Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Pusher Park Jets
Old 01-24-2013, 09:15 PM   #1
Davethebluessinger
Child of the 60s
Davethebluessinger's Avatar
View Davethebluessinger's Gallery4
Club: None
Friends: (9)
Default Motor and prop for HK BD-5 pusher?
Looking at one of these
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Total flying weight is appx 800g and HKs recommended setup is 2200 3S with a 28mm inrunner @ 300W but HK in the UK have only one motor on offer of the right size and wattage (the HK Donkey) and that's designed for a car.
I've seen one of these being flown for FPV on youtube, the guy had fitted an outrunner, OK not pretty but it seemed to fly OK!
Can anyone suggest a good motor and prop setup for this plane please? Ideally for some general sport flying.
Dave
HK Mini Spirit, Flying Wings Mini Raven, FT Versa Wing, HK WingWing, Yuneec Q500, RCTimer 450 Spider, Eflite 200QX, Eflite UM Habu, Eflite Sport Cub, Eflite Whipit, HK Phoenix 2000, Dogfighter SPAD, Stryker F27Q
Davethebluessinger is offline
Old 01-24-2013, 11:32 PM   #2
View CHELLIE's Gallery13
Friends: (326)
Hi Dave darn, your in the UK, i was going to suggest a motor from HURC, but he does not ship over seas, here are some motors that will work.
the turnigy 2836 2350KV 480 Watt motor would be my first Choice, with a 60 amp turnigy Plush or Sentry ESC, to keep the ESC cool, its a power house, you can also use a heli motor with a 28mm outside can, with 1900 to 2500KV
http://www.hobbyking.com/hobbyking/s...er_2350kv.html
use a 6x5.5e prop with the Turnigy 2836 2350KV motor, there is more info in the Video below. Hope that helps, Chellie
http://www.hobbyking.com/hobbyking/s...er_2100KV.html
Old 01-24-2013, 11:51 PM   #3
Friends: (326)
http://www.youtube.com/watch?v=pvOkU5XWXtQ
Old 01-25-2013, 02:36 PM   #4
Davethebluessinger
Child of the 60s
Club: None
Friends: (9)
Thanks Chellie,
The 2836 - 2350kv is in stock in the UK. One question though, do you propose I mount this INSIDE the firewall like an inrunner? If so I think that the diameter of the motor will be pretty close to the inside of the pod. If that’s the case I’ll probably have to route the motor wires outside the fuse and bring them back inside in front of the motor or they will foul the motor case. I notice that HK rate this motor as giving 800g of thrust. Given that the plane is also 800g this will give a 1 to 1 thrust/weight ratio. Is that going to be adequate for some spirited sport fun?
Old 01-25-2013, 08:05 PM   #5
Friends: (326)
Originally Posted by Davethebluessinger View Post
Thanks Chellie,
The 2836 - 2350kv is in stock in the UK. One question though, do you propose I mount this INSIDE the firewall like an inrunner? If so I think that the diameter of the motor will be pretty close to the inside of the pod. If thatís the case Iíll probably have to route the motor wires outside the fuse and bring them back inside in front of the motor or they will foul the motor case. I notice that HK rate this motor as giving 800g of thrust. Given that the plane is also 800g this will give a 1 to 1 thrust/weight ratio. Is that going to be adequate for some spirited sport fun?
It looks like the plane is designed to have a motor mounted inside the firewall, you should have enough room, because the plane calls for a 28mm can motor, if worst come to worst, you can run the wires outside and shield then with a blister of plastic,
Old 01-25-2013, 09:11 PM   #6
Friends: (326)
here is another motor, its a inrunner, its in the UK, I am not sure of the Watts, but it will fit a 6x5.5 prop. 25amps x 10volts= maybe 250 WATTs
http://www.myhobbies.myzen.co.uk/sho...at=130&group=8
http://www.jperkinsdistribution.co.u...p?JPNO=4445060
here is another inrunner that will work nice
http://www.horizonhobby.com/products/EFLM2005
http://www.rcgroups.com/forums/showthread.php?t=1584079
Old 01-26-2013, 05:01 PM   #7
Friends: (326)
Thanks Chellie,
I would use the turnigy outrunner 2350KV even if i had to do a little surgery to make it fit its a awesome motor, I have that motor and love it you will have a 1 to 1 power ratio and it does not get to much better than that also later if you want more power, you can use a 4 cell lipo and a 5x5 apc prop and make it go Ballistic
Info from HK on the BD-5
http://174.143.95.154/hobbyking/stor...dproduct=17137
midair 58 points - 6/10/2011
Can someone recommend an appropriate HK in runner motor and prop?
EDF_Freak 215 points
Why not use outrunner instead? There is plenty of space inside and it costs much cheaper. For speed and unlimited vertical, you may consider on using turnigy 2836 outrunner 2,350KV, 5X5 prop, min 40 A ESC (50-60A recommended) and 4S (35-45C) 1,800-2,200mAH Lipo. This is a James Bond's plane and it should fly fast
Page generated in 0.07453 seconds with 30 queries
