Old 01-09-2013, 12:05 PM   #1
yamahafunkplayer
Club: Me, Myself & I
Friends: (4)
Default Durable landing gear for foamie?
Hi All... I am patching up my Airfield Hellcat (43"/1100mm WS ). She's been crashed so many times, but still wants to fly...but she needs feet.
THe original gear was wire with a plastic snap-in piece built into the bottom of the wing to hold it. didn't last long, as this was my 2nd plane.
My friend crashed his dynam c-47 and i put the wheels on my hellcat, but then prop clearance was a factor. with 11in prop, prop hits the ground when the tail rises. with 10 in prop, she flies too sluggishly for my liking.
So, after giving up and hanging her in the garage for 6 months, i decided to give her another go at a flying life... i took her down and did a lot of work to patch up the holes and mount a new motor, and some other mods.... but she still needs landing gear.
any ideas on building a sturdy gear for her? something that will last more than a couple flights? and tracks straight? (she has a steerable tailwheel)
-Gary
yamahafunkplayer is offline
Old 01-10-2013, 02:03 AM   #2
View CHELLIE's Gallery13
Friends: (281)
I know what your talking about Gary I had the same problem finding landing gear for foam planes that are Durable, the wire landing gear always bends and does not track right, and the plastic landing gear break after a few landings, so I had to make my own custom landing gear from aluminum stock and they work great I make them for profile and full body Planes, the aluminum is about 1/8" thick by 1/2" or 3/4" Wide or so its not to heavy but is very strong, My Son and myself are going to be makeing light weight but strong landing gear for foam planes, and selling them on EBay, what dimentions do you need on your landing gear, top width at fuselage, bottom width, and lenght from fuselage to ground, I may be able to fabricate a one piece aluminum landing gear for you, we are also makeing 2 piece custom landing gear for profile Foam Planes, the landing gear i have made for my planes work Perfect Take care, Chellie
My custom profile landing gear in the pic is 3/4" wide, i also make them 1/2" wide for smaller profile foam planes, i use thin plywood and spacers to mount the landing gear to the foam with, it makes the foam very strong at the landing gear mounting area.
Old 01-10-2013, 04:01 AM   #3
road king 97
old hat
road king 97's Avatar
Club: joliet rc club rt 66
Friends: (13)
-Gary
I go to my local hobby shop and look in the replacement landing gear section and most times i can find a gear that i can either do a little bending to make it work or i buy wire and make my own . I have a old steel rc wire bender but i can bend it by clamping in my vice too.Most of the replacement landing gear was under 6 dollars and a couple were under 2 bucks and both were with foam wheels. joe
road king 97 is offline
Old 01-10-2013, 04:16 AM   #4
road king 97
old hat
Friends: (13)
Or you can order another set http://www.nitroplanes.com/93a806-12...nggearset.html
Old 01-10-2013, 06:19 AM   #5
yamahafunkplayer
Friends: (4)
Default gear
Originally Posted by road king 97 View Post
thanks road king, for your advice.
i thought of ordering the replacements, but they didn't track very good, so that's why i decided not to do it. I may head to hobbytown and see what they have there that may work....
-G
Old 01-10-2013, 06:30 AM   #6
yamahafunkplayer
Friends: (4)
Default custom gear?
thanks, Chellie, for the offer. I may have to take you up on that. let me see if there's an off-the-shelf option first, then I will let you know...
then again, i may just get creative. (hellcat on floats )
just kidding...
-gary
Old 01-10-2013, 02:10 PM   #7
road king 97
old hat
Friends: (13)
Hey Gary If you Twist the gear so the wheels are toed in a little, it will fix your tracking problem . It also helps with a tail dragger to slowly feed the power to the motor ,it creates less tork that way. joe
Old 01-10-2013, 05:53 PM   #8
CNY_Dave
Some draggers like toe-in, some like toe-out, some like neither.
Tried all 3 on my bipe off pavement, out worked much better.
CNY_Dave is offline
Old 01-10-2013, 06:16 PM   #9
road king 97
old hat
Friends: (13)
I think over 100 tail dragger kits i have built all sad to toe in the wheels for better tracking . I dont know about your bibe tho. http://www.rmfm.org/ground_loop.htm
Old 01-10-2013, 06:33 PM   #10
CNY_Dave
There's a lot of 'geometry' going on, and it varies depending on what angle the plane is at when landing/taking-off, and what will work better for a skid vs a wheel (I had a wheel), and if you are in a high-traction vs a low-traction environment.
I know kits tend to say 'in' a little, but it's like jetting a motorcycle carb, the only way to know what works best for a given rider on a given bike on a given terrain at a given altitude is to verify all points 'away' from the current point (jetting, wheel-angle, etc) is worse.
Also, could be too much toe or variation in the amount of toe is not a big deal with toe-in, but can have terrible effects with toe-out (cars are like this).
I have seen excellent, and correct, geometrical arguments conclusively proving in is better, and have seen the same for out. My advice is if the recc method yields poor results, the heck with it, try something different.
My bipe was approx 5 lbs, very prone to ground loops on landing, low rudder effectiveness, and flying off pavement with very sticky tires. It could be if some or all of those could be 'corrected' in would be better than out, but some of that's just the way a Fokker D-VII is.
