| Indoor & Micro Electric Planes Talk about indoor & Micro electric powered flight here |
#1 | ||
#2 | ||
2013 President of PSSF
Binding the receiver to the transmitter, is not affected by the gear switch.
I don't have a DX-7, but does it have a monitor screen, that will show you if the transmitted signal for your flap channel, is really changing? You DX-7 has no variable aux channels, so I think you should be able program it to use the 3 position flap switch. Then you could have; no flaps, take off setting, and full down landing setting. I hope someone with a DX-7 can guide you. But I have to admit something sounds wrong. If you bought it at a local hobby shop take it back to them. Or call Horizon Hobby Product support, they are very friendly and can guide you through a full check out. Then you will know for certain. Good luck, that is a good flying plane, it really looks good towing the glider up. several of my friends do that. |
Dave R, Proud PGR rider.
When you have flying skills like mine, ![]() You become a master at repair.
#3 | ||
Club: CVMRCC, SEFSD
Now that Wildflyer mentions it, I think the default for flaps settings in Spektrum tx's have no movement. I think it's defaulted to servo center. You said you checked the settings for this, though?
But then you mentioned ch5 is the gear channel? Have you tried all the channels on your tx? Also, you checked the servo connectors on the rx? Maybe they didn't plug them in all the way or something at the factory. |
#4 | ||
My friends carbon cub on a DX-7, operates the flaps, all or nothing with the landing gear switch.
He is trying to figure out how to program the flap 3p switch to mix to the landing gear channel, it should work but I don't have a DX-7 to play with. |
#5 | ||
Club: CVMRCC, SEFSD
Not that it will help me to help you figure this out, but maybe someone else: Is your tx really a Dx-7, or is it a Dx-7s? Don't know if it would matter.
#6 | ||
It also depends on the RX you are using...
But, on one of my planes I used a couple of mixes on my DX7 TX to do just what you are talking about. The Flap servos are in the RX Gear out. On the TX I mixed the flap sw to the gear and I mixed the gear sw to an unused output (Aux2?). This way the 3 position flap sw was used to move the flaps and the gear sw on the TX did nothing. Steve |
Stevens AeroModel Daddy-O 525, Groove G-480
Mountain Models Firestorm, P-51, EVA Sport/Bipe, Dandy/Dandy Sport Pocket Rocket, Stevephoon 3D, SSPR - Steve's Simple Pylon Racer DJAerotech Chrysalis 2M-E Sailplane, Misc Foamy Combat Planes..... |
#7 | ||
I've played around with this some more and am still getting nothing. The manual states that it is the GEAR switch that operates the flaps. Looking at the radio's (DX-7) display showing each channels movement, the gear switch does appear to be working. Had the flaps worked, my plan was to program the radio to use the three place flap switch to operate them.
I called the HS that sold it and was told to bring it back and they would replace as they had not seen this issue. I really don't want to crack it open in a search for loose wiring until they've made a determination as to what to do with it. Appreciate all of the recommendations and I'll post the end result. Thanks. |
#8 | ||
Because the display shows the flap channel is working, Defiantly take it back to the HS. Somehow the system is not working.
Since it uses a receiver similar to the 6400's, there is no choice there. If you break it open you are stuck, the HS would no longer honor a warranty. There is very little chance you will find a broken wire, and if you did, it would require soldering equipment made for subminiature work, that is uncommon. I don't think you would find the flap servo simply not plugged in. You are FAR better off to take it back to the shop. When you do, bring your DX-7 and maybe they can show you how to program it, to do what you want. |
#9 | ||
Problem solved. I carried it and my TX back to the HS where it was bought and they checked it out. They didn't have any luck either. We bound a replacement to the radio and everything worked so it was, in fact, a problem with the plane.
Thanks again, for all of the input. |
| Tags |
| carbon cub , flap settings dx7 , flaps |
| For Sale AS3X Carbon Cub | bimmerland | Airplanes - Electric For Sale & WTB | 1 | 11-09-2012 06:06 PM |
| UMX Carbon Cub 2s 180 motor with flaps, lights and even floats!! | rcers | Indoor & Micro Electric Planes | 16 | 11-02-2012 09:36 PM |
| For Sale Aluminum Motor Mounts for Multiplex, Parkzone, and Flyzone Super Cub Planes | terrynshed | Motors and Speed Controllers for sale & WTB | 4 | 09-24-2012 05:33 PM |
| super cub to a warbird? | corvette | Beginners | 17 | 12-27-2010 06:01 AM |
| For Sale HZ Mini Super Cub | All American | Airplanes - Electric For Sale & WTB | 2 | 02-08-2010 09:17 PM |
