Old 12-15-2012, 10:21 PM   #1
View mclarkson's Gallery4
Outstanding Contributor Award
Default Revolextrix Cellpro Multi4 - what's it doing?
I have a Revolextrix Cellpro Multi4. The charger works great and I’m very happy with it, but …here’s what I don’t understand:
I put on a 3S LiPo and start charging on setting #1 – Lipo Generic Accurate Charge. (The only setting I use.)
Now, as the battery crosses past 12.6v the charger beeps at me. 12.6v (4.2V/cell) is the nominal full voltage of a 3S Lipo.
The individual cells show something like 4.206 v/cell.
The charger fuel gauge, though, shows 93-94%. And the charger keeps going.
What I think is the display for total amps put into the battery (CAP 36mAh IN) keeps going up as the charger puts more amps into the battery.
The fuel gauge slowly climbs to 100%. Individual cells continue showing 4.206 v/cell. Eventually it finishes and gives me a series of beeps to let me know.
What is the charger doing between the first beep (12.6v) and the second beep (100%)?
Old 12-16-2012, 12:01 AM   #2
Stevephoon
Stevephoon's Avatar
View Stevephoon's Gallery40
Hi Mark,
I have a Multi4 as well. (But I have upgraded to a Powerlab 6 this year.) The first beep is when you hit 90% charged, then the series of beeps when complete. The charger "knows" that while flowing current into the battery, the voltage is higher than while resting. So the % charge calculations are not just based on voltage. It must take into account the amount of current that is flowing as well. (And probably a bunch of other things.)
If the charger stopped as soon as it reached 4.20 volts per cell, the battery would actually sag back to a lower voltage and not truely be 100% changed. They slowly ramp the current back while maintaining a constant voltage untill the current is low enough to be considered fully changed. I think that is the last 10% of the charge.
Stevens AeroModel Daddy-O 525, Groove G-480
Mountain Models Firestorm, P-51, EVA Sport/Bipe, Dandy/Dandy Sport
Pocket Rocket, Stevephoon 3D, SSPR - Steve's Simple Pylon Racer
DJAerotech Chrysalis 2M-E Sailplane, Misc Foamy Combat Planes.....
Stevephoon is offline
Old 12-16-2012, 01:44 AM   #3
Tim Marks
President FMA, Inc.
Originally Posted by Stevephoon View Post
Hi Mark,
Great explantion! I concur! The charge is considered "DONE" when the charge current drops to the charge termination current level defined in the preset. Generally this is C/20 which means (Capacity / 20) or in most cases the set charge current / 20. But this cutoff is adjustable using the CCS application and you'll find the parameter on the Termination tab.
Tim Marks
Tim Marks is offline
Old 12-16-2012, 02:10 AM   #4
swimmer
Tim Marks
Tim,
I also have a Multi4 and use a CCS. You say the termination current level cutoff can be changed but what is the advantage or disadvantage?
Allan
swimmer is offline
Old 12-16-2012, 05:34 AM   #5
Tim Marks
President FMA, Inc.
Originally Posted by swimmer View Post
Tim,
Allan
Hi:
Good question. The lower the current falls off at the end of CV mode, the more electrons you pack into the cells (without over-charging because you're always going to regulate the per cell voltage), the better the pack will be balanced, and the less the cell voltages will sag after the charge is DONE.
Example:
Termination set: C/20
Charge rate set: 2A
Charge will go until current drops to 2A/20 = 100mA
Termination set: C/10
Charge rate set: 2A
Charge will go until current drops to 2A/10 = 200mA
C/20 termination will result in a fuller, more balanced charge. The price you pay is the charge will take slightly longer.
Tim Marks
Old 12-16-2012, 10:04 AM   #6
Thanks guys. I trust the charger to know what it's doing, but I was curious just what that was.
Sneak Peek at the NEW Cellpro PowerLab 8 Tim Marks FMA Direct 63 09-21-2012 05:09 AM
CellPro Multi4 Q? TheRockman Batteries & Chargers 2 01-24-2012 09:02 PM
Sold CellPro 10 with balance leads -Sold MaxAdventure Batteries and Chargers Forsale/WTB 3 12-10-2011 07:52 PM
Introducing the ALL NEW Cellpro PowerLab 6 (EC5 version) Charger Howard Matos FMA Direct 7 10-25-2011 07:03 AM
Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 0 07-28-2011 02:04 PM
Page generated in 0.20260 seconds with 29 queries
