Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Company Support Forums > FMA Direct
Old 02-03-2013, 04:53 PM   #1
Ohio AV8TOR
Ohio AV8TOR's Avatar
Default Cellpro PowerLab 6/8 parallel charging
I would like to get the MPA but I have a slew of balance cables from 2-6. Using the FMA PL8 GP/KO Std Adapter can you then add a Parallel (2x or 6X) balance cable to do parallel charging such as the setup below? If so what Node connector wire position is used FMA or XH/EH?
Name:	Region capture 6.jpg
Ohio AV8TOR is offline
Old 02-03-2013, 05:17 PM   #2
Would it not be easier to just get a proper parallel charging board, e.g.:
Old 02-03-2013, 05:35 PM   #3
Ohio AV8TOR
If I went with a parallel board it would be a MPA. I Have used those ParaBoards before and they are tight. I later switched to the Y connectors as everything is so much easier to connect with the longer connections.
Sneak Peek at the NEW Cellpro PowerLab 8 Tim Marks FMA Direct 63 09-21-2012 05:09 AM
not so easy ...cellpro powerlab 6 setup stuart Batteries & Chargers 24 07-29-2012 03:29 AM
charging multiple mcpx batteries at once on Cellpro Gold 4S? matthewcornell FMA Direct 1 10-31-2011 03:54 PM
Introducing the ALL NEW Cellpro PowerLab 6 (EC5 version) Charger Howard Matos FMA Direct 7 10-25-2011 07:03 AM
Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 0 07-28-2011 02:04 PM
Page generated in 0.19255 seconds with 25 queries
