Old 01-10-2013, 01:27 AM   #1
wreckerdrvr
wreckerdrvr
Default ? about mpi arming system
I'm new to all this so I have a lot of dumb questions. I recently bought a used nitro plane that I'm converting to electric. I plan on using a 6s battery that I want to leave in the plane to charge. Can I charge through the arming switch? It looks to me that the esc would be getting the charge as well. Wont that.burn up the esc
wreckerdrvr is offline
Old 01-10-2013, 04:39 AM   #2
2013 President of PSSF
No, you need to connect directly to the pos and neg of the battery. Can not do that through the arming switch.
You should plug a lipo balancer into the balance jack of the battery.
Some lipo's have gone up in flames while charging, we do not recommend charging in the plane. it also should be done while the battery is in a fireproof lipo charging bag.
Dave R, Proud PGR rider.
Wildflyer is offline
Old 01-10-2013, 05:55 AM   #3
Friends: (16)
Nope, dumb questions are the ones asked AFTER burning something up.
You've probably read about those LiPo fires on our electric models. IMHO, most if not all of these fires were a direct result of improper charging of these very high powered batteries.
One thing to watch for is for these batteries, especially the larger 6S type batteries, getting way out of balance while charging. Getting out of balance is very hard on these batteries, and likely increases the chances of a fire.
The newer high performance LiPo chargers have built in automatic cell balancing features that do the cell balancing act while the charge process is taking place. (I've got the Cellpro Powerlab 8 charger, for charging a 6S4P 2300 Mah A123 battery pack. The charge rate is set at 30 Amps. These A123's are configured as a 12S2P pack while in flight)
If you charge these batteries without those balance wires hooked up, you increase the risk of cell damage, or much worse, battery fires.
If this is your first run at high powered electric models, perhaps the following threads might be useful???
AEAJR's Site on Electric Power
http://www.wattflyer.com/forums/showthread.php?t=18521
BEC Linear Current Rating
http://www.wattflyer.com/forums/showthread.php?t=63497
Old 01-11-2013, 02:05 AM   #4
Turner
You can charge a small receiver pack - usually NiCad or NiMH - through the arming switch harness but not the flight pack.
Turner is offline
What is FASST ? Birdmanpete General Electric Discussions 40 01-10-2013 11:57 AM
For Sale FMA CoPilot CPD4 Auto Stabilization System ShokWaveRider Radio Equipment For Sale & WTB 1 09-17-2012 08:16 PM
For Sale WTS: FMA Co Pilot II, 4 Channel Flight Stabilization System raitheslacker Radio Equipment For Sale & WTB 1 09-17-2012 08:13 PM
I need a real time video system for my Radian AEAJR Aerial Photography 20 09-27-2011 10:07 PM
Giant Scale Electric Backup Battery System kyleservicetech RC Radios, Transmitters, Receivers, Servos, gyros 12 05-23-2011 06:47 PM
Page generated in 0.21338 seconds with 25 queries
