Old 01-16-2013, 10:42 PM   #1
Gary H
Gary H's Avatar
Default Kit for a 370 size motor.
I accidentally ordered the wrong motor for a foamie, but being a kit builder I hate to see it go to waste. I don't know a lot about electric planes, but have bee around for awhile. What I'm looking for is a high wing trainer that is 4 channel and has no bad habits. I'm thinking of the Herr Cloud Ranger, but they suggest a 270 size motor?
Thanks in advance.
Gary H is offline
Old 01-17-2013, 02:01 AM   #2
View CHELLIE's Gallery13
Friends: (281)
Thanks in advance.
Tell us a little about the 370 motor you bought,direct drive or geared, the gear ratio if its geared, the KV/RPM per 1 volt, brush or brushless, size, thats important in trying to find a plane for it,
if its a brushless motor, here are some specs that you can use,
1000KV motor
http://www.headsuprc.com/servlet/the...h-10%29/Detail
1350KV Motor
http://www.headsuprc.com/servlet/the...h-14%29/Detail
Old 01-17-2013, 02:06 AM   #3
Friends: (281)
also tell us a little about the plane, size, etc, is it this plane, if it is, you will need a 400 size 1000 to 1350KV motor. if your 370 brushless motor is direct drive and is 1000 to 1400kv, it will work, but it will be a little under powered.
http://www.sigmfg.com/IndexText/HRR508.html
Mini Radio Rec.3 or 4 Channel R/CWingspan42in (1067mm)3 Channel Area296in² (19.1dm²)4 Channel Area324 in² (20.9dm²)Glow PoweredElectric PoweredWeight16.5oz
468gWeight22.2ozWing Load
3ch8.04oz/ft²
2453g/m²Wing Load
3ch10.82oz/ft²
3302g/m²Engine.049-.061in³
.80-.99cm³EngineSpeed 400class
Old 01-17-2013, 02:08 AM   #4
Gary H
Gary H's Avatar
Thanks CHELLIE. I plan on going with direct drive and this is the motor.
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
Gary H is offline
Old 01-17-2013, 02:23 AM   #5
Friends: (281)
that will work, use a 30 amp turnigy ESC, they are bullet proof IMHO using a larger esc than what is needed will make the ESC last longer and it will stay cooler, a 1300mah 25c will work great too.
http://www.hobbyking.com/hobbyking/s...ontroller.html
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Old 01-17-2013, 02:33 AM   #6
Friends: (281)
use the XT60 connectors rather than deans, they are easy to take apart and put on, they are rated at 60 amps, and the lipos from HK come with the XT60 connectors, i buy them with the leads already on, so its easy to solder on, no messing with the connector ends, just one wire you will need the female and male connectors,
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
Old 01-17-2013, 02:38 AM   #7
Friends: (281)
with your 370 motor use a 8x4 or 8x5 prop on 3 cells, no larger than a 8x5 e Prop.
Old 01-17-2013, 03:03 AM   #8
Gary H
Gary H's Avatar
Thanks CHELLIE. Besides using the higher amp ESC, I was pretty close in my guestimation. I had built a Cloud Ranger before with a TT .074? Anyway a little nitro motor, but never flew it. I sold it. I covered it with this.
http://www.stevensaero.com/AeroLITE-p-1-c-39.html
It was a nice build. Perhaps Ill do a build thread on it here if anyone is interested.
Gary H is offline
Old 01-17-2013, 03:11 AM   #9
Friends: (281)
That covering will work great, Sure do a build thread, that will be fun reading, Take care and have fun, Chellie
BTW, if your looking to build from Foam, foam builds fast and is fun, here are a few of my builds.
http://www.wattflyer.com/forums/show...652#post715652
Old 01-17-2013, 03:23 AM   #10
Gary H
Gary H's Avatar
Will do. Ill probably order the kit this weekend. I saw a video on this plane and fell in love with it. Sorry it's nitro. And it's not totally PC, but is funny.
http://www.youtube.com/watch?v=6cl6YWqi0LY
Gary H is offline
Old 01-18-2013, 04:58 AM   #11
Bill G
Super Contrubutor
Bill G's Avatar
View Bill G's Gallery82
Club: rcg staff
Friends: (17)
Thanks in advance.
I did that one and sent it to Chellie. It had a kv rating more in the line of a pusher jet. Thought that was the answer you would give him Chellie.
Good info to look at is a build thread, and hope the person posted detailed info. I'd rather see what exact weight they needed to balance the plane and how it flew, versus a manufacturer's generic spec sizing. The specs on some of the motors out there aren't exactly accurate to begin with, so you're never exactly sure if a motor is the "right" one, even if it claims to be in spec.
Bill G is offline
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 146 05-07-2013 03:24 PM
Everything You Wanted To Know About Electric Powered Flight AEAJR General Electric Discussions 255 01-03-2013 11:49 PM
For Sale Aluminum Motor Mounts for Multiplex, Parkzone, and Flyzone Super Cub Planes terrynshed Motors and Speed Controllers for sale & WTB 4 09-24-2012 05:33 PM
For Sale Aluminum motor mount for Flyzone Select Scale Super Cub and 450 size motor terrynshed Motors and Speed Controllers for sale & WTB 43 09-04-2011 04:32 PM
Page generated in 0.25179 seconds with 39 queries