CNY_Dave is offline
Old 01-10-2013, 06:33 PM   #11
View firemanbill's Gallery67
Friends: (63)
This might work for you. Real tough yet light weight
http://www.millenniumrc.com/X-Gear.html
Old 01-10-2013, 06:39 PM   #12
road king 97
old hat
Friends: (13)
I have not bought a set of those yet Bill but they look nice. CNY DAVE now you know why i build these now, NO LANDING GEAR and plenty of runway on a big lake.lol joe
Old 01-10-2013, 06:42 PM   #13
Friends: (63)
Wow! that is gorgeous!
Old 01-10-2013, 06:46 PM   #14
road king 97
old hat
Friends: (13)
Thanks Bill it' 100 inch wing span and only weighs 8 pounds with two lipo packs. I did a build thread here on wattflyers 3 years ago.
Old 01-10-2013, 06:49 PM   #15
Friends: (63)
I'll have to re look at that thread.
Ya know, if you brought something like that to SEFF you would have a very good chance of getting best of show with it.
Very impressive.
Old 01-10-2013, 06:53 PM   #16
road king 97
old hat
Friends: (13)
Very impressive.
I want to go to seff soon after i retire next year, i have a 84 inch scratch twin otter iam now building and the same size albitross so by the time i go i will bring all three. Ivan is the master of e- flight ,check out the weights and wingloading of his planes plans .http://www.ivansplans.com/
Old 01-10-2013, 07:42 PM   #17
Friends: (63)
Would love to see you there! I went for the first time back in '07. This will be the 7th year in a row for me.
Best electric event on the planet!
Old 01-10-2013, 07:59 PM   #18
road king 97
old hat
Friends: (13)
I have another Ivan plans builder comming from the UK to seff this Year .He has a Ivans twin otter also ( Scott ) . He plans on stopping in chicago and visit me then see the US . I have to work.
Old 01-11-2013, 08:02 AM   #19
yamahafunkplayer
Friends: (4)
thanks for the tips. by the way, awesome seaplane! very impressive. i want to build a multi-engine plane someday. too bad im so allergic to CA. i was building from plans a "Forerunner" pylon racer.
Old 01-11-2013, 11:11 AM   #20
subzJC
flyer
+1 on Chellies landing gear.
I do the same thing and they are stout.
Instead of ply I use countertop laminate between the
gear and the fuse to help strengthen the fuse and it
also helps to cushion a less than greasy landing.
This way you can customize the height and width to your needs.
Good Luck!
subzJC is offline
Old 01-11-2013, 02:02 PM   #21
road king 97
old hat
Friends: (13)
Thanks Funkplayer ,I have good news for you if you want to build .I havent used CA in 10 years ,i use tightbond 2 for my seaplane and all my builds . I use epoxy on landing gear blocks and motor mounts/wing joints but every thing else is tightbond wood glue. Ca does not sand well and when tightbond glue dries its lighter that ca. Tightbond glue does not get brittle and crack either like ca does. If you ever need any plane plans i probly have over 3000 free plans to choose from in a download. Just pm me any time.Good luck with those wheels they can be a pain in the ars. joe
Old 01-12-2013, 04:38 AM   #22
rcmad
RC MAD!
I've got some nice looking dubro ones, but they don't come in many sizes
rcmad is offline
Old 01-14-2013, 12:23 PM   #23
yamahafunkplayer
Friends: (4)
thanks, road king... going to try the wood glue. even having bad reactions to loctite super glue (it's more or less CA too) so this is good news. may start building a stick from scratch for the next one. thanks for the links to the plans too!
as for landing gear.. i'm going to hot glue a small wood block under the fuse (cutting out some foam to make it flush) and screw on the landing gear from my otherwise destroyed eflite sukhoi. --let you know how it works...
Old 01-14-2013, 02:18 PM   #24
road king 97
old hat
Friends: (13)
I would sand a flat spot and then epoxy the ply plate on it. If you ever looking for any plan just pm me i most likly have it or know where to get one. lol joe
Old 02-26-2013, 01:46 PM   #25
yamahafunkplayer
Friends: (4)
i made a flat spot and hot glued some balsa in place, used a couple wood screws to hold on alum landing gear from my crash eflite-su26. held up pretty well, took 2 rough landings and needs re-glued, but otherwise is working ok.
Tags
foamie , hellcat , ideas , landing gear
OK Who Crashed today ? Besides me :) CHELLIE Crash and Safety Forum 1381 05-24-2013 12:40 AM
Landing gear for my powered glider dgjessing ParkFlyers 0 07-27-2012 11:56 PM
my mini ultra stick escapades hayofstacks Crash and Safety Forum 0 03-05-2012 12:07 AM
Projet f4 retractable landing gear tires lvjet Electric Ducted Fan Jets 0 05-29-2011 04:49 PM
MSR carbon rod reinforced landing gear + permanent 250mAh Li-Po holder Thewyzardofdogz E-Flite Helicopters 1 03-19-2011 06:52 AM
Page generated in 1.15927 seconds with 73 queries
