#1 | ||
I'm going to set as advised, then see if that looks 'ok' when I check it on the wing. |
#2 | ||
That makes no sense at all. The wing will likely move the balance point back a bit when you install it so balancing without the wing in place is pointless.
It will also be harder to do as you wont have the underside of the wing to support the model from. |
#3 | ||
Friends: (63)
Yeah that does not make sense at all unless the balance point is exactly half the wing cord.
Still, I think I would want to balance it via the traditional method. |
#4 | ||
Yeah, I generally ballance my planes to the main spar, or about 1/3rd back from the leading edge.
#5 | ||
Friends: (63)
#6 | ||
This is a 1970s vintage midwest kit that I'm converting from gas, on the plans a big arrow points to the bottom of the fuse about 1/3 back from the front of the wing, manual says to balance with the wing off.
Balancing it is easy, just put a block of wood with a dowel on top under the fuse, if it's balanced it'll take a while to tip either way. |
#7 | ||
Friends: (63)
Interesting, I'd be curious to see where it balances once the wing is on based on doing it that way. I'd say it will be right where one is normally balanced, about a 1/3rd way back or so on the wing
#8 | ||
2013 President of PSSF
They probably are giving a balance point that you would have, if you balanced the plane the "normal" way then removed the wing and checked where the fuselage would balance without the wing.
Doing it this way on some models, makes it easier to insert the battery or weight to balance, without taking the wing on and off every time you try a different position. I have a carrying handle that bolts in place of the wing on my 63" Sig LT-25, it is marked where the body with the battery should balance. I use several different packs in this plane, so it is easier than having the wing in place. And in case you think his instructions are strange, look at the way the manual told how to balance the Hobie Hawk. |
Dave R, Proud PGR rider.
When you have flying skills like mine, ![]() You become a master at repair.
#9 | ||
Since this model has not been covered with monocote, but is all balsa and fiberglass, I wonder if the wing's contribution is different?
#10 | ||
Friends: (63)
Originally Posted by CNY_Dave
good point, anything that changes the original specifications weight wise could throw off the CG setting it with the wing off.
Both my cubs, a 40 size Hangar 9, and a 1/4 scale PA-12 balance right on the main spar. I'd say you would be safe setting it about that point. It will be flyable enough and you can tweak it from there. |
| Parkzone Extra 300 Upside Down Wings *HORIZON LEAVES US IN THE COLD* | jaskel | Foamies | 157 | 10-07-2012 02:48 PM |
| B-47 1/10.2th Scale, Boeing Stratojet...In The Beginning | Flite-Metal | Electric Ducted Fan Jets | 525 | 08-25-2012 04:49 PM |
| CG specs for the 35mm EDF jets by Jpower, Skyangel, Blitzrc, etc. and FAQs. | Joe 1320 | Indoor & Micro Electric Planes | 7 | 07-01-2012 02:20 AM |
| Wanted plans for Wing mfg Mitchell B25 84” pro kit | peluni1 | Airplanes - Electric For Sale & WTB | 0 | 03-31-2012 04:12 PM |
| Crazy idea? | WayneG | Hi-Performance and Sailplanes | 21 | 05-29-2011 08:37 PM |
