Old 01-03-2013, 08:25 PM   #1
70sflyer
View 70sflyer's Gallery2
Club: Quiet flyers
Question Push Rod problem
Building a ARF,The push rods sent with are to short.ordered new one.old one .060 new one .072.It fits already in staled sleeve but alittle tight.What could be used for a lub so it moves freer .
70sflyer is offline
Old 01-03-2013, 08:55 PM   #2
hayofstacks
I'd either order the correct size, or see if I could hook the push rod wire up to a drill inside the sleeve.
hayofstacks is offline
Old 01-03-2013, 09:45 PM   #3
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
Don't lube it---all the lube does is attract dirt and dust and that will untimately
slow things up. worse.
Get the right size wire or install a bigger tube..
Helicopters don't really fly.......
They're just so ugly, that the earth repels them.
Heli Jim is offline
Old 01-03-2013, 11:08 PM   #4
View CHELLIE's Gallery13
Friends: (281)
Hi where do the push rods go to if they go to the Ailerons with sharp bends to them, dont use the push rods, install 2 seperate mini servos for the ailerons, i have had sticky ailerons with the tube and rod having sharp bends to them from the factory on some ARF planes, Hope that helps, Chellie
Old 01-03-2013, 11:27 PM   #5
hayofstacks
Most plastics now a days have "dry" lubricants embbeded inside them.
If you hook your wire into a drill chuck(sounds easier then it is...) it will clean it out well enough for the pushrods to move easier. Just keep it spinning until the rods slide in an out easy. Done deal, costs you nothing, and your ready to go. You could also try to do the same thing by heating up the rods with a head gun or lighter, but I like the friction from the wire better.
Old 01-04-2013, 12:37 AM   #6
Friends: (16)
I wonder if that dry graphite door lock lubricant would work? Or would it make it worse?
kyleservicetech is online now
Old 01-04-2013, 02:29 AM   #7
70sflyer
Club: Quiet flyers
Chellie,Two go to the elevator and one to the rudder.I might try a dry lub and if that will not work I will replace every thing.Thanks
70sflyer is offline
Old 01-04-2013, 04:09 AM   #8
xuzme720
c'mere Monkey
xuzme720's Avatar
Send a message via Yahoo to xuzme720
Friends: (8)
Those are usually pretty straight runs. just keep in mind the last thing you want is any binding. If the drill trick doesn't free it up, order the correct size. Nothing to lose by trying the drill trick though, you already have wire on hand! All you need is a drill.
Just call me X! (or Gary works, too.)
Another signature landing! Somebody help me find all the pieces...
xuzme720 is offline
HELP!!! RX problem!! wittpilot General Electric Discussions 13 10-11-2011 06:19 AM
Glitch / lock out problem!!!! Gee Power Systems 20 04-14-2011 03:29 AM
MSR carbon rod reinforced landing gear + permanent 250mAh Li-Po holder Thewyzardofdogz E-Flite Helicopters 1 03-19-2011 06:52 AM
Unpossible servo problem mclarkson RC Radios, Transmitters, Receivers, Servos, gyros 13 02-13-2011 12:45 PM
Using a push rod for the float water rudder? donjiskra Seaplanes E-Powered 3 02-07-2011 05:37 AM
Page generated in 0.25742 seconds with 33 queries
