Old 02-12-2013, 09:07 PM   #1
View mclarkson's Gallery26
Friends: (8)
Default Wood propellers?
I've got a couple of planes I'm thinking about adding wood props to for scale purtiness. I notice that HobbyKing, for example, sells a wide range of wood props. They're labeled, TYPE A, TYPE C, etc. etc.
I've no idea what this means.
They ones that seem the most promising are labeled TYPE A BEECH. Is that ... right?
I know there are 10x8 props and there are 10x8 props but, in general, if I'm running a 10x8 propeller on, say, my SE5a do I want to replace it with a 10x8 if I go to wood?
Any advice is appreciated.
Old 02-12-2013, 11:37 PM   #2
Stevephoon
Stevephoon's Avatar
View Stevephoon's Gallery70
Friends: (8)
Mark,
I have a XOAR and some Turnigy wood props that are specifically made for electric motors. I would only use those made specifically for electrics unless you are using a really big heavy motor. I have had good luck with both. The turnigy are cheaper and the finish is not quite as smooth, but all have been balanced OK out of the shoot and seem to perform pretty well. I still think the APC thin electric are the best for mid sized planes and GWS for smaller.... But when you want that wood look, these work fine!
http://www.hobbyking.com/hobbyking/s...ric_wood_.html
http://www.xoarintl.com/rc-propeller...ood-Propeller/
Growing the fleet!
Stevephoon is offline
Old 02-12-2013, 11:40 PM   #3
hayofstacks
hayofstacks's Avatar
http://www.headsuprc.com/servlet/Categories
Headsup has several wooden props for a good price. I have no idea how to answer your question though. I was wondering the exact same thing. I have ran nitro props, and although they work, they don't put out the same thrust as an apc/slow fly prop on my electric motors.
I have however ran a couple of composite nitro props that worked fine on a escapade that we picked up from a yard sale with a 11X7 prop on the motor already. There was no discernable differance between the apc or electric props on this plane.
It is fairly easy to get a black prop and paint the tips yellow to get a good scale look on warplanes.
hayofstacks is offline
Old 02-12-2013, 11:48 PM   #4
Friends: (8)
I'm considering them for my WWI-era SE5a and my 30's-era Tiger Moth.
Old 02-12-2013, 11:52 PM   #5
Stevephoon
Stevephoon's Avatar
Friends: (8)
Most of the glow engine props, (from any material) are just too heavy for the smaller electric motors to spin. (Probably from 400 Watt and up it may not matter. Just a guess)
I had forgotten about the headsuprc props. I just bought this one, but I have not even pulled it out of the box yet..
http://www.headsuprc.com/servlet/the...-6-DFDL/Detail
Growing the fleet!
Old 02-13-2013, 12:00 AM   #6
Friends: (8)
I know a nitro wood props are going to be too heavy but these TYPE A's look fairly light. HobbyKing shows the Master Airscrew Beech Wood 10x8 propeller at 22 grams, and the Master Airscrew Electric Only 10x8 propeller (glass-filled nylon) at 32 grams. FWTW.
Old 02-13-2013, 12:05 AM   #7
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
The Turnigy "light" electric are what you want. They work well, as do the Xoar light electric props.
http://www.xoarintl.com/rc-propeller...Propeller/#des
They generally are larger sizes however and they are a bit limited in selection.
Old 02-13-2013, 01:54 AM   #8
Friends: (8)
Thanks for all the input, guys. By the weights, the 'light' woods from HK appear to be heavier than the other series. Definitely more limited in my sizes. I'll probably buy a few of each and see what I get and how it works.
Old 02-13-2013, 02:19 AM   #9
WAA-08 Pilot
Friends: (9)
The "light" ones are significantly lighter than the other Turnigy wood props I have. HK uses shipping weight on some items - strange but the light ones I have are lighter than their other wood props.
They also perform much better in my tests - pretty much the same as Xoar at a much nicer price. They rival the efficiency of APCe and they are very stiff.
Old 02-13-2013, 03:06 AM   #10
Friends: (8)
And ... they're all on backorder.
Old 02-13-2013, 01:19 PM   #11
WAA-08 Pilot
Friends: (9)
No not all of them - but no question the secret is out. More likely that HK stock controls are still less optimal than desired. Shocking.... LOL
Old 02-13-2013, 11:48 PM   #12
nidly
I bought a bunch of the wood electric props and while they were even lighter than plastic ones I wasn't impressed with them for two reasons.
Some of the holes weren't drilled on center and they seemed to pull nearly as much current , but turned the plane into a dog. I'm fixin' to use a few more of them to make sure that I do or don;t really like them. I think I'll replace an exact 11x7 with a wood 11x7 for comparison.
nidly is offline
Old 02-14-2013, 12:05 AM   #13
Friends: (8)
What was the brand / where did you buy them? Do you remember?
Old 02-14-2013, 12:11 AM   #14
nidly
They were the turnigy ultra light wood. The cheap ones that are backordered.
nidly is offline
Old 02-14-2013, 12:38 AM   #15
WAA-08 Pilot
Friends: (9)
Not my experience - the ones I have used rival APCe props in efficiency. I have not had an issue with offset holes either in fact balance on them was excellent.
Old 02-19-2013, 02:28 PM   #16
Stevephoon
Stevephoon's Avatar
Friends: (8)
I see that HobbyKing now has a lot of the Light Electric Props in stock. I also see a new type of wood prop. A wood slow fly prop.
http://www.hobbyking.com/hobbyking/s..._Slow_Fly.html
It would be nice to have a slow fly wood prop on some of the WWI birds... I do not see any details on theses props, so I am not sure if they would work on small to mid sized electric planes. Anyone else have any more info on those props?
Growing the fleet!
Old 02-19-2013, 02:37 PM   #17
WAA-08 Pilot
Friends: (9)
Steve those certainly look interesting. Not very authentic for WW1 aircraft though IMHO. The scimitar shape is more what they used.
That said - not sure what those props will do other than in very low revs. Will be interesting to see the amp draws -suspect they will be way up with that large blade.
ID:	166383   Click image for larger version
ID:	166384   Click image for larger version
Old 02-19-2013, 03:01 PM   #18
NJSwede
3D wannabe
NJSwede's Avatar
View NJSwede's Gallery1
2kW  1kW
Friends: (11)
I've been using Xoar props for some of my models and I love them. Nicely balanced and pretty much "everyone" carries them, so it's easy to find replacements when the inevitable prop strike happens. I'm sure the Turnigys are fine too, but the lack of supply always turns me off a bit.
AMA #959089
NJSwede is offline
Old 02-19-2013, 03:03 PM   #19
WAA-08 Pilot
Friends: (9)
Yep i have used both and the Turnigy's are a pretty good representation. But agree HK is a bit of a whipping even when they do good.
Old 02-20-2013, 02:33 AM   #20
Friends: (8)
None in my size, of course.
Wood spars problem solved ! solentlife Scratch and Kit Built Aircraft 12 01-08-2013 06:00 AM
Wood vs carbon fiber propellers? DannyShadow Beginners 19 11-09-2012 12:39 AM
Scratchbuilders - when you bulk order wood, what do you get? Mojo Scratch and Kit Built Aircraft 3 04-10-2012 09:36 PM
For Sale APC Electric Propellers brianfp_400 Airplanes - Electric For Sale & WTB 3 06-11-2011 01:15 AM
Page generated in 0.76883 seconds with 64 queries
