Old 01-17-2013, 08:29 PM   #1
dopey190
Default Need brushless help again
How in the world does this setup work, I cannot for the life of me figure out how this stays on the motor shaft securely.
Theres no place to tighten down the adapter, I know this is probably really simple to do.
The 3rd pic is the adapter and spinner correct?
How can I secure the adapter on the motor shaft as pictured in pic 2?
And what is all of this junk in pic 1.
ID:	165635   Click image for larger version
ID:	165636   Click image for larger version
dopey190 is offline
Old 01-17-2013, 09:23 PM   #2
BBCorvette18
You slide the prop adapter over the shaft. When you tighten the prop the adapter squeezes the motor shaft. It basically works the same way a drill holds a drill bit.
BBCorvette18 is offline
Old 01-17-2013, 09:30 PM   #3
subzJC
flyer
and use one of the allen wrenches through the spinner to tighten it up.
nice looking motor and standoff too!
good luck
subzJC is offline
Old 01-17-2013, 10:01 PM   #4
dopey190
And Im guessing these 9x6 props from the brushed motor need to be drilled to fit? Or just buy the props that fit correctly?
dopey190 is offline
Old 01-17-2013, 10:05 PM   #5
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
Props that fit correctly!!!
They MAKE props that fit correctly?
How come none of mine do?
fly
flydiver is offline
Old 01-17-2013, 11:48 PM   #6
BBCorvette18
Yea just drill to fit. Make sure you get it as close to straight as possible
Old 01-18-2013, 12:55 AM   #7
Yeah, some props must be drilled to fit. The APC-E Electric props come with a set of interchangeable "Bushings" that adapt to the size of your motor's shaft. Or, if you have a Harbor Freight store in your area, check out their supply of "Number" drills, or their complete set of fractional, letter and number drills. These are of fair quality, but entirely sufficient to handle this type of project. If you have one of those cheap drill presses, this will make the drilling out the hub far easier.
As for that prop adapter, the double clam shell type of bushing is several orders of magnitude better than those cheap, simple set screw type of prop adapter.
For Sale E-Flite Power 15 Brushless Outrunner 950KV & 60A brushless ESC EXTRAMAN13 Motors and Speed Controllers for sale & WTB 0 07-14-2012 04:02 PM
Why do I want brushless? RobWoodall Beginners 8 05-29-2012 11:23 PM
Best Brushless for 'Slow' MiniMag? deandome Beginners 3 03-17-2012 10:23 AM
For Sale Walkera 4g3 Dual Brushless & metal d&mrc Helicopters- Electric For Sale & WTB 7 03-16-2011 08:35 PM
do brushless motors ever die????? Flysohigh Power Systems 3 03-07-2011 02:55 PM
Page generated in 0.27599 seconds with 36 queries
