Old 01-27-2013, 12:15 AM   #1
Westwind
Default Batteries for light system
I have Ram 15, 04, and 16 light systems. I have spliced them together and run the system of a 9 volt battery. I would like to try ruining them off a turnigy nano-tech 370mah 25-40C battery. Ram says a 9 volt must be used. Can any one tell me if I well have problems running the turnigy batt
Sent from my GT-I9000 using Tapatalk 2
Westwind is offline
Old 02-12-2013, 08:33 PM   #2
oem flyer
You cannot attain 9 volts with a lipo battery. A lipo battery will have 3.7 volts per cell nominal and 4.2 volts fully charged. Thus, a 2 cell lipo fully charged would be 8.4 volts. A 3 cell lipo would be 12.6 volts fully charged. Your light system might work on 8.4 volts (although not as well as 9 volts). I wouldn't try it on 12.4 volts.
oem flyer is offline
Old 02-12-2013, 09:11 PM   #3
View mclarkson's Gallery4
Outstanding Contributor Award
You'd have to use some sort of voltage regulator with a 3-cell.
mclarkson is online now
Old 02-12-2013, 10:04 PM   #4
CrimzonRider
Fastest PropHead Crasher
CrimzonRider's Avatar
View CrimzonRider's Gallery18
Friends: (14)
http://www.wattflyer.com/forums/showthread.php?t=69616
CrimzonRider is offline
Old 02-12-2013, 10:43 PM   #5
Deja vu!
Old 02-13-2013, 03:55 AM   #6
Friends: (16)
What you'd have to do is hook it up to your 9 volt battery, and measure the current pulled. Then install a series resistor for your 12 volt LiPo battery.
To calculate the resistor value, it would be resistor value equals (12 Volts minus 9 volts) divided by the current.
Example, if its 0.02 amperes, R=3/.02 or R=150 ohms. It's not critical, but don't go much below that 150 ohms. Then when you've got the resistor soldered in series, hook up the battery and again measure the current pulled. It should be close to the current off of your 9 volt battery.
Old 02-13-2013, 04:27 AM   #7
Westwind
Once again guys thanks for you input. I realized that if i used a lipo i would probably run it down below 3v per cell by accedent so what i did was hook up a 1200 mah nimh batt at it wooks great.
Westwind is offline
Old 02-13-2013, 05:15 AM   #8
Friends: (16)
Yeah, I wondered about that, those old Nih cells really work well for this type of thing. They're rather hard to damage.
B-47 9th Scale, Boeing Stratojet...In The Middle Flite-Metal Electric Ducted Fan Jets 252 02-27-2013 02:09 AM
Extreme Flight Extra 300 EXP__Clean Sheet Doc Austin 3D Flying 5 01-05-2013 03:19 AM
For Sale WTS: FMA Co Pilot II, 4 Channel Flight Stabilization System raitheslacker Radio Equipment For Sale & WTB 1 09-17-2012 08:13 PM
Anyone interested in a Longest Flight Contest? AEAJR Hi-Performance and Sailplanes 26 07-23-2011 03:27 AM
Page generated in 0.28783 seconds with 33 queries
