Old 12-17-2012, 04:12 AM   #1
DHC Beaver
DHC Beaver's Avatar
Default Focke wulf ente
Hi,I thought I'd show a few pics of my current build.It's a canard design from the late 20's.Designer George Wulf actually got killed when he crashed oone of the 2 prototypes.
http://www.google.co.nz/imgres?num=1...9,r:1,s:0,i:90
I got the plans on ebay from a fellow in Canada.It's an old english plan,which I had my eye on years ago,before it disappeared from the plans catalog.
Anyway,here's a couple of views of the fuselage:
As you might be able to see the sides are foamboard with the paper removed(what a job).The stringers are 3/16 balsa.There are 2 main bulkheads from foam,and the rear one has ply reinforcement ,as the wing dowels plug into it.
I haven't weighed the fuse,as it's not quite finished,but it feels pretty light so far.
Here we have a shot of the basic wing.Foamboard ribs,with balsa spars and sheeting,plus rib caps.
The ailerons are a 1/16th sheet core,with 1/8 ribs glued on,then sanded to shape.
Next is the stab with separate elevators.On the real one,they are hinged on oddly shaped brackets,but this didn't seem very strong to me.Hence I used plastic "flap"type hinges from HK.They will be glued and screwed to the rear of the bottom sheeting,filled with trailing edge stock at those locations.
Finally,a shot of the fin.Again,a 1/16th sheet core,but with foam ribs,except for the top and upper leading edge.This portion of the fin has a straight edge,as the front portion is attached to the wing.
Currently,I'm working on the music wire struts for the stab,and the wire undercarriage.Next on the board will be the nacelles,which will also be foam based.
DHC Beaver is offline
Old 12-17-2012, 05:28 AM   #2
Bill G
Super Contrubutor
Bill G's Avatar
View Bill G's Gallery82
Club: rcg staff
Friends: (17)
Great subject. I love the oddball stuff, especially Luftwaffe subjects. The first pics reminded me of the Dornier Delphin, which I was debating when I decided to build their Gs recently.
I can't remember if it was on the web or the internet, but there's a full scale version of this plane, or at least a very similar version or replica that is flying now.
Bill G is offline
Old 12-17-2012, 06:26 AM   #3
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Friends: (168)
Hi
Outstanding
Great work so far
Do enjoy
Take care
Yours Hank
kenchiroalpha is offline
Old 12-17-2012, 07:02 AM   #4
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Neat build! And fascinating choice of subject! I also love to see the rare ones. Keep up the good work and please keep us posted!
Old 12-30-2012, 10:35 AM   #5
QUISSEL
Congrats to your nice build up! That`s the first build up thread about a Focke Wulf FW 19 I`ve found, and Ì`m looking for years! I collected pictures, data sheets and 3 views of the FW 19, but it was not possible for me to find a plan for a rc model. I`ve started to construct an own plan. I also calculated aerodynamic datas, but in the moment I´m not sure if this calculation is correct.
Can you tell me facts from your model, like position of CG, the wing-profiles, angel of setting, scale and your expected AUW, electric or glow drive? And do you know a source for a plan nowadays?
I cant wait for your maiden flight.... and it would be nice to get some further informations! Thanks a lot!
QUISSEL is offline
Old 12-30-2012, 07:58 PM   #6
DHC Beaver
DHC Beaver's Avatar
Hi,Quissel,here is where I got the plans:
http://www.ebay.com/itm/Plans-for-Fo...item53f2850c1f
It's an old english plan,that's probably been re-inked.Perfectly fine.
The plan is for 2 x .15 engines,but I'm going to use 2 of these:
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
I also use 2x50A esc's,and 2 x 3000 mah lipo packs in parralel.
I don't know what the all up weight is going to be,but I'm hoping for 2-2.5kg.The wing profile doesn't seem to be a specific section.
The c.g. is about halfway along the straight roof section.
I'm using a bit of foam here and there to keep weight down.Currently working on the nacelles in foam.I'll be flying of grass,so i'm using larger wheels as well.
Old 12-30-2012, 11:49 PM   #7
View Don Sims's Gallery3
WAA-08 Pilot  Globetrotter Pilot
Friends: (38)
Really interesting plane DHC. Looking forward to seeing more as the project progresses!
Take care and thanks for posting at WattFlyer!!
Don
Don Sims is online now
Old 12-31-2012, 02:47 AM   #8
HO-229
PROVERBS 27:17 ROGUE!
HO-229's Avatar
Looks good!
impressive video... it looked as if the aircraft was close to stall at the slow speed high AOA
Dave
HO-229 is offline
Old 12-31-2012, 10:36 AM   #9
QUISSEL
Thank you DHC! I ordered the plan just in the moment!
QUISSEL is offline
Old 01-08-2013, 09:20 PM   #10
QUISSEL
Hi, DHC Beaver, I have got the plans today.
QUISSEL is offline
Old 01-09-2013, 05:50 AM   #11
DHC Beaver
DHC Beaver's Avatar
Excellent,Quissel,have fun building this unusual model.I'm at a bit of a standstill at the moment,since I stuck my finger in a bandsaw bladeLuckily,it only cut my nail in half(!),but I need that finger for building
Old 02-18-2013, 11:53 PM   #12
DHC Beaver
DHC Beaver's Avatar
Sorry about the lack of updates,been a bit busy.
I made up the struts for the elevator out of 3/32 piano wire and brass strip
I've also done the nacelles, cowls,and cockpit cover.They are 1/2" foam sandwiched together,then shaped with various grades of sandpaper.
Then i covered all pieces with old dress pattern paper.It's very similar to model tissue,and applied with thinned aliphatic resin glue.
Then 2 coats of water-based polyurethane varnish,and the pieces have since been painted with silver acrylic enamel.
Unfortunately,the edges of the cockpit cover melted slightly,due to the paint being thinned with mineral turps.
I wasn't altogether happy with the fit of the cover anyway,so i'll line the affected areas with 1/16th balsa,and shape to fit.
Old 04-28-2013, 07:50 PM   #13
Arado
What goes up......
Hello DHC Beaver,
Noticed your thread on the Ente and also the fact that you use Ollie B. Bommel & Tom Poes as a mascotte - the logo of the town I live.
If you are interested, I am happy to supply you with a PDF of the original article that goes with the plan - it has been published in RC Scale Aircraft, spring 1987.
Please let me now if this would be of any use to you.
Best,
Arado
Arado is offline
Old 04-28-2013, 10:12 PM   #14
DHC Beaver
DHC Beaver's Avatar
Smile
Hallo.Arado,I would appreciate a copy of the build article.I'll pm you with my details.Thank you very much
I was born in Den Haag,and emigrated to new zealand in 1970.
I always liked ollie and tom poes comic strips.
Ultra Micro, AR6400 compatible, kits and scratchbuilds smokejohnson Indoor & Micro Electric Planes 95 05-13-2012 12:51 AM
Focke Wulf Ta 183 version 2 & 3 pattern14 Electric Ducted Fan Jets 25 04-11-2012 04:38 AM
Page generated in 0.40564 seconds with 47 queries
