| Power Systems Talk about motors, ESC speed controllers, gear drives, propellers, power system simulators and all power system related topics |
#1 | ||
TURNIGY TRUST 70A SBEC Brushless Speed Controller http://www.hobbyking.com/hobbyking/s...dproduct=19683 Turnigy® TRUST SBEC ESCs have a very flexible and broadly capable MCU, able to run all types of brushless motors. The large heatsink and simple PCB layout make heat dissapation consistant, enabling the ESC to be run at its limit, without failure. The ESC is program-card and transmitter programmable with clear and easy to understand instructions included. Default factory settings are; Brake: off Battery: LiPo Auto Detect Low Voltage: 3.2v (power down motor) Spec. Max Motor Current: 70A Max BEC Current: 3A BEC Voltage: 5.5v (Switching) LiPo: 2~6S NiMH:5~16cells Weight: 65grams Programming Options. Battery Type Forward/Reverse Soft Start LV Setting (Ignore, Reduce Power, Stop Motor) Timing (Auto, Med, High) Switching (8,16kHz) Factory Restore Or HobbyKing 70A ESC 4A UBEC http://www.hobbyking.com/hobbyking/s...arehouse_.html Specs: Constant Current: 70A Burst Current: 100A Battery: 2-6S Lipoly / 5-18s NiXX BEC: 5.5v / 4A Motor Type: Sensorless Brushless Size: 70 x 32 x 17mm Weight: 74g Programming Functions: Battery Type: Lipo /NiXX Brake: On / Off Voltage Protection: Low / Mid / High Protection mode: Reduce power / Cut off power Timing: Low / Medium / High Startup: Fast / Normal / Soft PWM Frequency: 8k / 16k Helicopter mode: Off / 5sec / 15sec (Start up delay) |
#2 | ||
Friends: (16)
[QUOTE=DCDetector;894822]I've got a Starmax MX2 55" and I'm needing to replace the ESC and need some help getting the right replacement. A Internet search shows it having either a 45A or 70A ESC with a 5A UBEC. I find different info on the same plane. I figure to be safe I should go with the 70A? I'm looking at 2 different ones at HK. Which looks to be the best choice and what should I be aware/warned of? Other options?
Castle Creations has a wide variety of ESC's with switching power supply type of BEC's. These units are several times more expensive though. I've got 10 of them, and all of them have been flawless in operation over the past five years. For what it's worth, these ICE series of ESC's also has data recording that records RPM, Watts, Amps, Volts, ESC Temperature, and a few other things. You download the info to your PC with the Castle Creations USB dongle. The CC software shows the information in a graph type of display. Or it can be downloaded to an excel spreadsheet. http://www.castlecreations.com/produ...oenix_ice.html |
#3 | ||
#4 | ||
Friends: (9)
#5 | ||
Friends: (18)
What's the difference to how many forums he posts on he will get more answers to his question to a specific plane that someone else will have.
![]() ![]() Those ESC on the starmax are not the best I replaced the one on my Starmax A1 skyraider after hearing others had problems with them. I went with a 60 amp from hobbypartz, and a separate UBEC to power all the servos. |
#6 | ||
Friends: (18)
DC did you ever check the watt's and amp's with the original setup?
That is a problem with starmax some of the planes seems they throw in whatever sizze esc they have on the assembly bench. Mine was a topfire 70 amp first run up it got hot and it was only putting out around 55 amps on the watt meter I tossed it. |
#7 | ||
Note to self: When connecting a battery to the ESC red does not connect to the red wire.
#8 | ||
Friends: (18)
Ya that is reversed for sure I can't say I am not guilty of doing something similar myself.
![]() Well you won't make that mistake again at least that's what I tell myself. ![]() New ESC and you will be on your way, and it looks like Dr.Kiwi gave you advice he knows power setups he does a lot of power testing. Good luck! |
| Everything You Wanted To Know About Electric Powered Flight | AEAJR | Beginners | 146 | 05-07-2013 03:24 PM |
| 100+ MPH Club | CHELLIE | Hi-Performance and Sailplanes | 1932 | 04-08-2013 02:16 AM |
| CG specs for 50mm jets by JPower, Skyangel, BlitzRC. ESC program instructions and FAQ | Joe 1320 | Electric Ducted Fan Jets | 2 | 07-31-2012 10:54 AM |
| Rock ESC - a new, open source ESC | hols | RC Radios, Transmitters, Receivers, Servos, gyros | 0 | 12-28-2011 12:56 PM |
| esc burn out ??? | arthersleep | General Electric Discussions | 4 | 09-12-2011 02:43 PM |
