Old 12-30-2012, 12:53 AM   #1
javier668
Default Eflite Park 480 910kv or 1020kv??
Hi dudes:
I have a eflite extra 260 with a Park 480 1020 kv, 40 amp pro BEC and 12x6 apc prop, whit 3s lipo, my plane runs like a dream, but searching in the web i founded the 910 kv motor, i wondering if the 910 kv is a better setup?
Which is the purpose of producing two versions?
Regards and happy holidays!
javier668 is offline
Old 12-30-2012, 01:01 AM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Originally Posted by javier668 View Post
Hi dudes:
Those motors spin at different speeds. So the change of kV allows the use of larger or smaller propellers.
Old 12-30-2012, 01:19 AM   #3
javier668
Oh yes i know that, but based in the kv 's the 910kv could be a best choice for the 12x6 APC prop?
Regards!
Old 12-30-2012, 01:33 AM   #4
WAA-08 Pilot
Friends: (9)
How many volts (cells) you running?
Old 12-30-2012, 02:40 AM   #5
javier668
3s
Old 12-30-2012, 10:13 PM   #6
View CHELLIE's Gallery13
Friends: (281)
Hi dudes:
There is not much difference between 1020 and 910 KVs, you may not even notice the difference if you swapped the 2 motors, if you wanted to use a 4 cell lipo, then i would use the 910 kv motor, take care, Chellie
Old 12-30-2012, 10:16 PM   #7
WAA-08 Pilot
Friends: (9)
The 910 will have less power on 3s but you might be pushing that already a 12x6 is a pretty big prop for those motors.
Old 12-30-2012, 10:29 PM   #8
Yes, 12x6 is too much prop for either of those motors but especially so the 1020Kv. Unless you are using a old/low rated LiPo whose voltage is sagging then you must be pulling far more amps than the motor is rated for. It must be burning up!
A 10x6 would be more like it.
E-flite's specifications are misleading because they tell you are range of props and a range of battery types (2s and 3s) but what they don't tell you is that you must never use the largest prop with the highest voltage battery. the large prop can only be safely used with a 2s battery.
JetPlaneFlyer is online now
Old 12-30-2012, 11:14 PM   #9
javier668
Mmm 12x6 is fine, i never burned a eflite motor.
A lot of people use this prop and Park 480 in the eflite extra 260 w/o problem, the motor after 7 min reach 40 Celsius.
For 3D is fine, i think if i use this prop on a warbird or heavier plane, 12x6 isn't good idea, but the extra weight is 800 g and runs fine.
I think 4s in a park 480 is too much.
Regards!
Old 12-30-2012, 11:15 PM   #10
have you ever put a Wattmeter on it? The motors max rating is I think 28Amps for a short burst, less for continuous
Old 12-31-2012, 01:04 AM   #11
javier668
Oh yes, 30 amp full TH static, in the air I think the real value is less.
For 3d I only need short burst of full power, the most time is mid throttle regimen.
Eflite motors are a bit under rated I think, I never heard about burned eflite motor.
Regards!
Old 12-31-2012, 06:07 AM   #12
Regards!
30A isnt bad. I can only guess that your battery voltage is low because with good voltage it 'should' be pulling about 40Amps.
Anyway. back to your original question.. the 910Kv motor using the same prop should pull a few less amps but the efficiency should be a bit better so power to the prop might not be much different.
Sold Eflite 480 1020kv icarus46 Motors and Speed Controllers for sale & WTB 0 12-02-2012 04:49 PM
For Sale PA Addiction new Eflite 480, Spektrum 6100 rcvr, servos, 40A Esc EXTRAMAN13 Airplanes - Electric For Sale & WTB 1 09-20-2012 10:22 PM
Slow Stick with a Park 480!??! Mad Joe ParkFlyers 21 02-24-2012 04:22 PM
For Sale Eflite Park 400 920kv with mount HiVoltageAir Motors and Speed Controllers for sale & WTB 2 08-03-2011 03:55 AM
Eflite Sukhoi SU-26m 480 vs. Parkzone Extra 300 Bobmic ParkFlyers 0 07-06-2011 04:15 AM
Page generated in 0.25504 seconds with 41 queries
