarkson Power Systems 11 05-18-2011 10:00 PM
your Duck is dead gramps2361 Humor 1 01-11-2011 04:22 AM
Page generated in 0.25681 seconds with 31 queries
