Old 01-02-2013, 12:36 PM   #1
DCDetector
DCDetector's Avatar
View DCDetector's Gallery25
Default Questions about 2 servo(separate plug) aileron vs single, and mixing on the DX7S
I see it is recommended to have 2 servos on separate channels rather than a Y-plug on a single RX channel for ailerons, what is the advantage?
I'm currently using a Y-plug on my ailerons on my MX2 if I were to plug one into the aileron channel would I plug the other into a AUX channel and use mixing to make the AUX work as the other aileron?
DCDetector is offline
Old 01-02-2013, 01:36 PM   #2
View firemanbill's Gallery67
Club: Smoky Mountain Aero Club
Friends: (64)
page 24 of your manual shows this, left in Aux 1 and right in Aileron channel.
page 14 of your manual explains some of the benefits, the ability to use differential being one of them. Another is the ability to center and trim each servo more accurately as they are on their own channels this way.
A much more preferred method in setting up your planes.
President - Smoky Mountain Aero Club, Sevierville Tennessee
Old 01-02-2013, 01:42 PM   #3
slipstick
Outstanding Contributor Award
Yes. Then that gives you the ability to use the ailerons as flaps (called flaperons) and other things like aileron differential (more movement up than down), very useful for some planes to counteract adverse yaw.
slipstick is offline
Old 01-02-2013, 03:35 PM   #4
As the others have said, it is a better way to do it for a number of reasons, sub-trim adjustment and differential being two of them. You don't need to use mixes, the Tx comes with pre-set 'wing-type' configuration for this very purpose.
Old 02-27-2013, 05:21 AM   #5
aerocal
Use the Wing type menu.Set it to 2 Ail.Look on the Monitor screen to see where to plug everything in.Once you set wing or tail configuration in Wing Type menu the radio will assign the positions they will be on the Rx.Go by what is on the Tx Monitor labels and not the Rx label.They may be different.The mixing of the second Ail will be done automatically by the Tx when it is set into the Wing Type.
aerocal is offline
Page generated in 0.07580 seconds with 26 queries
