Old 12-15-2012, 09:50 PM   #1
luckymacy
Default How do you troubleshoot an all electric setup?
How do I troubleshoot an electric plane when I don't have any parts to swap out? I bought a used Sebart Wind 110 I which supposedly has new Hacker A50-16L V2 (it does look shiny new and 'spotless') and the same props, ESC and battery packs that the plane supposedly flew with in copetitions. In other words, it should have been a perfectly working set already installed.
I took it out for a fist flight (for me) today. I had a amp meter installed and was doing a ground check. I do not have any experience with setups this large (8s) so was proceeding extra cautiouslessy. Anytime on the ground I got near 30 amps the motor made a screetch sound and shut down. I removed the back support plate as I was suspicious it was causing some drag/binding but it made no differenc. In my smaller electric planes that's usually been due to overspeeding or not enough load on the motor (ie, the sound doesn't happen when actually flying, it only happens on the ground). I am hoping that the motor won't make that sound and fly fine but I won't risk flying it until I know for sure. Any ideas on how to troubleshoot or verify the setup is fine?
luckymacy is offline
Old 12-15-2012, 11:40 PM   #2
View CHELLIE's Gallery13
Friends: (281)
The timming on the ESC might be off, or you might have the brake turned on, on the ESC, set the ESC timming to the lowest and give that a try, check to see that your brake is not turned on, what ESC do you have, you will need to get a timming card as thats easier than trying to time/program the ESC from the transmitter, Check the esc to motor connectors to make sure they are tight, Hope that helps, Chellie
Old 12-16-2012, 12:00 AM   #3
Rolling Thunder
Keep the sunny side up
Rolling Thunder's Avatar
If its a outrunner motor Ive seen the can come unscrewed from the rest of the motor causing it to screech
Im taking what their giving cuz' Im slopeing for a living
Rolling Thunder is offline
Old 12-16-2012, 07:20 PM   #4
hayofstacks
X2 for both.
I've had a bad bearing cause screeching underload only, motor timing and the set screw coming off of the can. A bent shaft or the motor being too tights can also cause it to screech like that. Also a bad or poor solder connection.
hayofstacks is offline
Old 12-16-2012, 10:11 PM   #5
Friends: (16)
Hmmm
Double check the shaft on that Hacker motor, try rotating the shaft while holding on to the rotating magnet "bell". The shaft is held by a set screw or two. If its loose, it will be obvious.
If the motor is "Bent", it will be visable if you spin the motor either with a battery operated drill, or by just running it with the battery and ESC.
Were you running that motor without a prop? If you had a prop on it, try running it with no prop. (No it won't overspeed, it will just run at its maximum no load RPM.) In fact, running any of my Hacker motors either with or without a prop makes absolutely no difference on how those motors run, while connected to my various Castle Creations ESC's. They run smoothly at any power setting, either with, or without a prop.
Also, is your 6S LiPo in good shape? If you were measuring current, were you also measuring the battery voltage? Also make absolutely certain the three brushless motor wires are solidly connected to the output of the three ESC wires. A loose or intermittent connection here can really screw up things.
What kind or brand of ESC do you have? This does kind of sound like an ESC problem. Make certain your ESC programming isn't allowing the ESC to hit the LVC (Low Voltage Cutoff) on the battery pack.
What is the current/voltage rating on your "Smaller" ESC's and battery? If those ESC's are rated for over 10 or 20 Amps or so, you can try wiring up that Hacker motor to the ESC and battery pack for your smaller models and see what happens. (DON'T USE THE 6S PACK ON YOUR SMALLER ESC!!!! The 6S voltage will blow up your smaller ESC.)
I'm assuming you've not noted any burned smell around the motor and its windings. If it's been overheated and burned up, it will smell like h*ll.
I've got 8 Hacker motors ranging from their A30 size to two A40's, three A50's and two A60's. All run flawlessly. Well one of the A60s had set screws come loose on the shaft and bell housing. After about 170 flights.
You're right, DO NOT FLY this model until you figure out what's wrong. You are dealing with a significant amount of power in your motor/esc/battery setup. And if things go south in flight, you could have a lot of electrical damage, or worse, loose the model on an off field landing or what ever.
And, last, but not least, you might check out my thread on testing brushless motors:
http://www.wattflyer.com/forums/showthread.php?t=35216
Everything You Wanted To Know About Electric Powered Flight AEAJR General Electric Discussions 256 06-14-2013 04:38 PM
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 147 05-29-2013 09:32 AM
WHITMAN FLYERS ELECTRIC FLY-IN 8/11/12 Bethpage NY whitman flyers Events, Shows and Fun Fly's - Electric Airplanes 5 08-10-2012 01:43 AM
Electric Setup for a 24" Wingspan Plane paul372 General Electric Discussions 5 08-10-2011 05:19 AM
12 Texoma RC Electric Extravaganza May 7 jed1d Events, Shows and Fun Fly's - Electric Airplanes 0 04-22-2011 11:44 PM
Page generated in 0.19216 seconds with 27 queries
