Old 12-24-2012, 03:15 AM   #26
Friends: (16)
Originally Posted by MX5Seeker View Post
I actually put a drop or two of hot glue through the hole they have for the "pin". Holds them well and I can always scrape or drill it out.
Those "APP" connectors we used at work by the thousands, and those from Allied Electronics don't have that hole in the middle.
http://www.wattflyer.com/forums/showthread.php?t=64539
BTW, I was using one of the Allied Electronics connectors along with those "Anderson Power Pole" connectors with the 30% thinner pins on the same set of #12 wires. At 55 Amps continuous duty, the APP pins MELTED their plastic shell. The Allied connectors were working just fine, even though they were both carrying the same exact 55 Amps for about 20 minutes.
Old 12-24-2012, 03:26 AM   #27
MX5Seeker
Glad to be here...
MX5Seeker's Avatar
Club: Georgia Mountain RC Club and Bristol Field
That's interesting. I went to the site just now and the plastic sleeves they show have the roll pin hole.
http://www.alliedelec.com/anderson-power-products/
MX5Seeker is offline
Old 12-24-2012, 03:31 AM   #28
Friends: (16)
Apparently Allied Electronics carries both the Anderson Power Pole connectors, AND the heavier duty TE Connectivity connectors.
I've got 130 Red shells, 150 black shells, 200 terminals from Allied Electronics. The last batch was ordered in November 2012. None of them have the hole in them.
http://www.alliedelec.com/search/pro...x?SKU=70087469
These are made by "TE Connectivity". When both the housings and terminals are made as a set, they readily plug into the Anderson Power Pole connectors.
Old 12-24-2012, 04:20 AM   #29
MX5Seeker
Glad to be here...
MX5Seeker's Avatar
The TE ones must be hard to find. All of the ones I have seen at HAM fest, which is where I buy most of mine, have the roll pin hole. But as you said in your other post the real issue is probably the thicker contacts. Will the thicker contacts work in the sleeves with the pin hole?
Old 12-24-2012, 05:49 AM   #30
Friends: (16)
Nope:
The thinner pins work only with the APP housings, the thicker pins work only with the TE housings.
That said, you can plug in the APP pins and housings into the TE pins and housings, or vice-versa. (FYI, I've got both the APP type and the TE type connectors in my inventory)
And, after a LOT of looking, I've only found the TE connector pins and housings at www.alliedelec.com. They started out with 5000 pins, and are now down to 1000 in their stock.
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 146 05-07-2013 03:24 PM
Castle Creations / A123 Battery Backup system kyleservicetech RC Radios, Transmitters, Receivers, Servos, gyros 6 04-17-2012 03:55 PM
3 cell Lipo Batteries- Bang for the Buck dahawk General Electric Discussions 30 03-11-2012 01:40 AM
Flite Test Videos: Appreciation Thread FlyingMonkey Off Topic Chit Chat 66 04-04-2011 04:58 AM
Page generated in 0.25022 seconds with 29 queries
