Old 01-16-2013, 10:58 PM   #1
dopey190
Build Review Need prop help for Super Cub
Putting together an brushless upgrade and have been doing alot of reading and can not find an answer for the right prop. I put a 480 eflite, I have a couple of 9x6 props. But i think I would have to drill them out for them to fit. Also how in the world does the spinner stay on the shaft lol. Thanks
dopey190 is offline
Old 01-16-2013, 11:10 PM   #2
The spinner back plate gets sandwiched between the prop adapter flange, the prop hub, and the retaining nut/washer. Some spinners have the back plate behind the prop hub and some in front.
The spinner cone either fastens to the backplate with screws or sometimes is retained by a single screw through the middle that screws into a special nut that goes on the end of the prop adapter shaft.
I've got a feeling that I've probably lost you on this but without drawing a diagram it's hard to explain any better.
I take it that you have hot a prop adapter fitted to the motor/shaft?
JetPlaneFlyer is online now
Old 01-16-2013, 11:13 PM   #3
dopey190
Not sure about the prop adapter? I have whatever they gave me in the bag that it came with. Figure I would find the right prop and then figure out how to put it on.
dopey190 is offline
Old 01-16-2013, 11:18 PM   #4
So when you put the prop on what are you fitting it onto exactly?
Old 01-16-2013, 11:23 PM   #5
here's a pic:
There are three components in the photo:
  1. The motor itself
  2. The cross mount (used to mount the motor to the plane but only if motor mounts in front of the mount plate)
  3. The prop adapter (fits over motor shaft)
Old 01-16-2013, 11:25 PM   #6
dopey190
Ok got that now, the million dollar question is which prop?
dopey190 is offline
Old 01-16-2013, 11:30 PM   #7
A 10x6 for the 910Kv version or a 9x6 for the 1020Kv type should be in the right ballpark assuming you are running a 3s Lipo
Go up and inch if using a 2s lipo
Old 01-16-2013, 11:31 PM   #8
dopey190
Thanks!
dopey190 is offline
Old 01-18-2013, 04:05 PM   #9
darkfire3814
Your local shop should be able to get what you need
darkfire3814 is offline
Welcome New Members to Wattflyer - We ONLY do electric flight here! admin General Electric Discussions 5327 04-04-2017 05:22 PM
Parkzone u/m j3 cub: RONALDO_UK Beginners 8 09-26-2012 06:18 PM
Dunam HAwk sky glider with grayson v2 pusher upgrade Prop problems Alabama Flying Dude Pusher Park Jets 3 05-19-2012 04:13 PM
3mm prop adapter impossible? Prop saver issue? mclarkson General Electric Discussions 12 11-26-2011 10:09 PM
Page generated in 0.09868 seconds with 35 queries
