Old 12-22-2012, 04:26 PM   #1
Epowerreg
Real Flying
Epowerreg's Avatar
Club: They cant handle it...
Default Charger cuts off at 4.26 per cell high or?
Is that very high? How high would make you worried per cell?
Epowerreg is offline
Old 12-22-2012, 05:01 PM   #2
slipstick
Outstanding Contributor Award
If it's an accurate measurement it's too high. I like to see 4.20V or less. But I wouldn't actually worry until/unless I'd checked it myself with a meter I know to be accurate. Some chargers report all sorts of odd voltages. I had one a while ago that cut off the charge at a reasonable voltage but consistently reported 0.2V high overall i.e. it stopped at 12.6V but said it was 12.8V .
slipstick is offline
Old 12-22-2012, 05:01 PM   #3
the guidance I've read says to never exceed 4.22v per cell. So yes, 4.26V is worryingly high.
Is this because the cells were not balanced?
Old 12-22-2012, 05:49 PM   #4
Friends: (16)
What make and model of charger do you have?
Old 12-22-2012, 07:14 PM   #5
Epowerreg
Real Flying
Epowerreg's Avatar
Is the Supermate dc6. When using balance the volt per cell is 4.17 This over voltage occurs with just a normal lipo charge selected.
Old 12-22-2012, 08:44 PM   #6
Rodneh
I'd suspect the accuracy of the meter being used to measure the voltage. Do you have a known accurate meter to check it against? Chances are the voltage is not quite what you are reading. However, if it is an accurate reading, I'd recalibrate the charger or use a different one.
Rodneh is offline
Old 12-23-2012, 01:39 PM   #7
nidly
Something about this isn't quite adding up.
You're saying that on a non-balanced charge the cv portion of charge is reading 4.26 per cell? How are you getting this reading? The resting voltage is probably well below 4.2 volts, right?
Are you saying that when balance plug is used the reading is 4.17 on the cv stage? How do you get this reading?
The only way I can guess this happens is that perhaps this is the reading from a pack's highest cell during a non-balanced charge and is the highest reading it gets to upon termination of the charge? If this is the case then the pack is just unbalanced and needs balanced.
nidly is offline
2 batteries at once with 2-3 Cell LiPo Balancing Charger EFLC3110? HobbyJumper Batteries & Chargers 2 11-26-2011 08:42 PM
Introducing the ALL NEW Cellpro PowerLab 6 (EC5 version) Charger Howard Matos FMA Direct 7 10-25-2011 07:03 AM
How to use a RC Lipo charger properly? SimonXi Power Systems 0 08-17-2011 11:02 AM
Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 0 07-28-2011 02:04 PM
Charging LiPos inside the airplane Henry111 Batteries & Chargers 118 03-18-2011 06:27 PM
Page generated in 0.20568 seconds with 31 queries
