Old 12-15-2012, 06:18 PM   #1
dheaton
Default Wing Pod
Do they make a wing pod for an electric motor? I used to fly several planes with the Cox .049 and would love to fly those same planes with an exectric motor. Any help?
dheaton is offline
Old 12-15-2012, 06:28 PM   #2
smokejohnson
smokejohnson's Avatar
View smokejohnson's Gallery22
Club: Independent
Friends: (108)
http://www.greatplanes.com/accys/gpmg0800.html
smokejohnson is offline
Old 12-15-2012, 07:32 PM   #3
dheaton
That is what I need. I went to the link but how do you purchase it? I asked the local (4 hours away) but they never heard of it and don't know where to get it. Can I order it online somewhere?
By the way, thanks for the reply
Originally Posted by smokejohnson View Post
dheaton is offline
Old 12-15-2012, 07:40 PM   #4
smokejohnson
Club: Independent
Friends: (108)
No problem...here ya go
http://www3.towerhobbies.com/cgi-bin...?&I=LXJ769&P=V
Old 12-15-2012, 07:52 PM   #5
dheaton
Thanks. I am kinda new to the whole electric thing. It says it comes with a 550 motor. That is a brushed motor right? I would like to put it on planes smaller than 2 meter and use a brushless motor. What do you think?
dheaton is offline
Old 12-16-2012, 12:23 AM   #6
starcad
Model Designer
starcad's Avatar
View starcad's Gallery14
You could probably make one with a little ply and balsa saving yourself a ton a $$$'s
starcad is offline
Old 12-16-2012, 01:39 AM   #7
smokejohnson
Club: Independent
Friends: (108)
Looking at the picture of the pod with the sides off I don't see why you couldn't mount a brushless motor. You may need some spacers to get it right but it should work.
http://www.headsuprc.com/servlet/the...ffs/Categories
Here are some ideas if you wanted to make one yourself like Starcad has suggested.
http://www.rcuniverse.com/forum/m_98...tm.htm#9867460
Edit: Yes, the 550 would be a brushed motor.
Old 12-16-2012, 04:51 AM   #8
Beemerider
Beemerider's Avatar
Club: Augusta County RC Club
Why not pull the 049 and put a small brushless in it's place? I started out early this year with a 2M sailplane (no motor) and had long ago purchased a balsa wing top pod and 049 to fly it with. Rather than fiddle with a pod a friend showed me how easy it was to modify the nose and mount a brushless motor.
Beemerider is offline
Old 12-16-2012, 06:45 AM   #9
dheaton
I thought about doing that as well but I would like the pod to go from plane to plane. I have a very small park flyer that is just a hand launch deal and would like to pur a smaller motor on with a pod. I do have a pod that i used with the 049 but I was not sure how I could mount the electric motor.
dheaton is offline
Old 12-16-2012, 12:36 PM   #10
View CHELLIE's Gallery13
Friends: (281)
here you go in place of the 049, just screw the electric motor in place. if needed, add a block of balsa to the pod, with some 3/16 or 1/4" plywood epoxied to the balsa block to move it out more and to mount the motor to. Hope that helps, Chellie
http://www.gravesrc.com/SIGSH660_SIG...p/sigsh660.htm
http://www.wattflyer.com/forums/showthread.php?t=39483
Old 12-17-2012, 07:27 PM   #11
dheaton
That is what I need, thanks
dheaton is offline
dihedral on low or mid wing paulatgis Scratch and Kit Built Aircraft 26 12-19-2012 12:25 AM
FMS / BlitzRC Cessna 182 (55-inch) wing span! guapoman2000 Scale E-Powered Aircraft 13 11-30-2012 09:12 AM
New Parkzone Extra 300 Its Here, Newbie Report phillipmorris Beginners 65 10-07-2012 02:53 PM
Parkzone Extra 300 Upside Down Wings *HORIZON LEAVES US IN THE COLD* jaskel Foamies 157 10-07-2012 02:48 PM
Super Cub & Wind Question vaflyer General Electric Discussions 17 04-14-2012 09:51 PM
Page generated in 0.75960 seconds with 39 queries
