#1 | ||
I have started building foam airplanes for the last 2 months and getting help from my old boss, but since he laid me off. I lost my bosses help for the airplanes I am building. Okay, here is my questions 1. What is KV? 2. How do I determine the size of KV for the plane I am building? 3. Does KV determine the size of a Prop.... Thanks in advance..... Charles |
#2 | ||
Club: CVMRCC, SEFSD
Hi Charles. Welcome to WF!
KV is how many RPM per volt a motor will turn with no load (propeller, fan, whatever) on it. A big factor in prop choice. Beyond that, I'm pretty much lost myself, but here's some reading for you: Everything you wanted to know about electric powered flight When it comes to choosing power systems, I find motors that give info like the props it should use and how many amps it will pull with each prop, etc. Enjoy the reading! |
#3 | ||
Kv is only one of the parameters of a motor.
Generally you choose the amount of power you want first based on the weight of the plane and type of flying (trainer, aerobatics, 3D etc). When you've got the basic motor power then you need to think about the battery you're going to use and the motor's Kv. But Kv does affect prop size. Simplifying a bit, lower Kv = larger prop turning slowly, higher Kv = smaller prop turning faster. Steve |
#4 | ||
So over-simlifying and generalising:
You figure out how many watts the plane needs based on it's weight and desired performance envelope. You decide the maxim size of prop you can use (based on ground clearace etc.) Then you go looking for a motor and battery combination that will give you your watts (plus a margin of error) while spinning your chosen prop. Use the manufacturers data or programs like eCalc to figure it out. Big props work best for most planes with the exception of high speed models where you might have to go for a smaller prop spinning at higher RPM. |
#5 | ||
Club: AMA, Marks, Pomona Valley, Prado Dam
Charles.....
KV = kilovolt - a unit of potential equal to a thousand volts kV potential unit - a measure of the potential energy of a unit charge at a given point in a circuit relative to a reference point (ground) V, volt - a unit of potential equal to the potential difference between two points on a conductor carrying a current of 1 ampere when the power dissipated between the two points is 1 watt; equivalent to the potential difference across a resistance of 1 ohm when 1 ampere of current flows through it. Hope that helps ya........... |
#6 | ||
But, this KV isn't that KV...
#7 | ||
Friends: (16)
Originally Posted by charles nitrotek
KV is just an indication of how fast a given motor will turn over with a given battery voltage and reasonable propeller. In theory, a 600 KV motor will turn a reasonable propeller at 6000 RPM on a 10 Volt battery. (600 times 10 Volts.)
The main parameters of these brushless motors is KV, Amps at no load, winding resistance, and motor weight. You could have a tiny one ounce motor with 400 KV that would turn perhaps a 6 inch propeller at 7000 RPM. That 6 inch propeller might blow some of the papers off of your desk. Or, one of my big 25 Ounce Hacker A60 motors that will turn a 19 inch propeller at 7200 RPM. That 19 inch propeller will clear everything off your desk, including any models that might be on it! Big difference! Similar to an electric drill motor that turns over at 10,000 RPM, versus one of those Indy 500 race cars with 800 HP that also turns over at 10,000 RPM. What helps in what you're trying to do is one of those computer programs. One good one is www.motocalc.com, free for 30 days, then $39. This program allows you to input model wingspan, wing area, model weight, motor mfg, battery and prop size, and let you know if it will fly, and how well it will fly. Also lets you know if the motor is being pushed to hard so as to burn up its windings. Or if you've got way to small of a propeller on the motor, making for real inefficient operation. |
#8 | ||
3D wannabe
AMA #959089
#9 | ||
#10 | ||||||||||||||||||||||||
homo ludens modelisticus
Club: www.rmvc-cumulus.nl
Originally Posted by bpj1980
Very handy/instructive tools and calculators, wiring diagrams, demos:
The Script Asylum -> RC calculations -> electrical E-flight 101 by RCG member Ken Myers, will at least save you a ruined LiPo (or worse!), a burnt motor and a fried ESC: The Ampeer -> Electric Power Basics followed by The Ampeer -> Everything youw wanted to know about e-flight (Ed Anderson) Table of Contents
Bruce heeft nog veel meer nuttige filmpjes voor modelbouwers op zijn geweten, meer dan 100, niet alleen over accu's: www.youtube.com/user/RCModelReviews/videos Idem zijn site www.rcmodelreviews.com LiPo storage
All about LiPo's
LiPo charging, 4-button charger
4-button charger, loading & saving data
What't inside a 4-button charger
ombouwen PC voedingen DIY: using a PC power supply
Switching charger to other batty type
Accucel 6 charger
#11 | ||
"<nitpick>Actually, kilovolt is spelled kV and "our" Kv is spelled Kv.</nitpick>"
LOL....kinda knew that....just threw it out there since the ? was KV....lol Good stuff Ron Van! |
| substituting much higher Kv motor? | CanCanCase | Beginners | 3 | 12-11-2011 12:52 AM |
| Wanted 2200 kv motor out runner | jim lyle | Motors and Speed Controllers for sale & WTB | 2 | 12-05-2011 02:19 PM |
| Trouble with kv | kvflyer | General Electric Discussions | 19 | 10-04-2011 09:56 AM |
| Motor ratings (KV or watts) | Bald Paul | Power Systems | 8 | 05-23-2011 06:46 AM |
| 2200 KV MOTOR getting hot, smells?? | BOB275 | Power Systems | 13 | 02-18-2011 02:06 AM |
