Old 12-22-2012, 05:37 AM   #1
DHC Beaver
DHC Beaver's Avatar
Default Twin opto esc's
Hi,all.I would like to use two 50A opto esc's I have to power my twin.I will use 2 3000mah lipo's in parralel.
Do i still need to remove the red wire from the esc to receiver connection?These will have to be on a Y-connector of course.
I will use a 2-cell LiFepo pack for the rx and servo's.
I know a separate sbec would be lighter,but I have a feeling I'm going to need nose weight anyway,so I might as well make it work for a living.The aircraft is the Focke-Wulf 19 Ente I mentioned in another post.
DHC Beaver is offline
Old 12-22-2012, 08:40 AM   #2
2013 President of PSSF
If the ESC's have a BEC (battery eliminator circuit) I disconnect the red lead when I use a flight pack battery. If they do not, then there is nothing to worry about.
In your case with 2 ESC's on a Y, and a separate flight battery of 2s Life which I think will put out 6.6 v, I would disconnect both red wires before they plug into the Y lead, if they have BEC's.
If you only disconnected the red from the Y lead to the RX, the 2 BEC's could sort of screw each other up. (don't need that)
2 --50 amp ESC's sounds like a nice plane, tell us about it. Good luck
Dave R, Proud PGR rider.
Wildflyer is offline
Old 12-22-2012, 09:00 AM   #3
The ESC's are OPTO (meaning no BEC) so you don't need to remove the red wire.
Just a thought and maybe too late, but would it not have been better to run the batteries in series (or get a 4s battery)? The higher voltage would have meant you could have halved the amps for the same power and so then used smaller/lighter/cheaper ESC's and lower kv motors.. This would give slightly lighter weight overall and better efficiency from the motors for the same power.
JetPlaneFlyer is online now
Old 12-22-2012, 05:57 PM   #4
Friends: (16)
How many cells are in your two 3000 mah LiPos?
Old 12-22-2012, 06:15 PM   #5
Good question... I somehow read it that they were 2 cell packs but i see that nowhere did it actually say that.. i must have dreamed it
Old 12-22-2012, 06:24 PM   #6
Friends: (16)
Yeah, same here, till it was re-read, and those two cells were for the LiFe receiver battery.
Old 12-22-2012, 11:48 PM   #7
DHC Beaver
DHC Beaver's Avatar
The 3000 mah packs are 3-cell Zippy packs.The motors are hextronic 4023 850kv bell motors.I want to swing 11x5.5 props with them,counter rotating.
The reason i want to use the 2x50A esc's is because I have those in my drawer.I don't have a matching pair of smaller ones.
This is the aircraft in question:
http://www.wattflyer.com/forums/showthread.php?t=69046
Thanks for the clarification re the red wire,folks.
Old 01-18-2013, 10:18 AM   #8
I use twin 50A optos on my HK Parkjet ...
I use a single LiPo - but principle is same. Power into both Opto ESC's, then ESC's Rx leads to Y lead to Rx throttle ch.
I use a separate BEC that is connected to the LiPo power lead before the ESC's .. this plugs into a spare Rx ch to power the system.
Nothing else to do as long as opto ...
Micro F15 twin 35mm EDF Joe 1320 Indoor & Micro Electric Planes 9 03-01-2013 04:49 PM
For Sale Suppo 18A, 50A, 60A, 70A, 100A, & 200A ESCs at CLOSEOUT PRICES! Garret H Motors and Speed Controllers for sale & WTB 7 01-12-2012 11:19 PM
Twin Motor Synchronization iFLYrc_Vic General Electric Discussions 11 08-19-2011 02:57 AM
Nitroplanes Dynam C-47 Twin Engine Maiden Success phillipmorris Beginners 18 04-30-2011 07:43 PM
Question regarding HobbyKing & Turnigy (1 cell, 3 Amp) ESCs BOBWRC Indoor & Micro Electric Planes 3 01-06-2011 11:39 PM
Page generated in 0.22176 seconds with 33 queries
