Old 01-23-2013, 04:03 PM   #1
foamcruncher
foamcruncher
Default noob help binding Turnigy 9x with Dsm2 rx
Noob electric flyer , looked in everything possible to solve a no bind situation with new Turnigy 9x with Dms2 orange rx . you tube vid. no bind . text , no help. both units are new , I just think this old dog needs to learn a few new tricks !! Any assistance is welcomed , thanks for the help .
foamcruncher is offline
Old 01-23-2013, 04:42 PM   #2
The Turnigy 9x uses Flysky protocol which is completely different to Spektrum DSM2. The two cannot work together unless you put a DSM2 module in the transmitter, which I think if possible requires some modification work, plus the new DSM2 module.
Much easier just to use a Turnigy 9X receiver, no?
Old 01-23-2013, 04:50 PM   #3
foamcruncher
foamcruncher
thanks for the speedy reply to my delima , looks to me like I didn't get on the forums ahead of my decision to buy the wrong rx . thanks for the help , will use rx as suggested , learned to ask first to people that know .
Old 01-23-2013, 04:58 PM   #4
LowThudd
You can get an Orange JR module for the 9x at HK: http://www.hobbyking.com/hobbyking/s...mpatible_.html
But, IMHO it is better to get RXs to match the module, rather than different modules for different planes.
I will be upgrading my 9x(when I get it) to a FrSky module. Much better range, telemetry as well as many RXs to choose from.
Great prices here: http://www.alofthobbies.com/jr-trans...ry-module.html
If you get a new module, make sure it is a JR type, not a Futaba type.
LowThudd is offline
Old 01-23-2013, 06:22 PM   #5
pmullen503
If you bought the 9x with the module attached, it's Flysky and it would have come with a receiver.
If you bought the version without the module then you can use what you want. One thing: the 9x defaults to Futaba channel order. If you use OrangeRx module and receiver the failsafe will be on the wrong channel for the throttle. You can fix this by upgrading the TX firmware but that's another topic.
My advice is to go with Frsky. (BTW, Frsky and Flysky are two different, incompatible systems.)
pmullen503 is offline
Old 01-24-2013, 02:12 PM   #6
Join this group : http://groups.yahoo.com/group/Flysky_RC_radio/
Second ... either fit the Spektrum compatible Tx Module to use the Rx you bought ... or as another suggests - install FrSky Module and FrSky Rx ...
Yes you can go FlySky factory if you want - but personally the FrSky gear provides one of the best systems and at prices that are pleasing to the pocket.
There are plenty people who will buy the Spekie Rx of you I'm sure.
Old 01-24-2013, 07:30 PM   #7
foamcruncher
foamcruncher
Default thank you
it's great to see so much expierence and know how from fellow modelers. the willingness to help is encourging to an uninitiated to electric r/c convert like me . thanks for the sugestions and links . plan on adding Frsky DJT module and foward from there. thank you all .
Old 01-24-2013, 07:41 PM   #8
LowThudd
I'm new too. Just did a lot of reading on the 9x. still learning.
Here are some more 9x links for you:
http://9xforums.com/forum/
http://www.rchacker.com/projects/turnigy-9x
http://www.rc-cam.com/forum/index.ph...-project-blog/
http://www.hacksmods.com/category/turnigy-9x/
http://www.ersky9x.net/
http://9xforums.com/wiki/index.php/F...t_1_-_Hardware
LowThudd is offline
Old 01-25-2013, 01:41 AM   #9
The 8 Ch recievers for the 9x cost less than $10 anyway. I just buy them and have never had any problems.
Old 01-25-2013, 04:32 AM   #10
All good ... but also note that most cater for the modification people ... particularly those who re-program (reflash) the 9X ...
The Yahoo group I started was more for those who do not reflash the 9X and leave as original. Not everyone wants to reflash and i thought to collect together as much info / experience of users to help those who start with their 9X and then they can decide what they thrn want to do.
The FrSky module installation uses the basic or reflashed 9X .. is the simplest and best you can do ... with no need of programming or electronic skills.
There is one aspect that may need sorting ... the pins in the Tx slot on the later models - some have raised plastic that stops the module sitting fully in. My Turnigy 9X has that and I ground the plastic away flush to the case ... The FlySky module has a recess that allows that plastic .. but FrSky has no recess ... Sounds worse than it really is ... very simple to cure.
Phoenix Sim Turnigy 9x kidhickey Flight Simulators 2 12-12-2012 01:47 AM
Turnigy 9x now barebones without module solentlife RC Radios, Transmitters, Receivers, Servos, gyros 6 11-18-2012 09:47 PM
Turnigy 9x arming question Beemerider RC Radios, Transmitters, Receivers, Servos, gyros 4 05-23-2012 06:08 PM
Binding to multiple rx. Doclove524 RC Radios, Transmitters, Receivers, Servos, gyros 7 03-09-2012 04:38 PM
Page generated in 0.26053 seconds with 37 queries
