#1 | ||
2. Reasonable charger that covers most packs you'd use plus balance charging / assessment. 3. Servo Tester unit - a standalone unit that servos can be plugged intyo to centre or test for full arc swing etc. 4. 4.8v NiMH small flight pack or BEC unit that can supply the 4.8V to the servo tester 3. These in my den are invaluable tools when setting up the model / general use. Why did I add the servo tester and 4.8v pack ? When building or first setting up a model - the servo tester and 4.8v pack are one of the best tools going. No need to fire up Tx / Rx ... no need for any actual radio gear other than the servos in place. Plug them in ... set tester to CENTRE ... that now gives you servos ready to position arms and set-up rod lengths etc. The cost being generally under $10 ... is a bargain IMHO. The Wattmeter and Chargers have had numerous threads about those .. so will not repeat here. Nigel |
#2 | ||
old hat
Club: joliet rc club rt 66
Friends: (13)
Nigel i dont have any of those but i need to get them ,at one time i thought i would never fly electrcict planes as much and my nitro or gas planes but things have changed and i need to change to. Thanks for the reminder .
joe
#3 | ||
Love my Super Cub
Friends: (15)
Good advice as always Nigel.
Happy flying may your crashes be limited and if they are not limited let them be cool.
#4 | ||
Originally Posted by road king 97
The servo tester doesn't care about whether gas or lecky !!
![]() You're lucky - like me you will have NiMH flight packs knocking around from gas planes to use ... Mine are a collection of home-made 4 cell 2300mAh NiMH in holders taped secure and wired up with servo lead, JR proprietary packs ... First thing I do when I open a new delivery that incl's servos - put them on tester and cycle them for a few minutes ... just to make sure. You know you can also use a Tester with your ESC to control a motor ? That was a surprise to me .. Nigel Nigel |
#5 | ||
#6 | ||
old hat
Friends: (13)
I will order the watt meter soon and i do have batterys laying around . I have battery testers and such but need to buy the right stuff now that i know iam going to fly more and more e stuff. I have been flying for 30 years and never had a servo go bad . I have all hightek servos and they have worked flawless for me but i should test them too. joe
#7 | ||
Why is it easier to use a servo tester then transmitter?
#8 | ||
Servo tester does not need anything except 4.8v power. No Rx, No Tx, ...
When building a model - I usually get to a stage that cut slots and fit the servos. I then want to know relations of rods / arms etc. to surfaces without dragging out Rx, Tx, ESC, LiPo etc. All I do is plug in servos to powered tester and bingo ... small, compact and simple. I can even test arc of swing of arm to be sure is clear. I'm actually thinking to open up my tester and see if I can insert a small 1/3rd AAA pack inside to make more compact. Tx can stay on bench charged up and quiet ready for flight. Nigel |
#9 | ||
I guess I haven't had to work on anything that the servo's are hard to get to. I actually enjoy setting up servo's with the transmitter, so I can set my throws to get an idea of actual pushrod travel and direction, do a quick range test, and its ready to fly.
#10 | ||
Friends: (8)
I only have the charger, and a paddock full of waist high crops to absorb mistakes
#11 | ||
Originally Posted by hayofstacks
Hay ... you are talking much later down the road ... when even I use the Tx ! I'm talking about when part way through build and sorting servo position, etc.
It has nothing to do with hard to get servos .... Nigel |
#12 | ||
Love my Super Cub
Friends: (15)
Yep I will be away until Spring time Just in time for good flying weather in the US
Nigel do you have a link or two to a servo tester that you use or recommend? It has sparked a lot of my curiosity. They appear to be very inexpensive but to a newbie builder or someone like myself who devils into it from time to time does not know a quality piece of equipment from garbage.
#13 | ||
Friends: (7)
Servo testers will also operate an ESC through the range if necessary.
IMHO you missed one very essential item for electric flight - a good soldering iron. Hillbille |
It isn't the mistake that causes the crash - it the time it takes to realize that it WAS a mistake!!
AMA884978
#14 | ||
Love my Super Cub
Friends: (15)
Got to agree with this. I made the mistake of buying your cheap department store iron and wondered why all my connctions were junk.
#15 | ||
One more use for the 4.8 volt battery; use it by powering up your receiver (just plug it into any open slot on the receiver instead of the ESC) to bind it to new systems. That way you do not need to worry about throttle position or about the prop doing those occasional nasty things by taking off unexpectedly.
#16 | ||
Originally Posted by Fishbonez
I too don't know a good one from garbage ! But I bought the tester on Hobby King ...
http://www.hobbyking.com/hobbyking/s...vo_Tester.html as it covered various pulse width servos etc. At $7.95 + shipp. - I thought it was a steal ! It works well and I am very happy with it. OK - it's not like a more expensive one that will tell you dead-band width etc. - but then I'm not that finicky ! I just want to know if servo works Ok or not. There is a cheaper one at half that price but is not dual pulse width. Nigel |
#17 | ||
Originally Posted by hillbille
I think we could all add a lot more items to the list, my point in the 4 was actually a lead into the Servo Tester and 4.8v pack .... which you rarely see mentioned.
I have an old iron that has been with me for nigh on 40yrs ... in fact so long that the bit is worn half away ... I keep looking for a replacement iron - but all the ones of 40W and up locally are pointed tips instead of the flat spade end I want. Looks like another online purchase coming up ! Nigel |
#18 | ||
Friends: (7)
Servo testers:
http://www.headsuprc.com/servlet/the...M-Servo/Detail http://www.hobbypartz.com/servotester.html http://www.gorillabobsrc.com/catalog...roducts_id=631 These are all USA distributors. The products might be Chinese but at least the dealer is here. A good soldering iron is essential but - that being said - knowing the proper method for soldering is also essential. Hillbille |
AMA884978
| Z-Best Sander Ever IMHO | CHELLIE | Ebay for sale | 1 | 02-12-2012 01:14 AM |
