Old 01-15-2013, 01:11 AM   #1
LowThudd
Default Versa Hybrid Supercraft
So I finally recieved my Versa Land/Sea plane(holiday delays, on my part and the seller). Here is a link to it: http://www.parkflyers.com/Versa_Hybr...rc-electri.htm
First off, the antenna on the RX is extremely short. Like 1.5". Can I use standard wire to extend it? There appears to be a hull plug to put the antenna through in the aft hull. Any advice on this would be appreciated.
Second, the RX that came with the plane is a 6CH, while the TX is 4CH. There are impressions in the wing to make flaps, so I am assuming that is why it has a 6CH RX. The obvious problem is the TX is only 4CH. I tried identifying the TX/RX through the FCC ID and came up flat. Is there any other way to ID the TX/RX system?
Also, since the flap servos would be on the wing underside, they need to be small. Any recomendations as to what size?
I'll probably have more questions later, but that is a good start. lol
TIA
LowThudd is offline
Old 01-15-2013, 02:34 AM   #2
pmullen503
DON'T change the antenna! It's normal for 2.4G antenna to be that short. The hole was probably for a long 72mHz antenna.
No idea of the TX make but if you want to upgrade you'll need a new TX anyway so just get a RX that matches your new TX.
Cheap 9 gram or 5 gram servos will be fine for flaps.
pmullen503 is offline
Old 01-15-2013, 03:32 AM   #3
LowThudd
Thanks. Will do. I am planning on upgrading the TX, but not till next month some time. I guess I'll save the flaps install till then.
LowThudd is offline
Old 01-16-2013, 12:00 AM   #4
LowThudd
Here is an odd one. The RX was installed inside a balloon(yes, like the blow up kind). Needless to say the balloon needed to go since the bind plug was not installed. Should the RX be put in a balloon after binding? I won't be pond surfing anytime soon, but just wondering if this is a normal method with seaplanes.
LowThudd is offline
Old 01-16-2013, 02:37 AM   #5
gramps2161
gramps2161's Avatar
View gramps2161's Gallery9
Friends: (18)
They put it in a balloon to protect it from the not so good landing on water AKA dunking.
gramps2161 is offline
Old 01-16-2013, 02:44 AM   #6
LowThudd
Yea, I figured that. But being that the balloon was zip tied closed WITHOUT the bind plug attachedto the RX, there would be no way to use the balloon.
So I guess I will find a better way to water proof it before water flights. Or just buy some balloons. lol
LowThudd is offline
Old 01-16-2013, 03:03 AM   #7
LowThudd
Just found out this model seems to be based on this prospective aircraft(real): http://www.iconaircraft.com/index.html
Very cool plane!
LowThudd is offline
Old 01-16-2013, 03:07 AM   #8
gramps2161
gramps2161's Avatar
Friends: (18)
Lowthudd you can get corrosion x to protect the electronics. It is a liquid that you dip the ESC and TX it helps protect the electronics from water.
Old 01-16-2013, 03:10 AM   #9
LowThudd
Great! Thanks, will do. Prolly a good idea on the underwing servos, even though they do have splash shields.
LowThudd is offline
Old 01-16-2013, 03:24 AM   #10
stuart
stuart's Avatar
Outstanding Contributor Award
Friends: (12)
lowthud,don't follows gramps advice on dunking the tx in corrosionx.....lol[he's old like me and meant rx...].....stinks getting old eh gramps?
stuart is offline
Old 01-16-2013, 03:37 AM   #11
LowThudd
I figured RX. lol I'm not that newb.
LowThudd is offline
Old 01-16-2013, 05:08 PM   #12
Rockin Robbins
Rockin Robbins's Avatar
Friends: (7)
Looking forward to flying impressions on this plane!
Rockin Robbins is offline
Old 01-16-2013, 07:22 PM   #13
gramps2161
gramps2161's Avatar
Friends: (18)
Dang no wonder my planes wgt. so much, and the control sticks seem so floppy when I try to use em. I got it all backwards.
LowThudd glad you knew what I was talking about hate to see your TX sitting in a 5 gallon pal. of corrision x.
Old 01-18-2013, 07:00 PM   #14
LowThudd
Next question. My controller has a training port(3.5mm). The instructions don't cover it. I am assuming that this can be used as a "Buddy box", and also for simulator. How do I hook up to the PC? USB adapter?
LowThudd is offline
Old 01-19-2013, 04:21 AM   #15
LowThudd
Another. I finally got all the servos adjusted as best I could without taking it out. And even with very limited motor use, the ESC got pretty warm. It is a 18A ESC, but there is no airflow through the inside of the fuse, as it is a seaplane. Should I try putting a heat sink on after removing the plastic cover on the ESC? Should I get a higher amp ESC? Or (other)?
Also, the servo rods seem to stick a slight bit going through the plastic tubes. Should I lube the rods?
LowThudd is offline
Old 01-19-2013, 12:55 PM   #16
riverrat
circa: 1946
riverrat's Avatar
Club: NRA Life Member
Friends: (22)
Default Versa
Ditto!
riverrat is offline
Snowdragon - coroplast/FFF KF hybrid. mclarkson Scratch and Kit Built Aircraft 8 01-03-2013 02:51 AM
Sold SOLD Bnf fbl trex 450 pro hybrid w/ skookum 720 raitheslacker Helicopters- Electric For Sale & WTB 3 04-08-2012 10:20 PM
The Bitsa Hybrid plane Wrench66 Scratch and Kit Built Aircraft 2 02-14-2012 11:24 PM
Page generated in 0.36763 seconds with 49 queries
