#1 | ||
#2 | ||
If you're planning on using it in an electric model then it's likely that the ESC (speed control) you use to drive the motor will have a BEC circuit which supplies 5V to the receiver from the main power battery. No separate battery for the receiver needed.
Steve |
#3 | ||
Friends: (8)
I am going to reformat your message to make it easier for me to answer.
Originally Posted by rc.antz
Never heard of this radio receiver. Did you buy this as a package or did it come with an RTF airplane?
Pretty standard recommendation. Most receivers willo work with either 4.8V packs or 6V packs, but I can not be certain about yours.
BEST? Always an opinion, but frankly this is not a big deal. Any 4 or 5 cell AA pack should work.
But as Steve stated above, if you plan to put this in an electric airplane with an ESC, electroncis Speed Control, it will likey have a BEC on the ESC that will supply 5V to the receiver and you won't need that receiver pack.
It would be best if you gave us the rest of the picture. What are you planning to put this receiver in and what is the rest of the electronics that you plan to attach to it.
And be sure to start reading these. It will answer most of your questions. EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT http://www.wattflyer.com/forums/showthread.php?t=31368 > Six Keys to Success http://www.wattflyer.com/forums/showthread.php?t=18 |
#4 | ||
Originally Posted by AEAJR
http://www.jperkinsdistribution.co.u...lanet%202.4GHz
it came with: http://www.jperkinsdistribution.co.u...lanet%202.4GHz just wanted to see if anyone reading might be also using what i have
i just wanted to know if i'm restricted to using a NiMH or if i'm able to use the other sorts of batteries available out there with the specific receiver i have. also i'd take recommendations and gauge it with other available battery packs when i shop around for parts
i'm actually looking to start from scratch: a lot of members on the foamies are inspiring me to start my own project.
at this point, i only have receiver and transmitter as mentioned above and a funky plane design in my head if anyone reading this could also give a recommended shopping list for servos, battery packs, ESC, motor or any stuff i'd need to start my first foam plane with the receiver/transmitter i already have, it'd be much appreciated.
yup: while i was starting this thread, i already had these links open. alt+tabbing in between work hours, but i'm still not done
#5 | ||
Friends: (8)
Oh, you are in the UK. You should add that to your profile as you will get a lot of answeres that are USA based and do not apply in the UK. Or we will send you to sources here rather than the UK.
As for servos and such. That comes after you tell us about the design of the plane. 5" wing span? 5 foot wing span? 15 foot wing span? 2 ounces? 2 pounds? 20 pounds? Can't answer anything about servos, ESC, motors or batteries till we know the design. But based on your radio selection it will have to be a small aircraft as your radio/receiver seems to be short range. From the product description: The Planet T5 transmitter and R6M micro receiver have been designed for crystal-free operation with Park Flyer, indoor aircraft and small electric-type models. That implies short range. Probably less than 500 and maybe less than 300 feet. |
#6 | ||
actually i'm in california. i just started the forums today and i'll come around to modifying my settings in a bit. how about we try this: assume all the parts needed can be procured within 1 hr. from my place. with the transmitter and receiver i have, how would you go about making a simple delta wing? consider the receiver's specs:
#7 | ||
Friends: (8)
I don't design planes, I fly them.
I would go to the store, buy a Parkzone F27 Stryker PnP, put your receiver in it and fly it. |
#8 | ||
Club: CVMRCC, SEFSD
Do a Google search for free plans. Follow the instructions.
| Everything You Wanted To Know About Electric Powered Flight | AEAJR | Beginners | 146 | 05-07-2013 03:24 PM |
| How To Select Your First Radio | AEAJR | Beginners | 19 | 02-06-2013 06:07 AM |
| Parkzone PKZ1060 3-wire servo with OrangeRX FASST receiver? | g725s | RC Radios, Transmitters, Receivers, Servos, gyros | 0 | 03-01-2012 01:01 AM |
| 2.4Ghz Receiver "Brownouts" | E-Challenged | Power Systems | 38 | 11-12-2011 12:05 AM |
| LiFe vs Nih Receiver battery tests | kyleservicetech | RC Radios, Transmitters, Receivers, Servos, gyros | 23 | 07-08-2011 02:40 AM |
