Old 01-11-2013, 06:25 PM   #1
Westwind
Default Servo issue
I'm installing my servos and found that one servo arm will not sit at a 90° from the servo sure to the position of the gear. The servo is centered. I think I might be able to trim it to center buy I wil lose some deflection. Is there a way to manually adjust the servo gear?
Sent from my GT-I9000 using Tapatalk 2
Westwind is offline
Old 01-11-2013, 06:37 PM   #2
Turn the arm through 180 degrees.
JetPlaneFlyer is online now
Old 01-11-2013, 06:57 PM   #3
Westwind
Default Re: Servo issue
Tried that nil fix
Westwind is offline
Old 01-11-2013, 07:30 PM   #4
2013 President of PSSF
We used to be able to adjust the feedback pot, but not in new servps.
If your transmitter has sub trim, you should be able to adjust to center without loss of movement.
If you don't have sub trim, it may be alright as it is, unless it is a highly critical plane.
Unfortunately not all servos are made with an odd number of splines which allow us do adjust arm position by turning the arm 180 degrees.
Dave R, Proud PGR rider.
Wildflyer is offline
Old 01-11-2013, 08:20 PM   #5
you could trim it (or better sub-trim).. you wont lose any travel.
If it still bothers you you could open the case and turn the output gear a tooth, but they can be a little tricky to get back together as there are several tiny gears on two or three shafts.
Old 01-11-2013, 08:36 PM   #6
Westwind
Thanks guys, I'll try the sub trim
Westwind is offline
Old 01-17-2013, 09:06 AM   #7
Seems some have forgotten that servo arms are in different offsets ...
The answer is to get ALL servo arms supplied with the servo ... you try ALL of them in different positions until you find the one that is 90 deg. Sometimes it's ONE of the arms of the 4 arm ... you just have to cut of the other 3.
Some arms used to have numbers moulded into the arm ... this was the number of degrees offset from 90.
It is best to find the correct arm instead of using sub-trim etc.
Unusual servo behaviour; tx / rx issue? Tom Sawyer RC Radios, Transmitters, Receivers, Servos, gyros 7 06-13-2012 09:05 AM
The Extreme Flight Edge 540T-EXP ARF-48 x-nitro 3D Flying 11 03-16-2012 02:13 AM
old airtronics servos? k-vette RC Radios, Transmitters, Receivers, Servos, gyros 9 02-06-2012 01:13 PM
3S or 4S Battery Question(s) RCFlyer44 Power Systems 22 03-29-2011 04:55 AM
servo zero, angle of the dangle, and flight surface equal travel DanWard Beginners 4 02-10-2011 04:57 AM
Page generated in 0.21276 seconds with 31 queries
