Old 12-17-2012, 08:35 PM   #1
paulatgis
Default red racer build
going to put all my notes into one thread. This is a red racer build. i saw this plane here http://www.rcgroups.com/forums/showthread.php?t=997818 a while back and built a few like it. the first a little 24 inch that flew very nice. Next a 36 inch version which flies superb. from comet plans. mine aren't red, but yellow instead. the two had tapered semisymmetrical wings (i used the falcon rib template). The design is a little different than the standard low or top wing plane.
I scaled it up to 60 inch wingspan with naca 0018 ribs. and after debating mid or low wing design went with the mid to shoulder design. im going to riase the motor and therefor was able to raise the wing a little to cut down on loss of fuse strength while keeping a one piece wing.
Also debated the fuse construction of balsa sticks or foam. My last balsa plane took a year to finish so I went with foam. Note the interlocking fuse parts.
looks pretty good so far. Next up is landing gear mount, wing supports and thought on battery placement below wing.
Name:	red racer 8.jpg
Name:	paper red racer.jpg
Name:	fuse parts.jpg
Name:	fuse banded while glue dries.jpg
Name:	fuse with wing placement and foam top.jpg
Name:	fuse with wing.jpg
paulatgis is offline
Old 12-17-2012, 11:45 PM   #2
dgjessing
Looking good! How thick is the blue foam?
Dave
AMA #56519
dgjessing is online now
Old 12-18-2012, 01:41 PM   #3
paulatgis
half inch from lowes.
Old 12-24-2012, 02:52 AM   #4
paulatgis
making progress. i cut the fuse to take the wing then put it back in the wing puzzle wise. shooting for zero incidence. i might have achieved it. hoping not to have negative incidence. looking good so far. going to sheet the wing with 1mm foam voered in bright orange and bright yellow.
Name:	big red racer wing joint mid wing.jpg
Name:	big red racer wing angle.jpg
Old 12-24-2012, 02:57 AM   #5
paulatgis
wing has an 11 inch chord. planning on making strip ailerons tapered. 6 inch aileron width at fuse tapering to 4 or 3 inches at wing tip
Old 04-25-2013, 08:57 PM   #6
paulatgis
Default flight
video and pictures of flight. flies nice. hoping to fly it again tomorrow. big fat wings made the landing very slow and easy. did bounce though, i need to get it even lower before killing motor.
im using a 5 cell battery on 17 prop.
Name:	in flight 1.jpg
Name:	in flight 2.jpg
46" Hall Bulldog Racer build The_village_idiot Scratch and Kit Built Aircraft 22 07-26-2012 03:50 AM
$100 Scratch Build Contest: Simple Pylon Racer Stevephoon Scratch and Kit Built Aircraft 57 01-19-2012 01:27 AM
$100 Scratch Build Contest "Best Looking" poll here hillbillynamedpossum Scratch and Kit Built Aircraft 100 01-07-2012 11:12 PM
Charlatan - a balsa scratch build pylon racer Sunstorm Scratch and Kit Built Aircraft 3 11-02-2011 12:13 PM
Advanced Design 1920 Dayton Wright RB1 Racer with Flight Video Bill G Scratch and Kit Built Aircraft 109 06-27-2011 03:50 AM
Page generated in 0.98328 seconds with 45 queries
